Go Back   HeliFreak > R/C Electronics Support > 3Digi FBL System
3Digi FBL System 3Digi Supoort
Old 11-30-2017, 04:04 PM   #1 (permalink)
Default HW 100 v3 Connection?
HW Has 1) Thr cable- 3 wires, and 2) BEC- 2 wires, RPM- 1 wire.
Where do the BEC wires go into the unit? This gave me pause:
"Hint: At the RPM sensor input an external voltage must not be connected under any circumstances, as this could result in damage to the 3Digi"
RCFred is offline        Reply With Quote Quick reply to this message
Old 11-30-2017, 04:26 PM   #2 (permalink)
Separate the RPM signal and put the BEC in any other open port.
NX4|eXo|Chronos|7NT|Specter700
*AccuRC Substance Guru*
Saje Marvin - Citizen 125
Raz0rSh4rp is online now        Reply With Quote Quick reply to this message
Old 11-30-2017, 04:29 PM   #3 (permalink)
I will be using Spek sats, so the REC. (or rather the "reveiver") port is the only open one.
Thx.
Old 11-30-2017, 05:30 PM   #4 (permalink)
Are you using the cyclic 4 channel? That's where I put my Bec power in and the room into its own servo connector
Kaolith is offline        Reply With Quote Quick reply to this message
Old 11-30-2017, 07:06 PM   #5 (permalink)
Done. Now, binding problem.
Spektrum DX7 and sat plugged into inner slot.
Start Terminal. Click bind box. Spektrum 1 sat, DSMX 11ms. Save. Close Terminal. Unplug pc cord. Plug in heli bat. Red and Grn lites shine. No flashing lite on sat.
Old 11-30-2017, 08:08 PM   #6 (permalink)
Check the 3Digi “Live data” menu when you are connected with your PC... bottom left side bar below your par set menu selections... anyway on that screen you will find RC1 and RC2 status lights... if you hover your mouse over RC1 it will indicate your Spektrum receiver status.
Name:	Capture 3digi Live Data tab.jpg
ID:	730250   Click image for larger version
Name:	Capture 3digi Rx Config tab.jpg
KC8CYF is online now        Reply With Quote Quick reply to this message
Old 12-01-2017, 09:28 AM   #7 (permalink)
I see the RC1 in red (fail safe).
Still unable to bind. What does this tell me to do?
Thx
Old 12-01-2017, 01:12 PM   #8 (permalink)
I don’t have Spektrum setup so I can’t help much with that... I would recommend reviewing the 3digi manual regarding the binding process. Looks like you have a few options for linking the 3digi
There’s a power up delay on the configuration menu... Diverse tab. Default is 0 seconds... try setting to 1 or 2 seconds. Might help delay 3digi initialization while the Spektrum Rx is binds.
Verify correct modes on the Transmitter tab... choose your receiver setup... DSM or DSMX, single or dual Rx... 11ms or 22ms frame rate, etc.
Name:	Capture 3digi Diverse tab.jpg
Synergy E5-626 / HW100v3HV / Unisense / Brain2
Synergy E7se-696 / Mezon 130 / Brain2
Mikado Logo 600 / HW100v3HV / Brain2
Old 12-01-2017, 05:32 PM   #9 (permalink)
Doh!
I had the sat. plugged into the wrong port; right instead of left!
Human Verification
