Go Back   HeliFreak > R/C Electronics Support > 3Digi FBL System
3Digi FBL System 3Digi Supoort
Old 01-17-2018, 04:16 PM   #1 (permalink)
Default Binding procedure for 2 spektrum satellites
I have been looking everywhere and haven't been able to figure out how to do this. If someone could help me out I would really appreciate it. I am down to hooking up electronics and then I can fly my Heli. Thanks
str8heli is offline        Reply With Quote Quick reply to this message
Old 01-17-2018, 05:21 PM   #2 (permalink)
Search the older threads here and review the 3digi manual. I did not have Spektrum system but recall a process to bind written in the user manual. You will need to specify the exact Spektrum interface type as well... DSM/DSMX 2048 and such. That was on the first tab of the 3digi setup.
KC8CYF is offline        Reply With Quote Quick reply to this message
Old 01-17-2018, 05:47 PM   #3 (permalink)
Thanks for responding.The manual only lists where the ports are and that one port is the master and the second becomes the slave in binding. My question is do I hook them up to the 3digi and then bind or is it done with a separate spektrum reciever and then the satellites are connected to the 3digi.. My guess is bind the first sat on a separate receiver and then the other becomes the slave when plugging it into the 3digi but I'm not really sure. I will continue looking it up in the other posts but as of yet I haven't found an answer.
Old 01-17-2018, 07:07 PM   #4 (permalink)
I got some info for where it was in the manual. Thanks
Old 07-11-2018, 06:45 PM   #5 (permalink)
So I am racking my brain trying to bind my 3digi to 2 dsmx sats. I can not get the sats to start blinking. Yes, bind at next Int checked. Clicked save, disconnected. Unplugged usb, plugged in battery... nothing. Tried many other different ways. What is the correct way to get the sats to bind? Heli is already set up. Crashed my logo 480 in November and finally got it fixed. Installed v2 and updated firmware so have to bind again and can’t for the life of me figure this out.
Align 450 Pro MKS ds95, ds520, ice 50, mx450, ar7200BX 4S 3850 rpm Edge 325mm
MSH Protos Max V2 Red MSH motor, Edge 160, MKS hbl960, Outrage bl9188, Neo, 700mm and 115mm Zeal
Citizen 731
dobis77 is offline        Reply With Quote Quick reply to this message
Old 07-30-2018, 10:25 PM   #6 (permalink)
Originally Posted by dobis77 View Post
So I am racking my brain trying to bind my 3digi to 2 dsmx sats. I can not get the sats to start blinking. Yes, bind at next Int checked. Clicked save, disconnected. Unplugged usb, plugged in battery... nothing. Tried many other different ways. What is the correct way to get the sats to bind? Heli is already set up. Crashed my logo 480 in November and finally got it fixed. Installed v2 and updated firmware so have to bind again and canít for the life of me figure this out.
Not sure if you have figured it out or not, but here is what I did: under Configuration/Diverse I set the "PowerOn init delay" to 3 seconds. I have never had problems with dsmx sats and 3Digi with the v1 firmware, but after upgrading to v2 last fall, I started to have random initialization issues with the master dsmx sat. After I increased that delay, the problem went away (for the most part, it still happens occasionally and I need to rebind the master sat after which I will be good for many flights). Hope this helps.
3Dmuse is offline        Reply With Quote Quick reply to this message
Human Verification
