Go Back   HeliFreak > R/C Electronics Support > Spartan RC > Spartan Vortex
Spartan Vortex Spartan RC - Vortex VX1 Factory Support Forum
Like Tree1Likes
  • 1 Post By RotorHeadKen
Old 08-26-2018, 01:37 PM   #1 (permalink)
Default Vortex + Datapod + Remote Tweaks = Nirvana
I don't know why I resisted using the Datapod when tuning my helis. It really cuts down on the time needed to dial in the settings.
My 450 is flying rock solid now.
That is all.
iscripter likes this.
RotorHeadKen is offline        Reply With Quote Quick reply to this message
Old 08-26-2018, 05:22 PM   #2 (permalink)
Oh yeah, remote tuning is superb. I've got a datapod and Jeti integration, tuning is stupidly quick :-)
Old 08-29-2018, 09:30 AM   #3 (permalink)
Absolutely! The DP makes setup and tweaking so quick and easy and it's totally portable. It's massively convenient.
I've only had a few other FBL units but the Spartans are by far the easiest to setup and I find the default settings and heli / style wizards often arrive at settings that are bang on the money right from the start.
My only (minor) gripes are that if you update the firmware in one unit you have to update the DP and then it won't work with any others still on the previous firmware. Also, in the swash setup I wish it was possible to step back, like when setting subtrims on the servos you have to cycle all the way through if you need to go back to servo 1 again.... but a very minor thing.
2009 TDR, Kasama Dune and Faifa, Minicopter Triabolo 700, RMJ Raptor gasser,
Beam E4 and Avantgarde, JR E8 leggero, Suzi Laos, Shape S8, TDRex 800, Rave 450, Trex 500.
trillian is offline        Reply With Quote Quick reply to this message
Old 08-30-2018, 06:08 AM   #4 (permalink)
Yeah, I agree. I've spoken to Angelos in the past about both, on the DataPod there's limited code space if I remember correctly, so it just wasn't possible to have it support multiple versions, and the GUI needs a total rewrite to support back buttons as the process under the hood is designed to support you as you work through the setup steps.
Angelos is aware of both, but there's no easy fix for either unfortunately.
On the plus side, I totally agree, the Vortex has the best setup wizard and easiest config of any unit I've tried so far.
Old 09-18-2018, 07:27 PM   #5 (permalink)
is it worth the 65 USD if you only have one unit?
im paying with loonies up here in canada.
Goblin 770S - eXo 500 - HD 502 - Oxy FE, Max, MEG - Few 4 Stroke Saito powered Fixed wings
Spartan VX1e, Frsky RX, RT & Zeal Blades MKS/BK, Hobbywing
Danker16 is offline        Reply With Quote Quick reply to this message
Old 09-18-2018, 07:30 PM   #6 (permalink)
Hey fellow Canuck, its worth every penny. Love my Datapod!!
Steve
Nano CPX || 130X || 230S II 450 3D converted to 450X || 360CFX || 550X || Oxy 5 || ALeeS Rush 700 Evolution || Goblin 770 Sport 'My flight style, determines my crash style"
crashcopterman is online now        Reply With Quote Quick reply to this message
Old 09-19-2018, 04:19 AM   #7 (permalink)
Well, I suspect that the answer to this is entirely subjective. If you find that you end up setting your Vortex up on day one, after only a few packs, and have not touched it since, because you are happy with how it flies and also find it no trouble taking your PC to the field with you, because the field is outside your back door, or if your vision is such that you need a magnifying glass to make out the writing on the datapod, but can manage with the text on a PC, then no, it's probably not worth it.
If however, you like to tinker, often, changing head speed, and other settings, and want to adjust them, on the fly, to match, or if your flying is progressing rapidly and you want to alter the heli accordingly, and the field is miles away, and you detest taking a PC with you, for security reasons, or whatever, and your vision is 20 20, then yes, I guess this is for you.
I haven't adjusted either of my Vortex equipped helis in years, and can't read it anyway, so I guess I fall more into the former group rather than the latter.
Regards, Sutty
BeltEXI, mCX, mSR, 4G3, FBL Trex250SE B, FBL Trex450Pro B,
sutty is offline        Reply With Quote Quick reply to this message
Old 09-19-2018, 08:34 PM   #8 (permalink)
Good points
I believe one of the main reasons people did not get the spartan FBL unit in the past was because you needed to purchase an additional datapod to set it up and tune it. They did not want to pay extra for it.
Then all of sudden vbar comes up with vcontrol and integration with the FBL unit. Now for some reason people decided yeah that seems to be the way to go. I will fork out big money to get a transmitter that allows me to progam and tune the FBL unit from my transmiter yet getting a seperate box that cost 10 times less to do the same thing was not cool.
The world works in mysterious ways.
dl5973 is offline        Reply With Quote Quick reply to this message
Old 09-25-2018, 12:20 PM   #9 (permalink)
Besides, if you fly planks like I do, Vcontrol is worthless for that purpose.
I did setup my first Spartan FBL with laptop and it was ok. Now I won't bother. I do everything with Datapod and I like that a lot.
I have tried Vbar, Brain, 3GX and from all I find Spartan Vortex easiest to setup. Normally I do not have to tinker cyclic at all and only minor tweaking of tail gain. After getting to know the heli I tend to fine tune small things like headspeed, gov start and tail. For all this Datapod is very good, not to mention transmitter tuning any parameter when Datapod is onboard.
ini_ is online now        Reply With Quote Quick reply to this message
