Go Back   HeliFreak > R/C Helicopter Support > Goblin 280
Goblin 280 SAB Heli Division - Goblin 280 Helicopters
Old 02-20-2018, 10:32 AM   #1 (permalink)
Default Ar7210
Has anybody set up a SAB 280 with ar7210 FLB unit
Ravmano7 is online now        Reply With Quote Quick reply to this message
Old 02-20-2018, 12:32 PM   #2 (permalink)
Did mine for a while with the microbeast. Same thing minus the rx.
Sent from my XT1650 using Tapatalk
Thickfog is online now        Reply With Quote Quick reply to this message
Old 02-20-2018, 02:45 PM   #3 (permalink)
yes
jsbach#1 is online now        Reply With Quote Quick reply to this message
Old 02-20-2018, 05:56 PM   #4 (permalink)
How did you guys set your throttle curves?
Old 02-20-2018, 06:07 PM   #5 (permalink)
Depends. If running the governor on the esc or flybarless unit governor or using flat curves.
I do not know of your AR has an internal governor. I think that one is an older flybar unit. Check the manual.
If no governor on the AR follow your esc manufacturer directions for setup using the esc governor.
Or use flat curves in your tx.
Old 02-20-2018, 06:10 PM   #6 (permalink)
Just checked the AR manual. It has governor.
So follow directions there or your ESC directions or use flat curves and no governor.
Old 02-20-2018, 06:27 PM   #7 (permalink)
Ok. Sounds good.
Old 02-20-2018, 09:10 PM   #8 (permalink)
And check back if, the instructions are no good. Hobbywing are some of the worst instructions out!
Sent from my SHIELD Tablet K1 using Tapatalk
Old 02-21-2018, 02:27 PM   #9 (permalink)
Thanks. How do I set the governor in the ar7210 I just want to get it in the air at 3000 rpm to check things out. And there?s no conversion because of direct drive. This is getting confusing!
Old 02-21-2018, 02:56 PM   #10 (permalink)
To be honest I think the best way is to setup ESC governor. That way it is simpler. And I think that's how SAB expects you to setup.
The Fireball has the HW/SAB 60A ESC. So you need to:
1. Have a fully charged battery
2. Setup the ESC for Gov Store (you need to buy the Hobbywing program box)
3. Setup a linear throttle curve 0-25-50-75-100
4. Spool up on a safe outside spot and let it run at 0 pitch and 50% throttle for a couple of minutes
That's it. You can experiment with different flat throttle curves to find out what headspeed suits you best. Use the reference on the manual (e.g. 85% throttle = 4200 on standard motor).
Goblins: 570 Sport (Big Bird) / 500 Sport (Ghost) / 420 (Panthro) / 380 (Yellowbird) / DX9 BE & DX6 G2 / [Citizen 755]
Team Pilot: SAB USA YouTube: http://tinyurl.com/toadiscoil
toadiscoil is online now        Reply With Quote Quick reply to this message
Old 02-21-2018, 03:00 PM   #11 (permalink)
Thanks! I want to use the governor on the ar7210. How do I set it up for 3000 rpm I just want to puts her around a bit? And there?s no conversion because of the direct drive! This app s getting confusing. Thanks in advance
Old 02-21-2018, 03:04 PM   #12 (permalink)
Sorry about the double post. I really want to set it up on the fbl. I already have the tach lead wired up. And don?t think I want to buy the Hobbywing programer
Old 02-21-2018, 03:41 PM   #13 (permalink)
Now I can't be sure but if that's what you want, you may have to anyways. I can't find the SAB-specific parameters. I know that someone posted here on another thread that and I assumed that came on the manual but don't see it.
My point is that if the ESC is setup from factory to use governor, then it's set to a governor mode (like gov store or gov elf). This means that if you use your FBL gov you will end up with two governors competing with each other which may be a very bad situation.
I would buy the programming box. It's inexpensive enough at least to what we are used to on this hobby.
Old 02-21-2018, 03:45 PM   #14 (permalink)
Also to set the throttle end points on the esc. You power up the copter at full stick wait for some beeps, then go to 0 stick wait for beeps and you?re done. Is this correct? My esc just keeps rapidly beeping.
Thanks guys for all the help!
Old 02-21-2018, 03:56 PM   #15 (permalink)
If I remember correctly on those units, they have to be powered on first. What happens is that they have a feature to ensure there is no throttle until it fully initializes. You have to power the FBL first, then the ESC.
See this:
https://www.horizonhobby.com/pdf/SPM...l_addendum.pdf
Old 02-21-2018, 04:17 PM   #16 (permalink)
I found the post I was looking for.
https://www.helifreak.com/showthread...77#post7535424
The SAB ESC comes factory with Gov Store so the ESC governor on by default. You will need the box to change that if you want to use FBL gov anyways.
Old 02-21-2018, 05:56 PM   #17 (permalink)
Use the hobbywing gov store - it works absolutely mint. You’re wasting your energy.
Old 02-25-2018, 07:07 AM   #18 (permalink)
Ok. So I took the 280 out to a park to run at 50% throttle for a couple minutes this morning. It spools up fine for about 30 seconds then the rpms drop out, raise back up and drop out. Grrrr need help in northern Virginia
Old 02-25-2018, 03:19 PM   #19 (permalink)
Get the Hobbywing programming box. Change your flight mode to airplane and power off then power on and change again to gov store and power off. The next time the ESC is powered on will go into RPM stabilization mode. Full pack 0 pitch and 50% throttle for a minute or so and power off. Done. You should be able to run a flat 80% throttle curve and the governor should kick in.
Old 03-13-2018, 06:31 AM   #20 (permalink)
Haven't been on the site in a while since buying a house and moving. I'm in NorVA. I can let you use a program box and help with your setup if you like. May be a little while before I dig out my heli stuff and get me back to flying again. Send me a PM if interested.
-Ben
Oxy 2/3/4; P380; Logo 700 project starting soon; DX9
Lynx Heli Innovations Field Rep
jrman83 is online now        Reply With Quote Quick reply to this message
Human Verification
