Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > 270CFX
270CFX Blade 270CFX Helicopters Information and Help
Like Tree4Likes
Old 09-17-2019, 09:20 PM   #21 (permalink)
Default My spektrum program
Hi, I would like to know when I can use the program on my pc for the Fusion 270 AR636a. Spektrum has files for 250, 230, etc., but not the 270.
I would like to check calibration but I canít get into calibration mode without zeroing out the settings. Any ideas?
Vrooooom is offline        Reply With Quote Quick reply to this message
Old 09-18-2019, 02:46 PM   #22 (permalink)
Default Grommets for swash
Has anyone tried the grommet mod on the swash on the 270?
Old 10-17-2019, 01:10 PM   #23 (permalink)
Default Gain value
Originally Posted by brianbremer View Post
The Fusion 270 only has Agility and SAFE Panic Recovery, no dedicated stability mode. The SAFE Panic Recovery is like the 230 S, you still control collective and the negative collective is limited once the model is near level.
Please keep in mind Panic Recovery is like stability mode in that you can still control the cyclic, tail rotor and collective. So after take off if you were to continuously activate panic recovery you would be flying in stability mode.
Panic recovery is activated by pushing the GER channel past 124%, if panic recovery is not activated then the GER channel controls the tail rotor gain.
For those that have a different preference in flight controllers you have a couple of options;
a) The ARF model and purchase your preferred servos separately
b) +$90 more for the BNFB gets you 4 servos and I am sure you could find another purpose for the AR636 (old airplane or maybe prop up the kitchen table).
We tested on the vbar, ar7210bx, Ikon and the AR636A all fly very well. ar7210bx settings are in the manual. KST215MG's fit without issue and perform well. Or you could go for 3x MKS DS95 and 1x MKDS DS95i, its all about what you want to do...
Best Regards,
Brian Bremer
Horizon Hobby, LLC
Hi Brian,
Iím confused about how to set the gain "D" for cyclic. I called tech support and he said 100 default and up to 150, 200, and down to 50, 0.
He said each stroke on my Dx6e will take it up or down 50.
However, when I perform the setting the looks like it moves a little, not 50%.
How much does each click change the value, it looks like if you hold the stick it will continue to move the swash.
Thank you,
Pat
Blade MCPX, MCPS, 230S, Fusion 270, 360 CFX
Old 10-17-2019, 05:37 PM   #24 (permalink)
Right, ist moves just a little because you are doing gain settings in oldscool way. Brian was refering to the new way, the foward programming.
The values for gain settings differ a lot in classic gain settings from foward programming settings. Don't mind, both ways work fine.
My Helis: https://www.helifreak.com/album.php?u=238607
The_Fox is offline        Reply With Quote Quick reply to this message
