Like Tree4Likes
Old 06-24-2018, 06:31 AM   #1 (permalink)
Default Logo 550 tail wag in hover FIXED!!!
I've had the new Logo 550 for the past year and frankly I haven't been happy with it. The tail has consistently wagged during hover and what ever I tried could not get rid of it. A few HF and FB flyers guided me to file the plastic ball ends on the grips (which helped slightly), shimming out slop, and moving the washers and bearings around to ensure they didn't bind but still I had the dreaded tail wag in hover. Nothing worked and I was getting ready to bin the heli.
A few flyers recommended I try the "QuickUK" alloy tail upgrade, which I installed and took for a maiden flight this weekend and surprise, surprise the tail wag is completely GONE. Shout out to anyone battling the same tail wag that I was having that I highly recommend the QuickUK tail upgrade. It will resolve the problem instantly plus it looks a lot better than those cheap looking plastic grips.
I've spoken to nearly 10 people now who have experienced this tail wag issue so its a common problem. I wish Mikado had this right from the beginning because it would have saved a lot of stress and bother.
GO QuickUK
I'm loving my Logo now
smyster is offline        Reply With Quote Quick reply to this message
Old 06-24-2018, 03:04 PM   #2 (permalink)
IIRC there has been some mention of faulty thrust bearings. Some mismatch of the cage or race maybe?
But I agree a good tail is gold.
For best long term results I always suggest remove the mains and tail control rod and dynamically balance the tail at the speeds you fly.
Steve
smittylube is offline        Reply With Quote Quick reply to this message
Old 06-24-2018, 04:08 PM   #3 (permalink)
Yeah. I thought some used msh thrust bearings and races and solved it. Can't find the posts.
Thickfog is offline        Reply With Quote Quick reply to this message
Old 06-24-2018, 07:28 PM   #4 (permalink)
GO QuickUK
Is that the same part as Mikado offers Now? The aluminum block between the tail case plates?
LOGO: 550SX, 700
SAB: MINI COMET, KRAKEN
VCONTROL*NEO*TRIBUNUS*MKS*TORQ*VTX*DPL8 W/BUMP CONTROL*MEANWELL
Corvette & Copter Guy is online now        Reply With Quote Quick reply to this message
Old 06-25-2018, 03:38 AM   #5 (permalink)
Hi, its not the Mikado one. The manufacturer is "QuickUK". Below is the link to the part. I highly recommend it to anyone having the tail wag issue.
Quick UK Retail - shop-products
Old 06-25-2018, 05:29 AM   #6 (permalink)
Were you able to use the brass insert from your kit?
Quick UK sells the tail slider with and without a brass insert.
Shows slider with insert:-
Getting the tail grips, slider and hub working as it should on a Logo is not straight forward. It seems everyone has to do a certain amount of fettling. The fan boys that have built multiple Logos do this with their eyes shut but for the new comer to Mikado this is such a frustrating model to get flying perfectly. Once achieved of course it is one of the best models ever.
If you have done everything suggested with making sure the bearings are seated properly, cleaning the flashing off the parts etc then as Bigpops found out the thrust bearings were not working properly, not something we should expect from a high end company.
Andy from Sandy is offline        Reply With Quote Quick reply to this message
Old 06-25-2018, 06:30 AM   #7 (permalink)
is there a retailer here in the states?
tonys-heli is online now        Reply With Quote Quick reply to this message
Old 06-25-2018, 06:44 AM   #8 (permalink)
RE: brass insert from the kit. Yes I did use the kits brass insert. It did take some fiddling around with to line it up straight but seemed to go in ok. It would be easier to go with the brass insert pre-installed though as you point out.
Old 06-25-2018, 06:45 AM   #9 (permalink)
Not that I know of. QuickUK is a small shop in the UK. I'm in Australia so I just bought and waited a few weeks for it to arrive.
lcatinchi likes this.
Old 06-29-2018, 11:22 AM   #10 (permalink)
I had the same experience with two Logos I owned. I replace the tail grips with Quick UK after trying many things and it finally went away.
Maybe the new Logo design should have metal tail grips along with the metal head.
Synergy 696 coming, Synergy E5SS HP, E5S, 2-soXos Strike 7s, soXos 600, VControl T, VBar Neo, Scorpion Tribunus ESC, MKS/Savox
Freeskiken is offline        Reply With Quote Quick reply to this message
Old 06-29-2018, 07:14 PM   #11 (permalink)
What other parts are needed?
