Go Back   HeliFreak > R/C Helicopter Support > Gasser Helicopters
Gasser Helicopters Gasser Specific Discussion
Like Tree15Likes
Old 06-23-2018, 05:46 AM   #1 (permalink)
Default Flybarless Unit for Goblin Gasser
Hi, I'm needing a flybarless unit for the Goblin gasser I recently bought. I use a Jeti tx and integration would be nice but not a must. I have 2 Ikon 2's now but am concerned about the software/ firmware issues. But all brands might be having the same issues as well.
Any suggestions would be appreciated.
Thanks, Bill.
bclark is offline        Reply With Quote Quick reply to this message
Old 06-23-2018, 06:24 AM   #2 (permalink)
If you know the Ikon's stick with them.
They work very well on a gasser.
Tom
TRM Power
CAUTION - my posts are based on my experiences, yours may be different.
fastflyer20 is offline        Reply With Quote Quick reply to this message
Old 06-23-2018, 10:04 AM   #3 (permalink)
The Brain/iKon FBL is all I use. I see no reason to lose confidence in MSH, BrainDev and Alex are on top of it and they don't hide it. My opinion, a lot of issues are us when you look at final outcome of the problem.
The HD version is great for a gasser setup.
Calil likes this.
Paul
Agile 5.5 - Q 4125-1100, YEP 120, Brain2 HD FBL / Outrage 550 - HK4020-1390, Edge 120, Brain2 HD
Rave Ballistic FSO - Q 4530-500, Edge 160HV, Brain2 HD / Protos Max V2 - MSH 4530-500, Edge 160HV, Brain2 HD
pctomlin is offline        Reply With Quote Quick reply to this message
Old 06-23-2018, 11:50 AM   #4 (permalink)
Thanks guys. I will go with the Ikon.
And yes I agree, some of the problems are self inflicted! Computers and I don't get along too well!
Why the HD version?
Old 06-23-2018, 11:58 AM   #5 (permalink)
HD gives you a better pathway to get the power through to your servos.
Thats the best way to think about that I could think of.
Heavy Duty for larger current draw
See attached photo
Kandace
Goblin 700 Gas conversion w/ TRM 300SE, MA 1005 w/ TRM 260VX, Synergy N5c, Synergy E5.
Team TRM
Team Synergy
Hovergirl01 is offline        Reply With Quote Quick reply to this message
Old 06-23-2018, 03:32 PM   #6 (permalink)
The HD vesion makes it easy to power the heli direct with a 2S LiPo and the on/off switch makes it handy powering on the heli when ready to fly.
Paul
Old 06-23-2018, 05:25 PM   #7 (permalink)
Ok thanks. I`ll give the HD a try.
Old 06-27-2018, 07:34 PM   #8 (permalink)
Default Mounting tape
I've standardized on the Ikon 2 on all my other (electric) helis but am still running the BD 3SX on my Goblin Gasser. I'm likely going to go to the Ikon 2 HD on that as well for i) the logging, ii) more familiarity with it. iii) potential to use it's governor iv) HD option.
1) What do folks that use this FBL use for mounting tape? Is the 3D 4010 the correct option or do I need to use something else? Sounds like rescue is still problematic but perhaps there's a choice of mounting tape that'll help this. Note that I already use Doug Darby's mount.
2) I'm currently using the Futaba 701 for it's governor but sounds like the Ikon 2 has this covered. Are there comprehensive instructions on how to set that up properly with a gasser?
Thanks in advance.
-Tom
XK K110(s), Align 150X, Align 500XT, Align 550E/DFC, Goblin 280, Goblin 500 Sport, Leviathan Goblin 700 TRM gasser --- FrSky/OpenTX controlled.
Oh, and GO HOGS!
tvoth3 is offline        Reply With Quote Quick reply to this message
Old 06-27-2018, 08:09 PM   #9 (permalink)
I use the 3m tape, but have not enabled rescue.
I still use the gy701, I have not tried the latest brain gov updates. The brain gov last summer did not work as well as the GY701. Since mine is on Jeti, the throttle and gov bypass the brain and connect to the Jeti rx.
