Go Back   HeliFreak > R/C Helicopter Support > Synergy Model Helicopters > E5
Like Tree24Likes
Old 02-20-2018, 09:23 AM   #41 (permalink)
Originally Posted by Freeskiken View Post
Thanks. It shows in the E7SE manual 270mm from each end, 260mm in the middle. I didnít see that on my printed copy. I put mine 254mm from each end. So if the tube is 800mm. I should have 292mm in the middle. Itís not even spacing so hopefully its OK. I will check it tonight.
just run it man... it will be fine, I did the same thing.
Freeskiken likes this.
tonys-heli is online now        Reply With Quote Quick reply to this message
Old 02-20-2018, 11:13 AM   #42 (permalink)
Thanks Tony.
I tested the R2 Buffer Pack yesterday. I am running the internal BEC on the Tribunus at 6.1 volts. I unplugged the main batteries and stirred the sticks. It took about 35 seconds to deplete the capacitors. Should be lots of time to auto. I set my VControl to warn me with a vibration and voice when the BEC gets to 5.8 volts. Works great.
Diabolo 600, Synergy-696, E5SS, E5S, Soxos 600, Strike 7, Logo 600, 200, VControl T, VBar, Egodrift, Scorpion, MKS, XPert, KST
Freeskiken is offline        Reply With Quote Quick reply to this message
Old 02-20-2018, 04:19 PM   #43 (permalink)
I set the protection limits. Max amps to 50 amps. It will allow 112 amps max. I couldn't find the amperage rating on the Hacker A50 14L motor but I don't think I would ever pull more than that. The only rating on the motor I could find is a max of 4500 watts.
Edit: It calculates 89.2 amps so it should be fine.
I set 14 degrees of pitch and 8 degrees cyclic. See how it goes. Maybe on low head speed 1200 rpm or so it should be higher?
Old 02-21-2018, 12:57 PM   #44 (permalink)
Customer service from Synergy R/C Helicopters (Matt) is the best !!!!! I asked him about the M5 x 35mm head bolts that were too long for the E5SS and he is sending me new ones that will fit no charge. Number one service !!!!!! Thank you Matt !!!
mverhorst and Indokast like this.
Old 02-22-2018, 08:08 AM   #45 (permalink)
Just ordered my custom aluminum sliding battery tray system for the E5SS it is ready.
Old 02-22-2018, 11:03 PM   #46 (permalink)
Looks like it is ready for the maiden. Just the weather isnít yet. But It is finished where it will fly. Weighed it and the Helicopter less batteries is 7.34 pounds. A very light 700 !! With my Gens Ace 2 - 4000 mah 6S 60C packs it weighs 10.14 pounds. It will be 9.56 pounds with my Gens Ace 2 - 3300 mah 6S 60 C packs. Should fly very light !!! The build went very well. Quality of the E5 is great.
Thank you Gary. He is the inspiration to build this Heli.
Thank you everyone for the great ideas and the help !!! Helifreak is awesome !!!
I will post some pictures when I can take some in daylight.
Old 02-23-2018, 05:25 AM   #47 (permalink)
Default Battery tray
Can you share the link or source for your custom trays?
Hope the maiden goes great. I just maddened my E5S last weekend between the rain clouds it was awesome. Yes, Helifreak is great!
Michael
So if the Son sets you free, you will be free indeed.
John 8:36
Kraken, Specter 700, Synergy E5S.... and many spare parts.
Mike_Capflyer is offline        Reply With Quote Quick reply to this message
Old 02-25-2018, 09:33 PM   #48 (permalink)
Here are some pictures of the finished E5SS !!!
ID:	738529   Click image for larger version
trillian likes this.
Old 02-25-2018, 09:35 PM   #49 (permalink)
More pictures !!
ID:	738531   Click image for larger version
ID:	738532   Click image for larger version
ID:	738533   Click image for larger version
ID:	738534   Click image for larger version
trillian and Mike_Capflyer like this.