LOGO: 550SX, 700
Old 07-02-2018, 10:29 PM   #12 (permalink)
every one please read the posts on the 480 xxtreme i wrote--i had the exact same issue and most people just buy a higher cost tail servo to power thru the problem--but that is not the issue -it truly has something to do with the blade grips and bearing combination-i tried everything with zero luck including sending my tail to mikado--that was waist of time --they my know the issue but wont share it--the worst part is i purchased a package including the tail servo that i guess it wasent good enough,,but thats not true i replaced the blade grips with the UKquick and yes that solved the issue--mikado needs to get a handle and fix this--it took me a long time to come to the conclusion it was the blade grips and bearings--mikado would do nothing about it--but other then the tail issue the heli is perfect...sorry for the long rant but hope it helps
I Fly Mikado, Align-repair and Build all brands
marke is offline        Reply With Quote Quick reply to this message
Old 07-03-2018, 09:06 AM   #13 (permalink)
A bit of white space helps!
A link to your other rant would be very useful.
Old 07-06-2018, 08:43 AM   #14 (permalink)
Sorry here is the string for the 480 issue. very similar to the 550 tail. I believe its something to do with the interaction of the bearings and the blade grip slop. but i am done chasing
https://www.helifreak.com/showthread.php?t=735356
Old 07-31-2019, 09:13 PM   #15 (permalink)
Just curious, but when I was looking at ERCMarket for the QuickUK tail hub, they mentioned it also fit an Align heli. Well, both the Align 550 and 600 uses the same tail grips so I was wondering if the Align tail grips would possibly work as a replacement for the Mikado plastic grips. Thoughts?
SAB Kraken, Align 700X, Logo 550SX, Oxy5 & 2, Protos 380 - NEO all the way!
Previous: Logo 600, Protos 700, Synergy 516, Velos 880, Gaui X7 & X5, Goblin 380, 120SR, SR, mcpx BL, 300X, 450XL, Blade 180, Align 150, DJI Spark, Leap 3D
gtruk is offline        Reply With Quote Quick reply to this message
Old 07-31-2019, 09:47 PM   #16 (permalink)
I think they do, but mikado grips have that weird dog bone angle. So not sure how that plays out with the geometry.
Old 07-31-2019, 11:45 PM   #17 (permalink)
The gaui x5 fit too, but the Mikado's grip balls are slightly farther from the group than both the x5 and quick UKs. I tried the gaui's first, but you couldn't travel the whole tail shaft without binding, I now have the quick uks and can set the travel all the way to the hub, but about 3mm from the tail box or it binds.
My wag is gone, but the quick uk tail slider is a touch stiff and you have to use it because the tail slide bolts on to the tail grips. I needed back out the slider to grip bolt and use red Loctite - it doesn't use a bearing. Note, too, the quick uk's did not come with the brass tail slider sleeve so I had to steal one from the Mikado slider. Finally make sure you set the slider up with travel all the way to the tail hub. I was seeing ccw piro rate was far slower than the cw piro rate until pushed the travel all the way to the hub. Usually, I leave 1 to 2mm gap.
Agile 5.5, Logo 550sx, X5, Oxy 3, Trex 450proV2, 250DFC #309
nflanagin is online now        Reply With Quote Quick reply to this message
Old 08-01-2019, 12:31 AM   #18 (permalink)
I found it easier to just find better thrust bearings.
Old 08-01-2019, 04:09 AM   #19 (permalink)
Glad it is working for you now
Changing the tail thrust bearings improved things a bit but the wag was still there. The real problem for me was the slider. On the bench everything was smooth, but once the tail was spinning there was binding in the tail. I ended up sanding the tail shaft with very fine sanding paper and that solved the problem.
One way of seeing if the tail is binding:
Remove the blades and disconnect the tail push rod
Now start the motor, the tail should center. Give some tail input by hand and let go, the tail should recenter immediately. If it only centers slowly there is still something binding
mr. mark is offline        Reply With Quote Quick reply to this message
Old 08-01-2019, 07:49 AM   #20 (permalink)
one thing I don't understand about that method.. if disconnected and no blades, how does it center?
