Go Back   HeliFreak > R/C Helicopter Support > KDS Helicopters General Discussion > KDS Agile 5.5
KDS Agile 5.5 KDS Agile 5.5 Discussion
Old 01-20-2018, 11:35 AM   #1 (permalink)
Default KDS 5.5 setup
Hi guys just a question on setting this up do you guy level the boom and then setup or leave it flat on the skids. What is the proper way .
It just seems that leaving it on the skids for setup would that make the fbl unit want to pull forward all the time. And if it is level on setup and then put back on the skids would that throw off the fbl unit and want to go back towards you in a hover .
bk479 is online now        Reply With Quote Quick reply to this message
Old 01-20-2018, 11:08 PM   #2 (permalink)
Leave it flat on the skids, every time you plug in the battery the FBL unit resets itself saying this is level so you do want the helicopter on a level surface on the skids when you plug the battery in. Your question is the same for any helicopter with a FBL unit they all work pretty much the same.
KDS Agile 5.5, Ikon, KST, KDE motor/Gaui X4ii, BK servos, Brain / Gaui X3, Ikon, KST, Scorpion 1580Kv
Frsky Taranis plus
PhoenixRC upgraded to wireless
Larryu is offline        Reply With Quote Quick reply to this message
Old 01-21-2018, 12:27 PM   #3 (permalink)
For setup I level the main shaft with a digital pitch gauge.
- Ensure you have a good zero on your digital pitch gauge on a flat surface.
Remove one of the swash to blade grip links and allow the grip arm to rest on the center block.
- Place the pitch gauge on the blade grip resting on the center block.
Rotate the head checking reading on all four points perpendicular with and transverse to the boom.
- Level the heli by shimming the skids/tail fin with magazines, paper etc until all four readings on the digital pitch gauge are the same. Your main shaft is now perfectly square vertically.
- Carefully move the pitch gauge to the other blade grip.
- Rotate the head to the four points again and adjust the servo to swash links so you have the same reading at all four points, your swash is now totally level.
- Now you can go about setting collective and cyclic pitch adjustments as you typically would from a perfectly vertical and level swash.
Paul
Agile 5.5 - Q 4125-1100, YEP 120, Brain2 HD FBL / Outrage 550 - HK4020-1390, Edge 120, Brain2 HD
Rave Ballistic FSO - Q 4530-500, Edge 160HV, Brain2 HD / Protos Max V2 - MSH 4530-500, Edge 160HV, Brain2 HD
pctomlin is online now        Reply With Quote Quick reply to this message
Human Verification
