Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > 270CFX
270CFX Blade 270CFX Helicopters Information and Help
Old 02-04-2018, 05:46 PM   #1 (permalink)
Default 270cfx not flying
I thought I put in all the proper settings as per manual, got bail out but, when I try to lift off it acts like it is throttle hold
sing23 is offline        Reply With Quote Quick reply to this message
Old 02-04-2018, 05:59 PM   #2 (permalink)
Throttle Hold?
As in motor shutdown?
nCPX(3)*mCPX(25)*130X(10)*130X-L(6)*180CFX(3)*300X/CFX(3)
450X(7)*470LP*GauiX3*nanoQX*180QX*DX9*HF180060*AMA 988253
JonJet is online now        Reply With Quote Quick reply to this message
Old 02-04-2018, 09:34 PM   #3 (permalink)
Default 270cfx
The blades and the servos move but heli motor does not start up.
Old 02-04-2018, 09:41 PM   #4 (permalink)
What Tx are you using...
Perhaps the Talon ESC is not seeing zero throttle so the startup cannot occur
Old 02-04-2018, 10:09 PM   #5 (permalink)
Try lowering the throttle trim all the way down. If that fixes it you need to do throttle calibration.
BrokeDad is online now        Reply With Quote Quick reply to this message
Old 02-05-2018, 05:56 AM   #6 (permalink)
Do you hear the tones from the motor?
-Ben
Oxy 2/3/4/5; Specter 700; Kraken; Jeti DS-14/DX9
Old 02-05-2018, 06:09 AM   #7 (permalink)
Default 270cfx
I am using the dx6 v2 and I here the tones for the start up tones. I have my thr. trim all the way down.
Old 02-05-2018, 05:25 PM   #8 (permalink)
So you hear the very first musical part, then a tone for however many cells you are hooked in with, I assume 6, after that do you hear a final tone?
-Ben
Old 02-05-2018, 11:54 PM   #9 (permalink)
270CFX Castle Creations ESC Throttle Programming
1) Radio on - All blades removed or motor disengaged from pinion
2) Throttle Curve 0-25-50-75-100
3) Throttle Travel set to 30 at high and low travel positions
4) Throttle at max position - plug in battery - wait for beeps to verify programming mode
5) Adjust max throttle travel upward to around 100 until ESC beeps
6) Throttle stick to low position - Adjust low throttle travel upward until ESC beeps
7) Exit Travel menu - disconnect battery
8) With throttle stick at low reconnect battery - wait for initialization to complete - signifying the ESC/FBL is ready
Throttle should work just fine now - test at will before re-engaging motor pinion or installing the blades
Lots of vids on YouTube
Old 02-15-2018, 01:00 PM   #10 (permalink)
Default 270cfx
Problem solved, thanks for last post.
