Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > 270CFX
270CFX Blade 270CFX Helicopters Information and Help
Like Tree4Likes
Old 02-01-2018, 01:15 PM   #1 (permalink)
Default 270 fusion
any body seen one of these yet ?
270 with safe and bail out with AR363 4 cell
https://www.horizonhobby.co.uk/BLADE...LH5350&p=43559
weinribgeddy is offline        Reply With Quote Quick reply to this message
Old 02-01-2018, 04:52 PM   #2 (permalink)
Looks interesting but I'm more excited that it comes in a ARF kit as well..
Blade 450X/450X-3D-HV2/ 550X/300CFX/Goblin-700/2-180CFX/Blade 360CFX/Goblin 380/360 Trio, E-flite Convergence
Microheli Team Pilot
Chris g. is offline        Reply With Quote Quick reply to this message
Old 02-01-2018, 08:34 PM   #3 (permalink)
Guess this is the 270CFX replacement.... I might have to buy
Esky Lama V4, Blade 120 SR, MQX, Nano CP X, Nano QX & 3D, mSR X, 130S, 230S, TRex 450, TRex 500, Spektrum DX9
Mysterious is offline        Reply With Quote Quick reply to this message
Old 02-02-2018, 02:11 PM   #4 (permalink)
I would be very interested in the ARF myself! My current 270 has KST all the way around and I unlocked the ar7210bx. Might get one of the price right!
Vcontrol Vbar Neo
Logo 700,Trex 700x, Goblin 500S, Trex 470
Hobbywing, iCharger!
ssschmidt4 is offline        Reply With Quote Quick reply to this message
Old 02-02-2018, 05:47 PM   #5 (permalink)
Yep, I am looking at 6 of them right now
If you have any questions on the model let me know.
Best Regards,
Horizon Hobby, LLC
Brian Bremer
brianbremer is offline        Reply With Quote Quick reply to this message
Old 02-02-2018, 06:27 PM   #6 (permalink)
Best Regards,
Horizon Hobby, LLC
Brian Bremer
Question answered.. Stability mode can be mimicked by setting gear channel over 124% keeping SAFE active. However the model is not advertised as having that feature. Thanks for clearing that up Brian
BrokeDad is online now        Reply With Quote Quick reply to this message
Old 02-02-2018, 07:48 PM   #7 (permalink)
Hi Brian,
Does the SAFE on this one mimic the other SAFE operation similar to a 230S etc. or is it a bailout like an upgraded 270cfx?
Thanks in advance!
Bill
Bill_Van is offline        Reply With Quote Quick reply to this message
Old 02-02-2018, 08:20 PM   #8 (permalink)
Originally Posted by Bill_Van View Post
Hi Brian,
Thanks in advance!
Bill
It is a bail out function only , it does not have self level or limited bank angle like 230s or 250s according q & a section on product video ..
Old 02-02-2018, 08:29 PM   #9 (permalink)
Best Regards,
Horizon Hobby, LLC
Brian Bremer
Could you mistakenly ship one to my address?
yakky likes this.
Old 02-02-2018, 08:53 PM   #10 (permalink)
The Fusion 270 only has Agility and SAFE Panic Recovery, no dedicated stability mode. The SAFE Panic Recovery is like the 230 S, you still control collective and the negative collective is limited once the model is near level.
Please keep in mind Panic Recovery is like stability mode in that you can still control the cyclic, tail rotor and collective. So after take off if you were to continuously activate panic recovery you would be flying in stability mode.
Panic recovery is activated by pushing the GER channel past 124%, if panic recovery is not activated then the GER channel controls the tail rotor gain.
For those that have a different preference in flight controllers you have a couple of options;
a) The ARF model and purchase your preferred servos separately
b) +$90 more for the BNFB gets you 4 servos and I am sure you could find another purpose for the AR636 (old airplane or maybe prop up the kitchen table).
We tested on the vbar, ar7210bx, Ikon and the AR636A all fly very well. ar7210bx settings are in the manual. KST215MG's fit without issue and perform well. Or you could go for 3x MKS DS95 and 1x MKDS DS95i, its all about what you want to do...
Best Regards,
Brian Bremer
Horizon Hobby, LLC
Chris g., yakky and BrokeDad like this.
Old 02-02-2018, 08:59 PM   #11 (permalink)
Join us for a LIVE Q&A all about the Blade Fusion 270! (22 min 31 sec)
Tom
Blade 230s V2, mCPs, 360 Fusion, Losi 3xl-e and iX12
Nytro97 is online now        Reply With Quote Quick reply to this message
Old 02-02-2018, 09:13 PM   #12 (permalink)
Old 02-03-2018, 07:40 AM   #13 (permalink)
Best Regards,
Brian Bremer
Horizon Hobby, LLC
Can you modify how much it is holding when it is engaged? Like if you have an engaged with a lesser control would you be able to fly and like a stability mode? Or would that just neutralize the ability for it to panic recover? Just trying to understand how it works.
Old 02-03-2018, 10:30 AM   #14 (permalink)
While the ARF looks like a cool option, the value really is there to just get the BNF, KST 215s while great, will add more weight and these days run a bit north of $100, then an FBL is going to be at least $120....
yakky is online now        Reply With Quote Quick reply to this message
Old 02-03-2018, 11:46 AM   #15 (permalink)
Default safe? !!!!
If this heli DOSNT have safe self levelling
why o why does it say it has in the blurb!
Spektrum™ AR636 flight controller
Black anodized aluminum head, swashplate and servo block
Low wear helical main gear
Proven belt-drive tail with aluminum tail boom
45A ESC with built in Governor
New tail case design and larger tail shaft bearings
New canopy design
SAFEŽ Technology self-leveling with Panic Recovery
Optimized servo geometry
Rugged construction utilizing carbon fiber and black anodized aluminum
Efficient 4S 14.8V optimized power system
Spektrum™ high-speed metal geared servos
Top mounted, 2950Kv brushless outrunner motor
Oversized, hardened main shaft with triple ball-bearing support
BLADE you need to quality control your press releases
Old 02-03-2018, 12:40 PM   #16 (permalink)
New canopy design
Because when you select panic recovery switch , the heli does self level ..check out the Fusion 270 Forum for further info ..
Old 02-03-2018, 04:10 PM   #17 (permalink)
surely thats BAIL out not safe
safe to me equals self levelling like the 230s (s for safe)
Old 02-06-2018, 10:50 AM   #18 (permalink)
Definitely not SAFE mode as we know it, just self leveling like the more expensive helicopter models w/ Ikon, Brain, Beast, etc. Still, I will watch & see how this shakes out in the next few months.
FloridaAKM is offline        Reply With Quote Quick reply to this message
Old 03-06-2018, 09:11 PM   #19 (permalink)
Default New tail case
Did I get the part about the new tail case correct? James said the tail case will be universal for other models? I would like the larger bearings on my 360. The new bearings are 4X10X4 I think.
Logo 550SX, Modified Logo 400SE, Forza 450 3S
Lompma is offline        Reply With Quote Quick reply to this message
Old 05-19-2018, 06:11 PM   #20 (permalink)
I have the Fusion 270, it's a good flying heli, lots of power. It flies really stable.
Since I have owned it, I only have two issues to pick at. One, the landing gear is WAY to narrow and the heli really tries to tip over on spool ups, has tipped a couple times costing me time and money. Two, I've noticed a hard cyclic flutter upon a fast descent, not sure why (maybe the tune?)
Other than that I've really enjoyed it so far.
bsamp is offline        Reply With Quote Quick reply to this message
