Go Back   HeliFreak > R/C Electronics Support > MSH Brain FBL Unit
MSH Brain FBL Unit MSH Brain Support Forum
Like Tree8Likes
Old 05-13-2018, 05:04 PM   #21 (permalink)
Originally Posted by Thickfog View Post
Hey Toad, on Tapatalk just touch the check mark in the upper right.
Thanks!
toadiscoil is offline        Reply With Quote Quick reply to this message
Old 05-13-2018, 07:01 PM   #22 (permalink)
Originally Posted by Pygmaeus View Post
Subscribed!
What i did notice on your 700 flight is that your throttle input signal dropped at the same time which would cause you to loose power. Is this the same problem that was reported before?
I think yes..
Originally Posted by Crashalotjoe View Post
Maybe it is related to the ESC telemetry.
Maybe
Now I disable the ESC telemetry in the G420.. but can't test the change until the next weekend
Align 800e PRO DFC // KRAKEN Yellow // RAW Nitro // Align 700N DFC // RAW Yellow // 2x Goblin 420 // RAW 420 // RealFlight 7.5 // neXt // AccuRc // Tribunus - Vbar Control Touch - Vbar Neo
msallua is offline        Reply With Quote Quick reply to this message
Old 05-14-2018, 07:34 AM   #23 (permalink)
BrainDev,
If you check my signature you will notice that I have 2x Goblin 420 ... In my house I took the second G420 and the same thing happens to me in the workbench
You may notice the "ESC Power Output" dropout approx. in the seconds:
1) 163,10
2) 203.22
3) 229.50
4) 288.22
These 3 helicopters worked perfect with version 3.1.027 and Telemetry ON
Attachment CSV and Attachment MTR, of the second G420
I have already prepared the first G420 and the G700 without telemetry to test the next weekend .. For work reasons it is impossible to try them before.
Old 05-14-2018, 08:53 PM   #24 (permalink)
Are all the CC's updated? When you look at the actual Throttle out, there's no drop.
Agile 5.5, Logo 550sx, X5, Goblin 500, Oxy 3, Trex 450proV2, 250DFC #309
nflanagin is online now        Reply With Quote Quick reply to this message
Old 05-14-2018, 09:13 PM   #25 (permalink)
yes, it's a telemetry problem
Old 05-15-2018, 03:52 AM   #26 (permalink)
Default ESC DropOut on my mini Brains 2 FW 3.2.010
I had no issue on FW 3.2 but met ESC Dropout issue 7~8 times after update to 3.2.101 and caused 4 times crash.
Logs capture attached.
Any idea about this issue on FW 3.2.101, it should be fixed....tight?
I am using Hobbywing Gov. Spektrum Satellite, No telemitry.
thanks
ID:	745744   Click image for larger version
ID:	745745   Click image for larger version
yrjou is offline        Reply With Quote Quick reply to this message
Old 05-15-2018, 07:06 AM   #27 (permalink)
thanks
This is a real fail safe.
And corresponds to a shot in which the frame rate rises indicating the loss of one or more signal frames.
Please check the wires of your satellite and eventually substitute it with a new cable.
You can try on bench to move the sat wire and check.
How many sat do you have? One or two?
Can you send your event file?
www.msh-electronics.com
BrainDev is offline        Reply With Quote Quick reply to this message
Old 05-15-2018, 10:49 AM   #28 (permalink)
Hi Brain,
Thanks for your quick replied.
Here is the log attached.
Old 05-15-2018, 12:02 PM   #29 (permalink)
Hi Brain,
As BrainDev noted you have failsafe and receiver failures all over the event log. Looks like a bad receiver or connection.
OnTheSnap is offline        Reply With Quote Quick reply to this message
Old 05-15-2018, 09:59 PM   #30 (permalink)
Thanks all,
I will check my sat wire connection.
BTW, any concern if I only use one sat on my mini Brain2?
thanks
Old 05-15-2018, 10:23 PM   #31 (permalink)
Thanks all,
thanks
Personally I would fly with 2 sats to minimize any rf shadowing and provide redundancy.
