Go Back   HeliFreak > R/C Helicopter Support > Turbine Helicopters
Turbine Helicopters Turbine R/C Helicopters
Old 03-02-2018, 11:48 AM   #1 (permalink)
Default Wren 44i max amperage draw?
What would be the max battery amperage draw for a Wren 44i during engine start? The Xicoy manual indicates the FADEC generally tries to keep the current below 12 amps during the start-up sequence. But due to the relatively small size of the Wren 44i, I was wondering if it perhaps uses even less max amperage.
The reason I ask is that I use Jeti, and was considering using their DPS 40 double pole electronic switch for the engine/FADEC and FBL/Servo Lipo packs (Jeti Electronic Switch Dual with Magnetic Key DPS 40). Each pole of of that switch handles 10 amp continuous and 20 amp burst. Would a 10 amp continuous / 20 amp max switch circuit on one of those poles be adequate for the engine/FADEC/pump side?
mlmflip is offline        Reply With Quote Quick reply to this message
Old 03-03-2018, 01:21 PM   #2 (permalink)
No idea on current draw, but a simple way to determine that would be to wire up a shunt in a harness, plug that in between the motor and the ECU and put a meter on it during a start sequence. 20A shunts are available on Ebay for $3-4.
-Kevin
Skiddz is online now        Reply With Quote Quick reply to this message
Old 03-03-2018, 08:27 PM   #3 (permalink)
Good idea. Thank you sir!
Old 03-04-2018, 12:52 AM   #4 (permalink)
Please post your results if you do the shunt thing. You got me curious.
-Kevin
Old 03-04-2018, 01:39 PM   #5 (permalink)
Well, that could be awhile. I haven't even ordered the turbine yet. I've just been reading the Wren and Xicoy manuals on line and planning for my build. I'm just asking questions now that will help determine my eventual set up and what accessories I need to purchase.
Old 03-04-2018, 02:14 PM   #6 (permalink)
Hi.
Check this story : https://www.helifreak.com/showthread.php?t=684494
I think that you will not have any issue using this Jeti switch.
At the end, Dennis Ferrari checked consumption : a quick spike to 5/6A at the very beginning and then around 3.5A while spinning at regime speed..
Its something very normal to me.. but i could take a measurement too.. i will let you know when i have it.
Dennis
Blackout_Mods is online now        Reply With Quote Quick reply to this message
Old 03-05-2018, 08:32 AM   #7 (permalink)
Wow, Dennis. Good find! Thank you. Yes, the Jeti DPS-40 switch looks like it would work perfectly amperage wise. Would there be a good spot for the switch on your new conversion frame?
Old 03-05-2018, 09:31 AM   #8 (permalink)
As long the T700XZ Turbine Conversion will be produced on demand, we can do any customizations we want..
No worries..
Dennis
