Like Tree4Likes
Old 10-06-2019, 01:47 PM   #41 (permalink)
Sorry guys, I haven't flown in a while as I had surgery and still recovering. The last time I flew my 600 though the tail was rock solid.
SAB Kraken, Align 700X, Logo 550SX, Oxy5 & 2, Protos 380 - NEO all the way!
Previous: Logo 600, Protos 700, Synergy 516, Velos 880, Gaui X7 & X5, Goblin 380, 120SR, SR, mcpx BL, 300X, 450XL, Blade 180, Align 150, DJI Spark, Leap 3D
gtruk is offline        Reply With Quote Quick reply to this message
Old 11-11-2019, 08:15 PM   #42 (permalink)
Update - I switched my heli from NEO to Futaba at IRCHA and made a whole bunch of tweaks to the tail so not really sure what one thing we did that made the difference but one thing stuck out to me was when one of the guys said that the tail push rod seemed to long. Given that the tail servo is not attached to the boom and cannot move, I felt the rod was in fact to long. The ends were turned all the way in and could not go in any further so I bought a new push rod and cut about a CM off and put on new ends.
This made a huge difference because now I could actually adjust the rod ends and add the proper 3 or so degrees of rudder to the tail. I went flying today and with some minor tweaks to the tail gain, it was rock solid with no wag.
FYI, I ended up selling my Futaba stuff and switched back to NEO. So, the solution, in my opinion to the tail kicking is the push rod is simply too long and needs 1/4" to 1 CM cut off and then you'll actually have some room for adjustments. My 600 flew awesome today!
Freeskiken likes this.
Old 11-17-2019, 12:10 PM   #43 (permalink)
I know the title says fixed but a friend gave me his new logo 550 that had a persistent wag to try to sort out. Pushrod was correct length, all assembled correctly, thrust bearing races the right way round. Everything was butter smooth when static but i noticed that if i pulled outward hard on the tail blades to simulate centrifugal force I got a binding when i tried to turn the grips.
So it turns out the problem is the shim between the outer radial bearing and the inner thrust bearing race. The shim is too thin so under load the inner race of radial rubs on the thrust bearing and makes it bind.
A thicker shim should fix it. I had some spare grips off my Tarot 600 and i just put them on, that did the trick. Tail was transformed, it's rock solid now.
Gob Kraken |Gob 700 BT 'T' | Gob 770 Comp | Gob 700 Speed | Trex 700X | SoXos Strike 7| Tarot 600| | XLPower 700 | Henseleit TDR & TDR2 | Kasama Dune | UK distributor for Tarot 550/600 helis - ScotiaRC.co.uk
Old 11-17-2019, 01:03 PM   #44 (permalink)
Would this be the same as idea?
Thickfog is online now        Reply With Quote Quick reply to this message
Old 11-17-2019, 01:43 PM   #45 (permalink)
Maybe so, they could have used a narrower bearing and a thicker shim.
Old 11-17-2019, 02:36 PM   #46 (permalink)
Glad to hear this issue appears to have been resolved.
Old 11-17-2019, 03:22 PM   #47 (permalink)
Typical Mikado silence on the issue. And they changed the parts too apparently but still not a word.
Old 11-17-2019, 04:31 PM   #48 (permalink)
Based on my experience, the 100% sure fire fix is to throw the stock tail grips in the trash and drop in a pair of Tarot grips. Fortunately the Tarot grips are cheap, a pair of metal grips with bearings and shaft is about $15
Old 11-17-2019, 06:45 PM   #49 (permalink)
I may have asked this before, I don't remember, but what tarot grips?
tonys-heli is online now        Reply With Quote Quick reply to this message
