Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade mCPS
Blade mCPS Blade mCPS Helicopters Information and Help
Old 07-28-2018, 11:28 AM   #1 (permalink)
Default Blade mCPS losing tail
Stock Blade MCPS with long tail boom and nano-tech 300mah. I've done everything from setting my pitch travel adj to 88-90%, cleaning the servos, max flight time set to 3mins, used long tail boom and nano-tech 300mah but I still keep on losing the tail!!! I did a back flip after this vid and it completely lost it causing a crash!
Really need help!
Blade MCPS front flip practice (1 min 9 sec)
Blade mSR
KDS450SV
DX6i
gjo0228 is offline        Reply With Quote Quick reply to this message
Old 08-02-2018, 01:28 PM   #2 (permalink)
A 7mm tail motor with mCPx BL tail blade ( with the extended boom) really helps with tail issues.
fliermike is offline        Reply With Quote Quick reply to this message
Old 08-09-2018, 06:02 PM   #3 (permalink)
Almost gave up on this. Eventually, I just had to go back using a mCPS hi-perf blade rather than the mCPXBL ones and had to lower down thro curve from all 100 to 80 on stunt and pitch curve from 88 to 75.
Will play around with the setup again once I get better. I would feel better crashing now when trying new tricks rather than crashing because of faulty setup 😅
Blade MCPS finally got the TBO out (0 min 52 sec)
Blade mSR
KDS450SV
DX6i
Old 08-12-2018, 05:14 AM   #4 (permalink)
Just get BLH3602L mcpx extended tail assembly. It's an easy upgrade to install. With this even at 100 flat throttle and 100/100 pitch travel I don't have TBO issues. But still the new tail won't hold that well when you smack the stick, but nowhere near as bad as the stock tail.
Heli-X, DX6 G3, DXe, V977, K110, 130S, Nano CPS x 4, MCP S, Nano S2. since 08/2017.
koopa137 is offline        Reply With Quote Quick reply to this message
Old 11-04-2018, 11:09 PM   #5 (permalink)
Fwiw..
Use long boom with 7mm tail motor, microheli tr blades...couple this with brushless main conversion, better 3d than old
Bl version...
John.
bmlasater is offline        Reply With Quote Quick reply to this message
Old 11-09-2018, 10:04 PM   #6 (permalink)
Link to the 7mm tail motor?
logo 600sx, 480, mcps bl.
Dsss is offline        Reply With Quote Quick reply to this message
Old 11-10-2018, 01:30 AM   #7 (permalink)
Originally Posted by bmlasater View Post
Fwiw..
Bl version...
John.
How about long tail boom alone?
neosunrise is offline        Reply With Quote Quick reply to this message
Old 11-14-2018, 11:41 PM   #8 (permalink)
Hi,
Long boom by itself does not help...7 mm motor is answer. I am stilll expeeimenring with blades, the 47 mm lynx work best so far..
Hyperion 550 mah batts also minimize blowout, allows 3.5 min of 3d....essential trickk ia to limit pitch in both directions to prevent lvc if you get too rough on cyclic...
Old 11-18-2018, 11:11 PM   #9 (permalink)
A few comments on the tail and some flight video links in the ending.
It holds great .
Blade McpS and 130s comments (8 min 10 sec)
- SpekBo
Goblin 420, Oxy 4 360 stretch, Goblin Fireball, Oxy 3 Tareq Edition, Oxy 3 Speed, Oxy 2 190 FE, Blade 230S V2, Blade 130S, Blade McpS, Hirobo S.R.B Quark.
Transmitter: DX8 Gen 2
SpekBo is offline        Reply With Quote Quick reply to this message
Old 11-20-2018, 07:02 PM   #10 (permalink)
Today's flight .
Blade McpS backyard flight (2 min 26 sec)
- SpekBo
