Go Back   HeliFreak > R/C Helicopter Support > OXY HELI > Oxy2
Like Tree11Likes
Old 12-10-2017, 10:22 PM   #41 (permalink)
Went together super quick and smooth. The only hesitation I have is that the tail slider has a _tiny_ bit of friction on it, not sure if I知 gonna disassemble it and lightly sand it down.
Electronics will go in tomorrow and I値l get it tuned to fly next weekend!
ID:	731188   Click image for larger version
WonderedUnder is online now        Reply With Quote Quick reply to this message
Old 12-11-2017, 03:58 AM   #42 (permalink)
What I have done in the past is once I have the motor installed, tail slider fitted, but no blades (tail or mains), oil the tail shaft and get the motor running at low rpm move the tail slider from one extreme to the other a few times (either with servo or fingers).
This has helped it to bed in...
Mikej is online now        Reply With Quote Quick reply to this message
Old 12-11-2017, 05:33 AM   #43 (permalink)
I started assembling mine and noticed the coarse surface finish on the tail shaft. Some 600 grit sand paper improved the finish, the slider moves smooth now. Emery cloth, 400 grit or scotch brite pad would also work. A corse finish will wear the inside of the pitch slider quicker, so it is good to do if you ever see a coarse finish on a tail shaft.
Tom
TRM Power
CAUTION - my posts are based on my experiences, yours may be different.
fastflyer20 is offline        Reply With Quote Quick reply to this message
Old 12-17-2017, 08:12 PM   #44 (permalink)
Just finished the build this weekend as things have gotten crazy. This was my first time using a hobbywing esc or a brain FBL unit.
I'm getting a tail wag, much like many of the folks here have had on their oxy2. I have read the basic threads... but not really sure what to do to fix it at this point.
Tail wag is the same at 3800-4400 rpms. i'm running 45% gain in the microbrain. tail slider moves smoothly. i have the belt pretty darn tight.
Any ideas?
Old 12-17-2017, 11:08 PM   #45 (permalink)
Any ideas?
45 is way high. Try as the manually says. Around 20.
Page 32.
Thickfog is offline        Reply With Quote Quick reply to this message
Old 12-18-2017, 01:18 AM   #46 (permalink)
Default Getting back into the hobby - OXY 2 build question
+1 for the gain around 20
And the belt shouldn稚 be to tight. You could try to loosen it a bit.
AWdeBoer is offline        Reply With Quote Quick reply to this message
Old 12-18-2017, 07:09 AM   #47 (permalink)
turned gain down to 20 this AM - wag is less, but still prominent. Not sure how i missed that step of the manual....
Old 12-18-2017, 07:43 AM   #48 (permalink)
What's more tough is making sure you read every word in the left panel when setting up your ikon/brain. Miss a word or two and things become painful. I did that first time around. There's super important stuff there.
If you still have wag, try 18 to 19, but around 18 you'll get blowouts, especially if you run low headspeed.
Make sure your tail pitch mech is super free and butter smooth.
Make sure you have the tail servo arm ball in the specified hole.
Some servos will not work well. What servo are you using? People always try to save money on tail servos and it's the worst place to do so in a copter.
Try all that and let us know. We'll get into fine tuning after this.
Old 12-18-2017, 09:19 AM   #49 (permalink)
In panel 8, not 100% of the panel number, where you adjust tail servo travel...do you have the box checked that says "set in software? If not, you adjust gyro gain in your radio. If you do, make sure radio adjust is set to inhibit.
-Ben
Oxy 2/3/4; P380; Logo 700 project starting soon; DX9
Lynx Heli Innovations Field Rep
Old 12-18-2017, 09:58 AM   #50 (permalink)
I did try turning the gain down even more, and again, the wag got a little better, but the tail becomes ridiculously soft.
The tail pitch mechanism was rough when i first got it (as i posted above), so i sanded it with 400, then 600, then 1200 grit sandpaper and now it's butter smooth.
The tail servo is a blue arrow H0988UHS Tail Servo which is what i got in the lynx recommended setup. I have the ball in the second hole, which is about 6.2mm (manual says 7mm).
And in panel 8, i don't have "set in software" checked, as i adjust the gain from my dx8.
Old 12-18-2017, 10:12 AM   #51 (permalink)
And you have done the tail servo travel adjustment in panel 8 to near max travel of the slider left and right, correct?
-Ben
Old 12-18-2017, 10:14 AM   #52 (permalink)
I maidened my Oxy2 yesterday (190 version). I saw the recommended gain in the manual but didn't go immediately towards that number (also set in Tx) and prefer to adjust on the fly as necessary. Although I don't have my Tx in front of my, I recall I am in the low 40s at 4300rpm, mid 30s at 4500 and low 30s at 4700 with no tail wag. I'm still tuning it a bit so it may go a bit further as I continue to learn the heli and fly a bit more aggressively.
Are you using the 38 or 41 mm tail blade? I went directly to the 41 as a lot of people have recommended.
MSH Mini Protos Stretch || Oxy 4 325 || Oxy 3 255 || Oxy 2 190 FE || NCPS || DX8
howaboutme is online now        Reply With Quote Quick reply to this message
Old 12-18-2017, 10:30 AM   #53 (permalink)
Yes, i have completed the max tail servo travel on panel 8.
And i'm using the 41mm tails on the 210 mains (stretch) running 3800-4400 headspeed. i have set my transmitter gain anywhere from 15%-65% (in the transmitter, not in the ikon) and the tail wag exists throughout all of these ranges - which makes me think more and more that it's something mechanical.
Old 12-18-2017, 10:44 AM   #54 (permalink)
Yes, sounds mechanical. Have you gone through and checked all ball links to make sure they move freely (tail grips to slider, pitch lever to rod, rod to tail servo ball? Make sure the links in the slider move freely without binding also. Isolate these items and don't check as an entire moving piece.
-Ben
Old 12-18-2017, 10:50 AM   #55 (permalink)
Ball is almost 1mm away from ideal spec too. Do you have a different arm you can use.
Most people have said that the spektrum servo works the best overall.
Old 12-18-2017, 11:19 AM   #56 (permalink)
I'm not able to test fly it, but i loosened up the ball links in the tail grips to slider, they were a little tight, but still moving freely.
The only other thing i can notice is that when i move the tail rod by hand, at or near the extreme, sometimes the tail servo push rod will "flex" and then it will get "stuck" and won't want to move until i change the pressure on it. Hard to describe i guess, ... the pushrod doesn't seem straight by design as far as i can tell. I have a feeling that this may be my problem, because the mechanical play of the tail when i detach the pushrod from the crank is perfectly smooth.
i'll try a different servo arm this evening when i get home and go back through the tail setup on the ikon. that should help make the angle a little less "steep" and give the servo a little more speed.
Old 12-18-2017, 12:14 PM   #57 (permalink)
Are you running the center tail rod support? There should be some resistance on it. Pics?
Old 12-18-2017, 12:26 PM   #58 (permalink)
Did you select a "450" size heli in the FBL programming? If you did, set it to the proper blade length.
For elimination, since you mention some potential binding, you can remove the tail rod support for now.
-Ben
Old 12-18-2017, 12:35 PM   #59 (permalink)
.. the pushrod doesn't seem straight by design as far as i can tell. .
I noticed that too that the center rod support actually kinks the rod a slight bit. Kind of weird of a detail if you ask me but I don't have any binding issues as a result.
Old 12-18-2017, 12:43 PM   #60 (permalink)
Designed for a reason like that. Prevents the rod from resonating and causing vib issues. Bigger deal on micros than larger helis.
Human Verification
