Old 08-10-2018, 01:58 PM   #1 (permalink)
Default Just bought a used 250 dfc any tips?
As the title
Just got a used trex 250 pro dfc that came with a Spektrum ar7200bx and a separate bec attached also
Any tips at all for spares that go regular in crashes or wear quickly ?
Also are the transmitter settings the same for the ar7200bx the same as the ar7210bx ?
Thanks in advance 🙃🙏🏼
ID:	752995   Click image for larger version
ID:	752996   Click image for larger version
Numbs is offline        Reply With Quote Quick reply to this message
Old 08-10-2018, 03:28 PM   #2 (permalink)
I still fly mine on a regular basis. In fact last week before IRCHA I got new NanoTech batteries and that really improved performance over my 3 year old batteries.
Make sure the bearings in the head are good and not crunchy. Bearings in the head that don't move smoothly cause a bad hysteresis effect with the collective. The mushroom gear has spun on its shaft on me also. Maybe caused by damage from a prior crash, however.
Anyway, on a used machine I'd probably totally disassemble it and check all the bearings and gears and torque tube assembly.
Micros: Hisky HCP80, ESKY 150x,K110, Trex-150X x 2 Mid: Oxy 3 T New Version, Oxy 4 360 Big: Trex-500X, Trex-550X, Trex-700X Scale: MD500 TOW Defender (Trex 500 size) Vintage: Trex 450 SE V2
ic-racer is offline        Reply With Quote Quick reply to this message
Old 08-10-2018, 05:28 PM   #3 (permalink)
This has been happening for ever - it's a combination of heat and oil getting up under the gear. If you look through the threads from years ago, you'll find that even on the new ones we would pop the gear off and use some JB Weld to keep it on snug. Clean it with alcohol first and apply the epoxy inside the gear before pressing it on so it doesn't get in the bearing.
Agile 5.5, Logo 550sx, X5, Oxy 3, Trex 450proV2, 250DFC #309
nflanagin is online now        Reply With Quote Quick reply to this message
Old 08-11-2018, 08:19 AM   #4 (permalink)
Ah thanks for the heads up .. going to replace all the bearings as there’s wobbles all over the place .. shall get some goo for the pinion gear too 👍🏻
Old 08-12-2018, 05:02 AM   #5 (permalink)
I'd be tempted to look at some of that wire routing too. No need for cable braid on a 250, it's unnecessary weight. And ESC wires have an easy route along the side of the frame, no need to cross under the motor like that.
Helis: Oxy2 FE, Oxy2 Sport, Protos 380, Oxy 4 Max, Gaui X3 stretched
Electronics: Spartan Vortex, MSH Brain, Jeti DS-14
Sims: RealFlight & AccuRC
Other: Team rep for Lynx/Oxy, Founder of NightWave Systems
Old 08-12-2018, 06:27 AM   #6 (permalink)
Yeah I thought it was a bit unnecessary as not even done it on my 470 lt lol
Shall take a before and after weight see how many grams we can shift .. I reckon a lot will be saved swapping out the align esc/ ccbec will save a fair amount 🙃
Old 08-12-2018, 07:27 AM   #7 (permalink)
Yup, likely 20g or more weight saving from that alone. I always solder my 250 motor straight to a Talon 15, makes it neat & tidy, the Talon 15 can stick underneath the battery tray, and it's the ideal combination.
Old 08-12-2018, 05:57 PM   #8 (permalink)
So ... Started stripping her down this eve weighed it without battery and we got 293.18g .. old esc/ bec combo came in at 30.09g compared to the 6.45 of the talon 15 .. may even get a talon 25 instead of the 15 we shall see ..
Also just stripping it down we’ve managed to chop out 5g just in cable ties and heat shrink and a couple of unnecessary sticky pads alone .
Is looking like a much more sprightly bird already 👌🏻🙃
ID:	753161   Click image for larger version
ID:	753163   Click image for larger version
ID:	753164   Click image for larger version
ID:	753166   Click image for larger version
