Go Back   HeliFreak > R/C Helicopter Support > MSH Protos > MSH Protos 700/800
MSH Protos 700/800 MSH Protos 700/800 Helicopter Support Forum
Like Tree2Likes
  • 1 Post By pctomlin
  • 1 Post By jsbach#1
Old 03-23-2018, 11:08 PM   #1 (permalink)
Default Did I just lose Signal?
So I was just about to (hopefully) get the blade tracking sorted and was just going to do a quick test hover in my test area. Had run 4-5 previous test flights usually <2 mins.
As I was spooling up 37 secs after initialisation, I get a phone call. Spool down, attend to call. Restart at 106 secs, take off and 6 secs later, heli loses power and crash. Not too much damage, I was only less than 2m off the ground, but it took out the tail blades and plastic bits of the tail assembly.
Back home I look at the logs, Events extract and Log attached. The only thing I can see is that both Sats lost signal 6 secs in. Can anybody suggest any other reason for the crash?
TIA,
Paolo
2 x ALIGN 550Ls (1xU/S), Prôtos MAX V2 Leggero 700 and an Evoluzione 800 (RCHN #803 - joined just before they shut up shop!)
PaoloFCantoni is offline        Reply With Quote Quick reply to this message
Old 03-24-2018, 12:10 AM   #2 (permalink)
Could be the TX as well. Either way signal was lost.
MSH USA
Short replies are friendly replies.
Old 03-24-2018, 03:44 AM   #3 (permalink)
Originally Posted by OnTheSnap View Post
Could be the TX as well. Either way, signal was lost.
Thanks, while I was setting up one of the Sats behaved a bit odd but it only happened once. I'll run more checks and I can swap the Sat.
Paolo
Old 03-24-2018, 09:00 AM   #4 (permalink)
Don't forget about the sat wires, these are typically the issue when having signal issues.
Michaelinpr likes this.
Paul
Agile 5.5 - Q 4125-1100, YEP 120, Brain2 HD FBL / Outrage 550 - HK4020-1390, Edge 120, Brain2 HD
Rave Ballistic FSO - Q 4530-500, Edge 160HV, Brain2 HD / Protos Max V2 - MSH 4530-500, Edge 160HV, Brain2 HD
pctomlin is online now        Reply With Quote Quick reply to this message
Old 03-24-2018, 03:32 PM   #5 (permalink)
But two at the same time is rather unlikely, if there was signal from both Sats before the failure. TX is more likely. Paolo, hope you get your stuff sorted.
Michael
Diabolo 600, Prôtos 380; Oxy 3 Tareq Edition 2018; 230S Night
mulchi is offline        Reply With Quote Quick reply to this message
Old 03-24-2018, 05:08 PM   #6 (permalink)
What about this more popular now than before occurrence where the battery rx pack or bec is zonked out momentarily by a back emf or something from the servo (servos). We were able to demonstrate it on the bench at our club with a heli that would lose power and then all control and motor would come back online in a few seconds. We installed a capacitor and problem goes away on the bench. I think it was a spektrum badged part spm1600 part number or something like that very cheap, I will put one on any heli that has suspicious servos.
One time it happened WITHOUT pumping the servos the collective stick was just pushed a hair and it reset. Other times no, its hit and miss.
I saw IRCHA reposted Scorpions warning about this on facebook.
Andrew166 likes this.
jsbach#1 is online now        Reply With Quote Quick reply to this message
Old 03-25-2018, 06:17 AM   #7 (permalink)
Default Factory Reset to the Rescue!
Thanks for all the feedback and concerns, guys.
I have made some progress. I switched the suspect Sat, but the problem was still there. Attached are the Event file and Log for an on the bench NO blades test. You can see the motor starting up then stopping, over three cycles before I switched it off. You can also see the very anomalous Events file. The Sat also seemed to go in to "bind" type flashing during the speed reset.
This was actually reproducible - always good when trying to analyse a problem?
On the basis of this reproducible, situation, I decided to do a factory reset on the Brain 2 unit and reload the "last good configuration" (as the Windows startup says... ). The problem seems to have gone away. I offer the Events and logs for Flight 18 where I ran the heli for over 90 secs at full speed (bladeless).
I do have a question. Based on the fact that the reset seems to have fixed the problem, should I also reload the current firmware or can I rely on the startup self-tests?
Also, as a side issue, I timed the Flight 18 run with my phone and I ran for 90 secs after the motor had reached full speed, but the log and event files seem to show less time than that. Can anyone explain or seen this themselves?
Thanks, again,
Paolo
File Type: csv 2018-03-24 Flt 13 (Bench Test No blades).csv (59.6 KB, 5 views)
File Type: csv 2018-03-24 Flt 18 (Bench Test No blades).csv (145.4 KB, 3 views)
File Type: csv 2018-03-25 Flt18 Events.csv (353 Bytes, 4 views)