Tom
TRM Power
Old 06-27-2018, 09:02 PM   #10 (permalink)
I like the Futaba gyro pads for mounting Brain/iKon FBL units. I use to use the 3M gray tape, but found the Futaba pads to be much better.
Paul
Old 06-27-2018, 10:30 PM   #11 (permalink)
If you're planning to use an Ikon / Brain on a Goblin, the Doug Darby mounting plate is a must, IMHO :
https://www.helifreak.com/showthread.php?t=741324
Doug Darby likes this.
Dawiev is offline        Reply With Quote Quick reply to this message
Old 06-28-2018, 04:31 AM   #12 (permalink)
The Brain HD is great for gassers with the nice power bus setup. It flies well, and the governor works well with some tuning. I was never able to get rescue to be reliable with it, it would be great one day and not the next. 3m, Futaba tape, Milton Mod, nothing made it 100%. Milton was close, it was roughly 99%, but then there was the inherent compromise of an essentially soft mounted gyro and it not feeling exactly right in the air. That was all with the Darby plate in my Goblin gas. Eventually I just bailed on Brain and put a Neo in, but the Brain on Futaba tape was pretty great as long as rescue isnít a priority.
Eury is offline        Reply With Quote Quick reply to this message
Old 06-28-2018, 03:15 PM   #13 (permalink)
We tried something new and I CNCed the lower half of the NEO replacement case right into the Goblin FBL mount. Kyle tested it for me in Virginia and we were saw a 45% reduction in the amplitude of the vibration while in a hover as compared to a NEO with a Lynx case, and we saw a 2.5% reduction in the vibration amplitude for the full flight were he beat the living tar out of it. The nice thing is it is always perfectly straight and you never have to worry about your tape. It appears that with the NEO the mikado tape was only designed to hold it in place as without any tape in this combo mount there was less vibration...
Name:	NEO FBL 1.jpg
ID:	749509   Click image for larger version
Name:	NEO FBL 7.jpg
ID:	749510   Click image for larger version
ID:	749511   Click image for larger version
Name:	NEO FBL 5.jpg
ID:	749512   Click image for larger version
Name:	NEO FBL 6.jpg
Name:	NEO FLB 2.jpg
ID:	749514   Click image for larger version
brw0513, Eury and scssniper74 like this.
doug
TRM Power - RC Racing Engines - - VP Racing / Powermaster Fuels
Aero Hobbies - Lewisville, TX (972) 420-1414
Doug Darby is offline        Reply With Quote Quick reply to this message
Old 06-28-2018, 05:08 PM   #14 (permalink)
That is pretty cool. Now if I only flew a Neo ☹️
Kandace
Team TRM
Team Synergy
Old 06-28-2018, 05:27 PM   #15 (permalink)
That is cool. How about something like that for the ikon?
Oh, and GO HOGS!
Old 06-28-2018, 05:29 PM   #16 (permalink)
Kandace... I can show you how to fix that!!! LOL
doug
Old 06-28-2018, 07:42 PM   #17 (permalink)
You make me wish I wasn't sick of looking at Goblins, Doug.
Nick Crego
#0168
Old 06-28-2018, 09:15 PM   #18 (permalink)
I fly a Goblin with a Neo, yet I have only seen pictures of the Darby case. I am thinking it is a photoshop picture and they really donít exist
Tom
TRM Power
Old 06-28-2018, 10:57 PM   #19 (permalink)
Ikon 2 HD all the way!! futaba tape
And I use rescue feature without any issues on my goblin Gasser
For gov I have the Align sensor inside the fan casing of the motor with the gov sensor mount from Gas Powered Helis
Rahulgaba is online now        Reply With Quote Quick reply to this message
Old 06-28-2018, 11:25 PM   #20 (permalink)
Iíd like to get one Doug. Are they available for sale?
Iíve been looking for an excuse to try a Neo
Kandace
scssniper74 likes this.
Team TRM
Team Synergy
Human Verification
