Go Back   HeliFreak > R/C Electronics Support > MSH Brain FBL Unit
MSH Brain FBL Unit MSH Brain Support Forum
Old 02-03-2018, 09:12 AM   #1 (permalink)
Default Brain2 Mini with OpenTx
Hi all,
I've done lots of searching and haven't found anything regarding my issue and my work around yet...so I'll throw this out there.
Just picked up a Protos 380 with the Mini Brain2 unit. I'm an OpenTX user with a Horus X10S.
Of course I want to connect my FrSky receiver of choice to the Brain unit using SBus. When I get to the receiver setup screen of the software wizard I naturally select the option for "OpenTX FrSky", however when I get to the Transmitter Setup screen it does not see any of my stick movements.
After trying multiple receivers, multiple cables and different binding scenarios it hit me that I should just try selecting "Futaba S.Bus" on the receiver setup screen...Bingo! Now the Brain software is seeing my stick inputs...
Not sure if this is a bug in the software or if it actually expects something other than S.Bus when using a FrSky receiver but hopefully this post will save some head scratching for anyone else experiencing the same thing.
If anyone has a better work around I'm all ears!
Cheers!
cosmith is offline        Reply With Quote Quick reply to this message
Old 02-03-2018, 09:29 AM   #2 (permalink)
I was using the Futaba Sbus option with no problems for quite some time. The Frsky setup diagram is how you need to do it if you want to use the telemetry options which may or may not be important to someone.
Old Man 3D.......Low and Slow!!!!!
Cromer is offline        Reply With Quote Quick reply to this message
Old 02-03-2018, 10:04 AM   #3 (permalink)
I'm very new to this, but if I understand correctly I won't be able to get mah consumption and rpm passed on to my receiver unless I use the Brain2 in FrSky mode?
In that case, with all the latest software/firmware has anyone got the FrSky mode to work?
Is it possible that FrSky won't work at all without the FrSky integration cable? I assumed that special cable was only for telemetry and that control would be handled through S.Bus. Obviously I don't have that cable yet to try!
Thanks!
Old 02-03-2018, 01:42 PM   #4 (permalink)
Thanks!
In most of my helicopters I use a X4R SB and a current sensor in SBUS mode with the Brain.
In one heli I use a X4R SB with the MSH telemetry cable and a Brain2 in FrSky mode to read the telemetry data from a Hobbywing 130.
Hydros27 is offline        Reply With Quote Quick reply to this message
Old 02-03-2018, 05:21 PM   #5 (permalink)
I think this is the setup I'll be trying.
You're still using the SBUS from the X4R to Ch3 on the Brain? Did you happen to notice if the controls still worked if that special MSH telemetry cable was unplugged?
Thanks!
Old 02-03-2018, 06:21 PM   #6 (permalink)
The SBUS goes through the MSH cable into the SAT1 port. The Smart Port goes to channel 3. I haven't tried it, but I'm pretty sure it won't work with the MSH cable unplugged.
Old 02-03-2018, 10:06 PM   #7 (permalink)
Okay, that makes good sense. Obviously it is expecting control signal through SAT1 not CH3. Cable is on the way!
Old 02-04-2018, 06:53 AM   #8 (permalink)
You need the cable to make FrSky mode work.
Specter v2, Tron Dnamic, Nimbus 550, P380, Edge-TX
JWeber is offline        Reply With Quote Quick reply to this message
Old 02-04-2018, 07:08 AM   #9 (permalink)
Got it. Thanks a lot!
The wizard makes it pretty idiot proof, but for whatever reason when I looked at the wiring diagram I kept seeing SBUS going to channel 3...now I see that it is actually S.Port.
Do any of you use a Hobbywing ESC by any chance? I'm hoping to get mah consumption and rpm without any extra sensors. Starting using mah consumption in my planes this summer, best thing I've ever done for my flight time and lipo health!
Old 02-04-2018, 09:07 AM   #10 (permalink)
I have the Sab 60A on my Fireball which is really a Hobbywing 60A V4 and everything works well however the 60A does not offer mah consumption.
I also have a Gaui X3 with a Castle 50 Edge Lite on my Frsky radio and all the telemetry is working on that also. That ESC does have current consumption and it is working but it appears to be way off calibration at the moment. I have not had good enough weather to fly it to try and dial it in yet but at least it is working.
Old 02-04-2018, 09:52 AM   #11 (permalink)
I am using the Hobbywing 130 with FrSky and Brain2. The RB1C, which is the consumed MAH calculated by the Brain, is spot on. Voltage and temperature telemetry is accurate also. The current reads extremely high as does the consumed MAH calculated by the radio. I have just been ignoring the Taranis current readings and using the Brain RB1C. I don't know why there is such a difference. Anybody have any thoughts?
https://www.helifreak.com/showthread.php?t=797745
Old 05-14-2020, 08:19 PM   #12 (permalink)
Does anyone have an eepe file they would be willing to share. I have a Sab Fireball that I've been trying to set up. I get it to hoover but my settings are a little wacky. Would anyone be willing to look at my setup to see what I'm doing wrong. Currently using Jumper T16 radio.
Thanks,
Tomas
tavila71 is offline        Reply With Quote Quick reply to this message
Old 05-15-2020, 04:56 PM   #13 (permalink)
You can look at oscarliang.com for suggestions on how to get inverted S.Bus signal out of certain FRSky receivers. This will make SBus work from FrSky and allow telemetry as well.
If you're really curious and decent at soldering small things, you can convert an X4R-SB to F.Port and use a single wire. However you need to be on the not latest FrShlky ACCST protocol.
Ivan is offline        Reply With Quote Quick reply to this message
