Go Back   HeliFreak > R/C Helicopter Support > Goblin 280
Goblin 280 SAB Heli Division - Goblin 280 Helicopters
Old 02-25-2018, 07:02 PM   #1 (permalink)
Default New Fireball Tail Wag and how I fixed it
Hey guys just got my fireball combo up and flying. Using the SAB servos and a Spartan vortex Pico. I was having a lot of trouble with tail gain and fast wagging. My tail shaft pitch slider is buttery smooth so after going crazy all day I went into advanced tuning and went into PID tuning for the tail. The D gain was at zero so I adjusted this value to 20. All of my tail oscillations and fast wagging were gone! Just seeing if anyone else had this problem?
TipSpeed is offline        Reply With Quote Quick reply to this message
Old 02-28-2018, 07:09 AM   #2 (permalink)
That does seem to be helping in my neo as well. Beastx v5 and ikon2 were no wag for me.
jsbach#1 is online now        Reply With Quote Quick reply to this message
Old 02-28-2018, 03:07 PM   #3 (permalink)
I had 2 fireballs both combo kits. both silky smooth and built perfect, and both had the same tail wag. both helis using v bar neo and one using mini v bar.
so the fireball with the mini v bar in it i tried all the setting i could and it did nothing the only thing that cured the tail wag was getting rid of the SAB tail servo and fitting an align one instead and its perfect now
the other fireball i stripped and sold the airframe and put all the gear minis the motor in to a Lynx oxy 3 and it worked.
jayfrs is offline        Reply With Quote Quick reply to this message
Old 03-01-2018, 07:15 PM   #4 (permalink)
I also heard that getting rid of the SAB Servo solved the problem. So far so good. Still need to take it out and really beat on it to see how it is.
Old 03-02-2018, 04:34 AM   #5 (permalink)
SAB tail servo is working great on one my Fireballs
Synergy 766 12s/ 766 14s / Synergy N7 / Align 700X/700XN
Black Thunder 700T / Black Nitro 700x2 / 2x Fireball Comp
SAB Mini Comets/Synergy 516x2 /SAB 500 Sport /GUAI X7FZ.
Vcontrol/Neo
Locktite is offline        Reply With Quote Quick reply to this message
Old 03-02-2018, 05:42 AM   #6 (permalink)
SAB tail servo with 18T upgraded pulley on mine. No tailwag at all (with mini Brain2)
floriske.nl is offline        Reply With Quote Quick reply to this message
Old 03-28-2018, 02:21 PM   #7 (permalink)
I have some bad fast tail wagging on my mini comet. In forward flight it is barely noticeable, but if I increase pitch rapidly, it shakes so much you can hear it. No matter how I adjust the gyro gain (which is at 39 on an ikon), I can't get rid of it. Mechanics are super smooth and I have a completely upgraded tail with metal parts.
I have a SAB tail servo, and am thinking of moving out a hole on the ball to get more resolution. I will also try adjusting the PID to see if that helps.
Any other tips for me would be useful.
Mini Comet, SAB Goblin 380, SAB Goblin 500, Logo 550SE, Invertix 400, DJI Spark
Brain/IKON and Jeti: Making RC Great Again!
echopoint is offline        Reply With Quote Quick reply to this message
Old 04-08-2018, 08:01 PM   #8 (permalink)
I'm running a AR7210 with V5 PRO and had some fast tail wag on my maiden flight.
What settings were you running?
Art Henk is offline        Reply With Quote Quick reply to this message
Old 04-12-2018, 02:32 PM   #9 (permalink)
I have same setup. Where did you end up with your tail gain and what headspeeds you running?
I'm running 3800 as my high headspeed and find that plenty fast enough for me.
I have also fitted the speed up pully.
I have my tail gain down to 15, and added precomp until any drift in full pitch punch outs was gone.
If I have gain any higher I get a lot of wag in a hover.
I have only had 2 flights since change the tail pulley, and hope to get more fights at the weekend
Citizen 584
Raptor E700, scorpion, helijive, BD 3sx. Trex 700N BD 3x, Trex 550 helijive BD 3x. Gaui X3, scorpion, hobbywing, BD 3x. Blade 300cfx BD 3x base
raptor90wm is online now        Reply With Quote Quick reply to this message
Old 04-13-2018, 05:17 PM   #10 (permalink)
Just an update… I am using a mini brain 2. I moved my ball out on the tail servo to 10 mm, reduced my pitch precompensation to nearly zero in the advance settings. That fixed the issues with pitch pumps. I still have very fast wagging in hover. I guess next step is to lower i gain? Any suggestions on what to try?
Old 04-19-2018, 05:03 PM   #11 (permalink)
Just attempted the maiden hover with my Mini Comet. I'm using a BK tail servo and Spartan VX1e gyro with default settings. I have a bad tail wag, medium speed high deflection, at the default tail gain setting of 17. I dropped gain to the minimum (10) and no change. I increased tail gain to 40 and while the deflection dropped, the wag speed increased. As someone else did, I tried increasing the D gain from zero to 20 and it had no impact. The distance from the tail servo output shaft to the ball link is as specified in the builder's manual. At this point, I'm out of ideas so I did send an email to BK asking for suggestions.
Mike
Protos Evo : Goblin 700C : Trex 700E V2 : Goblin 570 : Gaui X5 Formula : Goblin 380 : Mini Comet : Trex 250 : Oxy 2 : Futaba 8FGH : Jeti DS-16 : Jeti DS24 : Kontronik Kosmik and Jive Pro: Spartan VX1e and Pico: MSH Brain 2 : BK Brushless : Xpert R1
MKMAERO is offline        Reply With Quote Quick reply to this message
Old 04-19-2018, 06:17 PM   #12 (permalink)
Make sure your tail is silky smooth.. I polished the tail tub spindle shaft and tail rotor shaft..Also adding the aluminum tail grips helped with tail wag.. I am using dry fluid on the tail thrust bearings instead of grease.. make sure the thrust bearings are installed correctly on each grip
Vcontrol/Neo
Old 04-20-2018, 05:46 PM   #13 (permalink)
I'm using a BK tail servo as well. I have the metal tail upgrades. My tail is mechanically smooth, but the ball links seem a little tight. I will try to make sure those are loose as well and will post if I find a solution.
Old 07-16-2018, 06:10 PM   #14 (permalink)
I am happy to report that after loosening the ball links, it flies better with very little wag. It's not perfect, but way better than before.
Human Verification
