Go Back   HeliFreak > R/C Helicopter Support > Goblin 280
Goblin 280 SAB Heli Division - Goblin 280 Helicopters
Old 02-14-2018, 05:23 AM   #1 (permalink)
Default brand new bad tail servo?
so I just started to get things ready for the build and hooked up the tail servo to a 6100 spectrum RX to center and it moved a tiny bit and that is all? The RX is in a plane that all channels of the RX work fine but the SAB servo just holds and it will not move w/stick movement? I hooked up one of the SAB cyclic servos to the same channel and it works fine. (rudder channel). I guess its bad, I wonder why it holds and if you try to move the servo it fights you and hums but will not move.
180 CFX, TREX 150X, SAB 280, TREX 450DFC
hydrojeff is offline        Reply With Quote Quick reply to this message
Old 02-14-2018, 05:46 AM   #2 (permalink)
A dedicated tail servo operates at 760 ms center. It does does work at all connected to a normal servo port.
Hook it up to a FBL, set it up to 760 ms and it will be fine.
ini_ is online now        Reply With Quote Quick reply to this message
Old 02-14-2018, 06:01 AM   #3 (permalink)
yep, sounds like you have a narrow band 760us tail servo
Gob 700 Speed | Gob 770 Comp | Gob 630 Comp | Trex 700X | KDS Agile 7.2 | Compass 7HV U | Trex 600Pro (626 stretch) | Kasama Dune 600 | KDS Chase 360 | Devil 420 | XLPower 520
Grumpy_Old_Man is online now        Reply With Quote Quick reply to this message
Old 02-14-2018, 07:31 AM   #4 (permalink)
I did try it on my ar7200 with the same results. The 7200 is hooked up to a older setup so could that still be why that its not set up for the correct frequency?
Old 02-14-2018, 12:05 PM   #5 (permalink)
Yes, sounds likely.
If the FBL tail is set up to accept a 1520 us servo this SAB tail servo will not work until the FBL setup is changed.
You can test it: if a cyclic servo works in tail then it is about the setup.
Old 02-14-2018, 12:37 PM   #6 (permalink)
sweet,, thank you all very much,, now time to learn to set up the 7200..
Old 02-19-2018, 06:25 AM   #7 (permalink)
yes u guys are great with the correct programming of the 7200 the tail servo IS ALIVE!!!!!
Human Verification
