07-15-2018, 02:58 AM | #1 (permalink) |
Push rod rubbing on tail case
I just notice on my 470LM that the tail push rod is just touching the underside of the tail case. Is this designed this way or has my tail bell crank bent forcing the push rod up to touch the case?
The flight isn't complete until the blades stop turning... [Trex 600N, V-Bar] [Trex 450ProV2, 3Gx] [Trex 470LM Microbeast Plus] |
07-16-2018, 09:39 PM | #2 (permalink) |
Mine
Mine did same thing because I was pushing ball on. I just bent it back a little.
Austin, TX HoudiniRCHeli Podcast |
07-19-2018, 01:24 AM | #3 (permalink) |
Recommend using ball link pliers to install the ball link onto the ball. If you do not and pop on with your finger you will bend the arm until it is close to or will contact the tail case during operation.
Gale Align Team Align Sent from my SM-N900P using Tapatalk |
07-19-2018, 03:40 AM | #4 (permalink) |
Hi
I would never just push, always use pliers or pinch. Ie push from both sides.
V977, Align T-rex 470LM, Align T-rex 550X, Align T-rex 760X. |
07-20-2018, 02:18 AM | #5 (permalink) |
I also always use the ball link pliers for the ball link.
So there should be no contact between the push rod end and the tail case? Maybe the bell crank has been bent by crash or other?
08-05-2018, 08:03 PM | #6 (permalink) | |
Rub Fix
Fix Mount the servo under or on the bottom of the Rudder Servo Mount.
Align450L / 470/150 DFC/Blade stuff DJI/AR Drone |
10-01-2018, 11:25 PM | #7 (permalink) |
sounds like the arm is bent a little. mine is about 3mm away from the tail case and the arm on mine is dead straight
NanoS2 - mCPX BL2 - 230s - 470LT - Goblin BT700 - LaTrax Alias
10-02-2018, 10:49 AM | #8 (permalink) |
Mine rubbed also so I mounted it to the bottom of the servo mount. Problem solved. Align really should either change the instructions or rework the mount....
JW Blade 230S-Rakon Kit/Fusion 270-Spirit-GeoLink/T-Rex 470LT-Spirit-GeoLink/Taranis X9E |
10-02-2018, 10:08 PM | #9 (permalink) | |
there is nothing wrong with the instructions. everything works perfectly as per the factory assembly instructions. until you bend the arm by installing the rod incorrectly [by hand and not using pliers]
10-12-2018, 10:55 AM | #10 (permalink) | |
