Like Tree25Likes
Old 07-06-2018, 01:37 PM   #21 (permalink)
Originally Posted by prokyon View Post
It looks like 690SX with carbon nitro frames (yeah, same cross-member design as Synergy) and a tighter canopy - not surprised they went this way. Which means that there should be a new carbon 690 frame available soon just like the 600SX frame.
I've seen a lot of Mikados fly and 690SX flies like nothing else - super smooth and super efficient and can even handle basic smack, although the manual warns not to exceed 2000rpm and 11degrees of pitch. I cranked mine up to 2150rpm and it smacks OK, although at 1850 it's ballistic enough due to low weight and crazy efficiency under load. It's basically a 600 stretched, which has been around for like 10 years now with different versions - basic, SE, SX, now V2, so it's definitely a tried and tested design.
Mikado had their own carbon frames a while ago, like the kaos frames, from what ive read, most people didn't like them compared to the plastic frame. not to mention finding replacement frame parts..I understand the nitro don't like the plastic. but the carbon does look cool.
prokyon likes this.
tonys-heli is offline        Reply With Quote Quick reply to this message
Old 07-06-2018, 02:04 PM   #22 (permalink)
Originally Posted by Johnny31297 View Post
Plastic and fuel don't go together at all. It'll stay CF.
I think that depends on the plastic, besides Mikado can't be to worried as they are still using plastic main grips.
prokyon likes this.
SYNERGY 516
Mikado LOGO 550
Mikado LOGO 700
SMJT is offline        Reply With Quote Quick reply to this message
Old 07-06-2018, 02:11 PM   #23 (permalink)
TT Raptors and many Hiroboís never had any problems with fuel in the past. So Iím sure Mikado can make them in plastic if they want to
Quest Impaction 787 x2 | Futaba CGY760R | 272+276 | Kontronik Pyro 750 | Jive Pro 120HV+ | Telme
XL Power Specter 700 | Futaba CGY760R | HC500+276 |Egodrift 4525 | Hobbywing 130A
tomas is offline        Reply With Quote Quick reply to this message
Old 07-06-2018, 02:16 PM   #24 (permalink)
Oops. It's been covered. Really looking forward to this one.
Nick Crego
#0168
Eury is offline        Reply With Quote Quick reply to this message
Old 07-06-2018, 02:39 PM   #25 (permalink)
I'm done being excited over anything until I can order it and it ships immediately.
Time will tell.
Citizen 61
Glenn Goodlett is offline        Reply With Quote Quick reply to this message
Old 07-06-2018, 03:04 PM   #26 (permalink)
The plastic main grip design is actually very cool - the blade grip arm is designed to break in a crash but the main grip itself is so beefy that the blade will never fly off. Everything else like the main shaft and feathering spindle takes kinetic energy of an impact really well, so most of the energy is transferred away from the frame. I've dug my Logo in and had all the parts basically sacrifice - unless one crashes the frame head on or goes in under a lot of power, it's hard to break the frame.
The only thing you can't do is run the blades very tight in the blade grips, but that's not really needed anyway.
Added bonus - all plastic parts are super inexpensive and use nylon nuts.
Synergy E7se | Mikado 690SX V2 | Goblin Black Thunder T | Gaui X3 | brushless mCPx
VControl | MKS & KST Servos | Pulse
Heli-X8 | Lynx Team Pilot
prokyon is offline        Reply With Quote Quick reply to this message
Old 07-06-2018, 04:27 PM   #27 (permalink)
While your all on here, I see where kyle attached his pipe to the motor with the long bolts and nuts. I've been trying this today and for the life of me and can't thread them all the through by hand. My hand is sore and wore out. Any suggestions???? Would it be OK to use a 3mm hex screwdriver bit to run them all the way through with a battery screwdriver to break the screws in first, then tighten them by hand. This is kind of a logo question and pipe question all in one since Kyle is using this method on the goglo 690.
Wyno is online now        Reply With Quote Quick reply to this message
Old 07-06-2018, 09:02 PM   #28 (permalink)
If that's on a OS 105, you need to drill out the motor case first. I think it's a 4mm bit? Don't remember for sure.