Old 05-16-2018, 10:57 AM   #32 (permalink)
I had this problem of cutting the ESC using a Brain1 on a Trex450 with two spektrum dsm2 satellites without telemetry. This is unfortunate and could not occur after a firmware/softwarr upgrade of a reputable brand.
Enviado de meu SM-J500M usando o Tapatalk
eliasnjr is offline        Reply With Quote Quick reply to this message
Old 05-19-2018, 01:24 PM   #33 (permalink)
Updated manually to 3.2.010... , in the bench it's all OK now.
Going to the field in this moment to test IRL.
I give you my feedback later
fingers crossed!!
Old 05-19-2018, 01:45 PM   #34 (permalink)
Confusing statement.
Updates are always automatic. New feature allows update to be cancelled, but still automatic when it occurs.
If you updated ~to~ 3.2.010 then you're coming from the previous version which was known to have the throttle bug.
Not trying to give you a hard time, just seeking clarification.
Krager is offline        Reply With Quote Quick reply to this message
Old 05-19-2018, 05:16 PM   #35 (permalink)
@BrainDev
Following your recommendation, update the 3.2.010 firmware manually.
1)Goblin 420
First the good news of the Goblin 420, no dropout, no tailtwitch, no engine cutoff
I flew the G420 3 times and got 3 solid flights without problems, perfect.
Align 700e (two flights)
In the first flight .Good news.
No Esc dropout, no tailtwitch, no motor cutoff. It was a sports flight.
Now the BAD NEWS
In the second flight hard 3D flight, I did not have ESC Dropout, no tailtwitch.
BUT!. I had an motor cut-off .. land without problems because I master the autorotation (this issue was reported by other pilots)
I attached the Castle log, the flight number 5 of the castle was without problems, the flight 6 of the castle was in which I had the motor cut-off
I attached the Brain log. that was perfect and I attached the Brain log where I had the motor cut-off
I also attach the .MTR, EVENTS
Hope it helps to solve the problem
Thanks in advance
Old 05-19-2018, 10:53 PM   #36 (permalink)
@BrainDev
Now the BAD NEWS
Thanks in advance
If I'm reading this correctly, the Castle log is showing a throttle cut and is responding correctly but the Brain log is showing the throttle out increasing while it is trying to maintain head speed. It would seem that both devices are working correctly but there is a disconnect between the Brain and the ESC.
Mark
So many things to fly, so little time.
Crashalotjoe is offline        Reply With Quote Quick reply to this message
Old 05-20-2018, 07:03 AM   #37 (permalink)
Today, several flights after last crash due to FW bug, the same thing happened again! The heli being again relatively close to me (sat antennas in clear sight), at ~3mtr/9feet hight the motor shut down. Again I just half flipped it backwards! I’m not sure if the motor signal was the only signal that got lost.
Frustrating!!!
Brain1v2/HWplatinum v4/SpektrumDX8 & 2x dsmx sat/FW 3.2.010
Helihabit is online now        Reply With Quote Quick reply to this message
Old 05-20-2018, 09:15 AM   #38 (permalink)
I opened up my TX and saw the connector of the antenna hanging loose. And then remembering the antenna got hit last time
I am 'glad' it hasn't got anything to do with the Brain
besides the one in my head
Goosky S1 Brainless, 180CFX Lynx motor, Trex450se fbl, Trex500 fbl ,6HV fbl..XLPower520,..all with Brains
Old 05-20-2018, 10:43 AM   #39 (permalink)
Frustrating!!!
This theread is only related to the Futaba S.Bus protocol and only when used with ESC Castle Creation that have the Live Link protocol active.
From the signature it does not seem to me that the radio used is Futaba but Spektrum.
As far as I know and as reported by all users the problems of all other protocols with all types of ESC have been definitively solved with firmware 3.2.010
Unihiron likes this.
Old 05-20-2018, 10:44 AM   #40 (permalink)
Okay, I read only now. Happy that you have found the real cause of the problem. In any case, I recommend you to manually reloading the latest firmware.
