Go Back   HeliFreak > R/C Helicopter Support > Compass Helicopters > eXo
Old 02-12-2018, 02:35 PM   #1 (permalink)
Default Linkage Length and other Questions :)
I'm hoping this is my last question set.
I set my servo-to-swash links to ~82.5mm and the flybarless links to ~39mm.
I've got a couple degrees of positive pitch at mid stick (servo horns centered on KST servos). Which links should I shorten? I'm guessing I'm gonna need 4-5 turns.
If I shorten the servo-to-swash links, the swash will drop. If I shorten the flybarless links, the swash will stay where it is (relative to the mainshaft.)
Also, what are you guys running for timing/pwm settings on the hobbywing 100/rage motor?
The specs I've found say 18 degrees 10khz. I can run 8,16,24,or 32khz.
Lastly, max headspeed? She's gonna fly soon...
Thanks guys.
Current Fleet--Goblin 770 Comp, Trex 700L, Compass EXO, Goblin 420, Oxy 3 285, All Vbar
Old Friends--Trex 700n, Trex 600n, Gaui X5, Blade 450x, Blade 180cfx, Blade 130x, Blade mcpx, Walkera 4#6
fluxcapacitor121 is online now        Reply With Quote Quick reply to this message
Old 02-12-2018, 10:47 PM   #2 (permalink)
Well I kinda answered my own question.
I only got one complete turn outta the flybarless links. If I try for 2 turns, the plastic on the link bottoms out against the jam nut. I guess all the links will have to be a little shorter. I'm wondering if the kst output shafts sit a little higher than the mks?
Old 02-13-2018, 09:45 AM   #3 (permalink)
If you are following the suggested lengths from the manual those are specific to mks servos. Kst servo shaft position is probably is not the same as mks.
KBDD Team Pilot / Team Rage-RC
Compass Chronos | 7HVU | 550U | Atom 5.5 | Atom 500 | Gaui X3 #1 | X3 #2
cyclo is offline        Reply With Quote Quick reply to this message
Old 02-15-2018, 11:37 AM   #4 (permalink)
I am running JR servos in both of my eXo's, so the lengths will be different there also.
The key thing is not to have the servo to swashplate pushrods so short that the swashplate bottom will not interfere with the top of the frames at the extremes of cyclic throw.
Another important thing is to make sure that the rods are threaded into the links and SZ arms enough to stay in properly.
I can measure the height of the swashplate at zero collective/zero cyclic later today and post that, if it will help. It should give you a good starting point.
Ah Clem is online now        Reply With Quote Quick reply to this message
Old 02-17-2018, 03:18 PM   #5 (permalink)
One turn on the flybarless links and 3 turns on the servo to swash links got her all dialed in. Swash is no where near interfering at all extremes.
For you vbar guys, the 13.5mm mks arms yielded me an 80 setting on collective at 13 degrees, and also 80 on the 8 degree cyclic calibration. 13.5mm is perfect for the tail, giving me right around 100 in both directions.
If you want your cyclic/collective numbers closer to 100, I'd say about 12-12.5mm ball spacing. But, mikado says 80-110 is fine.
The rake on this thing is awesome. I maxed out my leveling table setting up the head with the soko. Had to shim the front...
ID:	737885   Click image for larger version
Old 02-17-2018, 07:26 PM   #6 (permalink)
Come on! Let's see the first flight! I'm getting impatient.
A very cool looking heli. Awesome canopy.
I sold mine though.
Sent from my XT1650 using Tapatalk
Thickfog is offline        Reply With Quote Quick reply to this message
Old 02-17-2018, 07:44 PM   #7 (permalink)
I wish. It's 20 degrees here. Snow on Monday.
She's a little big for an indoor hover...
Old 02-17-2018, 08:05 PM   #8 (permalink)
Dl
Old 02-28-2018, 09:01 PM   #9 (permalink)
Thanks guys.
on my exo that is equipped with KST servos, my ball links are pretty much bottomed out on the rod. Only 1 thread showing. inner measurement between the links is 38.9 mm outer measurement is 82.05mm cant give you the other lengths currently rebuilding the head. hope this helps. my hobbywing 100 amp v3 settings with the rage motor, I am running factory defaults in gov store mode.
KBDD TEAM PILOT/Compass field rep.
Brain fbl
Futaba 8fg/14sg
mike pound is offline        Reply With Quote Quick reply to this message
Human Verification