Team Only Fine Helis
smwht is offline        Reply With Quote Quick reply to this message
Old 07-06-2018, 10:10 PM   #29 (permalink)
Matt Botos has confirmed that the new GloGo is using Synergy parts as this heli is a Kyle Dahl design with input and parts supply from Matt Botos
Synergy RC.
Freeskiken, boogie12 and prokyon like this.
Gabriel Sandoval "NitroGabe"
Team Synergy / Rail Blades, Team Dee Force
Team Scorpion, Team YS engines USA
Bavarian Demon Flight Team #HIGHONHELIS
DUCDOC is offline        Reply With Quote Quick reply to this message
Old 07-07-2018, 12:06 AM   #30 (permalink)
I logoLove it might have to revert back to nitro Wow that there me. Devin said a nitro logo and I was like What no way mikado will do a Nitro ok I want a 550 on a ys 60 please Kyle
Trex_600n,Trex_500,MR25,MikadoLoGo5003D_KDE,CastleCreations,Ys,JR XG8,Sab Goblin 380/X_Nova/Bk_Servos, JR TagsMini//Sab Goblin 500Pulse Edition, Sab Goblin570Carbon_SABUSA_X_Nova_BkServos_KDE,RJX-Swash,JR-SPG-Tail/TagsMini_JRX-Bus.
JEEPWORLD2002 is offline        Reply With Quote Quick reply to this message
Old 07-07-2018, 09:56 AM   #31 (permalink)
Synergy RC.
so what parts are synergy?
Old 07-07-2018, 01:37 PM   #32 (permalink)
Fresh from Global 3d:
Glogo @ global 3d 2018 (0 min 47 sec)
cudaboy_71, apper001 and GregCA like this.
-TT E700 V2-vbar-mks950-980-Kosmik 160HV-Pyro 700 rewound by PD / Voodoo 600 -PD-MX700-470kv--BLS255hv-VBAR 5.3+- Gaui X3+Spirit Pro
velocity90 is offline        Reply With Quote Quick reply to this message
Old 07-07-2018, 07:05 PM   #33 (permalink)
Mikado Glogo 690 Kyle Global 3d 2018 (5 min 9 sec)
Verstuurd vanaf mijn U FEEL PRIME met Tapatalk
GregCA likes this.
Old 07-08-2018, 01:30 AM   #34 (permalink)
Heard something that Ralf Buxnowitz mentioned the Glogo 690 might be available around December.
apper001 is offline        Reply With Quote Quick reply to this message
Old 07-08-2018, 09:08 AM   #35 (permalink)
This is why I like my logos. And parts interchangeability between sizes.
Sad to see the new ones all with aluminum grips now.
Sent from my SHIELD Tablet K1 using Tapatalk
Thickfog is online now        Reply With Quote Quick reply to this message
Old 07-08-2018, 09:22 AM   #36 (permalink)
The plastic grips are exactly why I bought the last 550SX instead of the newest one.
Old 07-08-2018, 01:56 PM   #37 (permalink)
where did they get that older style hatori??? are they not all sold out, and only the Newer versions are left?
Trex 700 LE Dfc, Trex 700 Dom Top HV, Trex 800 Trekker
Trex 800 Dfc Pro, Goblin 700 Comp & 380, Goblin 500 (Yellow)
Blade 180Cfx, Blade 130x, 3 of them, modded Spin 8500/8000
Andrew166 is offline        Reply With Quote Quick reply to this message
Old 07-08-2018, 01:58 PM   #38 (permalink)
Cd with the Glogo
https://www.facebook.com/10000632961...9425480611751/
Old 07-08-2018, 02:49 PM   #39 (permalink)
Kyle Dahl freestyle
00139 (4 min 19 sec)
Verstuurd vanaf mijn Nexus 9 met Tapatalk
apper001 likes this.
Old 07-08-2018, 03:18 PM   #40 (permalink)
Thanks for all the videos, can't wait for this to hit the market. Looks awesome and light!!!!
