18SZ/ R7003 link trouble ? - HeliFreak
Old 04-14-2018, 10:17 AM   #1 (permalink)
Default 18SZ/ R7003 link trouble ?
I have to "copy" and move my "model"s around sometimes (internal -to-SD card, and vice versa) to get it to bind to R7003SB--
any ideas? anyone have trouble besides me?
zr1100 is offline        Reply With Quote Quick reply to this message
Old 04-14-2018, 01:02 PM   #2 (permalink)
I think is had to rebind when I copied some models. Mainly needs to be the proper type. 7ch 14/ 18 etc.
Steve
smittylube is online now        Reply With Quote Quick reply to this message
Old 04-14-2018, 05:23 PM   #3 (permalink)
Can you explain this case a bit more?
Robert "Full" Montee | Team Futaba | Team Synergy | Team Kontronik USA | Team Ninja | Citizen 13 | TellARotor RC Podcast
Full Montee is online now        Reply With Quote Quick reply to this message
Old 04-14-2018, 08:22 PM   #4 (permalink)
On 1 heli the r7003 just fails to bind (red light) a lot of the time--if I use a different copy of the same model setup (in the 18SZ--ie. make another
copy, either on internal or SD disk)--sometimes it works after I do that and re-try. Then on subsequent start-ups it's hit-or-miss, usually miss--and go through the "making copies" procedure again.
P.S. I do have another heli with an R7003 that seems to bind consistently--no problem
Old 04-15-2018, 09:21 PM   #5 (permalink)
CHC Benefactor
I would make sure you read both the T18SZ and R7003SB manuals. I've found the combination of Tx and Rx can vary the binding procedure. So far I had some some trouble in the beginning when I switched Tx's and after reading the manuals I got it sorted. I can't remember the exact issue but it may have related to copying models. Never had to copy a model to solve binding though. Just set the correct channels as mentioned earlier and do a rebind. Then all should be good after that. This combination is my go to setup for almost all my helis.
Raptorapture is online now        Reply With Quote Quick reply to this message
Old 04-17-2018, 08:33 AM   #6 (permalink)
Disconnect your RX from any other Unit
Make sure you are in the Fassetest 18Channel Mode when binding the 7003SB.
Using a 2S Battery pack with a switch ( if you have available) Turn on TX to Linkage Screen > Select 18Channel Mode> Turn on power to RX> Hit Link Button. It should bind and give you a RX ID Number.
You should never have to copy or switch back & forth to get the RX to bind. If so you may have a faulty RX or Connection wiring.
You may also be in the wrong mode on the RX and need to change it by following the Instruction Sheet settings procedure.
Protos Max V2/ Brain2, Align 700X w Brain2 , Mikado 550SEV-2 w/Brain2 ,Oxy 2/Micro Brain2 all with Futaba 18SZH!
BigEddie is offline        Reply With Quote Quick reply to this message
Old 04-20-2018, 08:56 PM   #7 (permalink)
OK--will try--I believe I was in 12ch mode
Human Verification