Old 03-07-2018, 10:33 PM   #50 (permalink)
I received and installed my new custom painted canopy and my custom aluminum battery tray. So just need to maiden. It is 9.28 lbs ready to fly.
ID:	739406   Click image for larger version
ID:	739407   Click image for larger version
ID:	739408   Click image for larger version
ID:	739409   Click image for larger version
Old 03-07-2018, 11:30 PM   #51 (permalink)
That should be an excellent weight for that size. 12s purple power.
Should be able to fly for a long time at 1600. 10-12 Minutes.
Looks great with that canopy and that battery tray. Well done.
Hope it warms up for you to fly It soon.
Steve
Team Mastercard.
smittylube is online now        Reply With Quote Quick reply to this message
Old 03-08-2018, 12:14 AM   #52 (permalink)
Thanks Steve.
I plan on trying three banks, 1250 rpm, 1400 rpm, and 1600 rpm. See how it fly's. Really happy with the way it turned out. I have some VTX blades as well.
Old 03-08-2018, 07:48 AM   #53 (permalink)
The VTX fly awesome, but I much prefer the rails overall as they auto amazing. I've found as they slow down I can still get lift when you think no way. They allow a ton of hang time for a nice soft set down, for me the vtx drop off rotor speed much faster than rails. I think it really shows how well the rails perform at the slow speeds and higher pitch angles. I'm mostly flying 1600, but having both blades will be fun switching back and forth to see what works best for your feel and style.
Steve
Team Mastercard.
Old 03-08-2018, 07:51 AM   #54 (permalink)
What pitch are you using ? 14 degrees or higher ?
Old 03-08-2018, 08:31 AM   #55 (permalink)
About 14 - 14.5 much higher I get cyclic binding at the ends. I know your not supposed to do cyclic and pitch at the same time, so if your good with that then you can run higher.
That blade and 14 climbs really good at 1600 and lower as well.
It just sips the amps. Roughly 16 to hover and 50-60 tops flying for me.
Steve
Team Mastercard.
Old 04-29-2018, 09:08 PM   #56 (permalink)
Finally flying on Saturday. I set the pitch at 16 degrees, cyclic at 8 degrees, 1260 rpm, and it flies great. 2 - 3300 mah 6S batteries. I was getting 9:30 minutes. Really impressed !!!
Synergy Helis are awesome, you build them and no weird tendencies, no tail issues, no aftermarket upgrades needed, just flies perfect. Quality!!!!
Hicksy and Rodney Kirstine like this.
Old 04-30-2018, 07:59 AM   #57 (permalink)
Nice to hear it worked out well. Sounds fun to me.
Steve
Team Mastercard.
Old 06-11-2018, 06:59 PM   #58 (permalink)
I have been asked a few times for a parts list to build the E5SS. From other posts from Gary Wright and Codepox.
999-308 Synergy E5 FBL/TT Kit
310-121 Helical Main Gear 121T
320-154 54T Spur Gear
320-111H 11T Spur Gear - Hard Coat
310-145 Blade Bolt Adapter 5mm
315-140 Tail Boom 812mm E7
320-500 Torque Tube E7
315-117 Carbon Boom Support Rod 580mm
315-111 Carbon Tail Control Rod 728mm E7
305-012H E5/E7SE 12T Pinion Hard Coat
For the Carbon Tail Control Rod, the E7 one (315-111) at 728mm is on the short side to get a good engagement of the plastic links, this is because of the tail servo placement between the E7 and E5, I recommend using the 766 one and cut it down to 737mm.
706-306 Carbon Tail Control Rod (Comes at 770mm and cut it down to 737mm)
If you use 106mm or bigger Tail Blade, I recommend using the N7 Vertical Tail Fin which is 11mm longer for more ground clearance.
317-302 N7 Vertical Tail Fin
If you are using 696/716mm main blade, you are also going to need the 5mm Blade Bolt Adapter as well as M5x35mm screws and M5 Nylon nuts.
Hicksy, mverhorst, Grimmy and 1 others like this.
