Go Back   HeliFreak > R/C Helicopter Support > OXY HELI > Oxy4
Like Tree88Likes
Old 09-08-2018, 09:00 AM   #21 (permalink)
Originally Posted by proy View Post
The yge seems very good for the weight as well, I need a spirit unit with 2 satellite port (at the moment) to have Geolink and telemetry active with yge OR HV.
for the fbl i could always drill holes on the frame to the the sat wires connected on the side of the unit. I will wait the manual to have a look if it could fit in they’re.
Envoyé de mon iPad en utilisant Tapatalk
I mounted the Spirit Pro on top of the boom box a little further back for better access to the cyclic servos and drilled holes in the frame plates for easy access to the sat ports. I too will be mounting a Geolink on my Oxy 4, so you will be just fine as far as sat port access is concerned by doing the same.
Kevin
Blade 230 S / 230 S NF / 450X / 500X / 550X ~ Trex 470LM ~ OXY 3-285 / OXY 4-325 / OXY 4 MAX ~ Spirit FBL ~ DX9
________________________________
Team OXY Helicopter - Lynx Heli Innovations Field Rep
Genesis X7 is offline        Reply With Quote Quick reply to this message
Old 09-08-2018, 11:23 AM   #22 (permalink)
Does the Spirit Pro fit in the frame of the OXY 4 / Max? Can an owner show pictures?
Regards
Dave
T-Dave is offline        Reply With Quote Quick reply to this message
Old 09-09-2018, 09:59 AM   #23 (permalink)
I’ll post a pic here sometime today for you T-Dave
T-Dave likes this.
Old 09-09-2018, 10:00 AM   #24 (permalink)
Thank You!
Old 09-09-2018, 12:05 PM   #25 (permalink)
Post Pics
Here are the pics as promised.
Kevin
ID:	755411   Click image for larger version
ID:	755412   Click image for larger version
Indokast and T-Dave like this.
Old 09-09-2018, 12:21 PM   #26 (permalink)
Thank you!
It looks very narrow. Does it touch the frame?
David
Old 09-09-2018, 12:33 PM   #27 (permalink)
Originally Posted by T-Dave View Post
Thank you!
David
It slides in nicely, but there really isn't any wiggle room to spare.
Kevin
T-Dave likes this.
Old 09-09-2018, 02:23 PM   #28 (permalink)
Originally Posted by MaGooRc View Post
Could you post tail case photos?
There you go
ID:	755473   Click image for larger version
Michael
Kraken 700 & 580; Oxy 4 MAX; Oxy 3 TE18
mulchi is offline        Reply With Quote Quick reply to this message
Old 09-09-2018, 02:26 PM   #29 (permalink)
Hi Michael,
What size are the tailblades?
David
Old 09-09-2018, 02:28 PM   #30 (permalink)
The blades that come with the kit (and are mounted) are 70mm.
72mm should also fit, e.g. for even lower speed setups.
T-Dave likes this.
Michael
Old 09-09-2018, 02:46 PM   #31 (permalink)
Kevin
With as much room as you had to spare on the back, couldnt you have just slid to the rear some vice drilling? Looks like you had more than enough cable, lol. One of the biggest things that I dont like about spirit is the form factor. Impossible to get a clean looking install. The reason I also hate the mini version of brain/ikon, vertical connections. Seems like it would be easy enough to go horizontal.
Sent from my SM-G955U using Tapatalk
Old 09-12-2018, 06:58 PM   #32 (permalink)
Here are my 325 and 360. Max shows tomorrow, hopefully. I chose to put my FBL on the bottom like the Oxy 3. Some say that it is better protected on the top. IME, this just isn't true. Every crash is different and I crash more inverted than I do upright. I do tend to fly in light rain a lot, so maybe it helps there also. And as many crashes as I have had in the early days with the Oxy 3, some very violent and even upright, the FBL never was touched.
crashnrox, Indokast and mulchi like this.
Old 09-14-2018, 07:53 AM   #33 (permalink)
And here is my 380 max. My AUW is 1052g. Even with that weight, as a frame of reference it is only about 25g heavier than my P380 EVO, which is the lightest thing I have flown.
Only flew one test flight. I started with a pretty low headspeed and it was incredible down low at 1600rpm. Flips, rolls no problem. Needed some tail tuning tweaks, but other than that really smooth at that speed. Flew mostly at 2000, which may end up being my low speed, or possibly 2200. Used an 1800 pack and after a 5min flight had 3.95 per cell, which says to me an easy 7min if I stayed at 2000 or possibly could go higher and still get 7min. Adjusted to 12.7 pitch.
My beta kit came with 71mm plastic tail blades. Plan to stay with Switch mains for now but have Zeal and R/T also to test out.
Need to finish setting up telemetry and make some tweaks and will be ready to open it up some.
For those planning to use the Tareq motor be prepared to extend the flat spot on the shaft. Takes seconds with right tool. Pinion does have 2 grub screws but I wanted at least one on a flat area for safety. Can't speak to other Xnova motors.
Old 09-14-2018, 04:23 PM   #34 (permalink)
Here's the whole family.
Old 09-14-2018, 04:27 PM   #35 (permalink)
Awesome family picture
Michael
Old 09-14-2018, 06:17 PM   #36 (permalink)
Wow the max looks unreal, hopefully mine shows up on Monday...
My local shop has some 1800 6s gensace packs, I think I'll run with those.
Sent from my MI 6 using Tapatalk
majorlemond is offline        Reply With Quote Quick reply to this message
Old 09-15-2018, 07:37 AM   #37 (permalink)
Here it is!!!
- Michalis |OXY Heli|XNova Motors|
...let the flying be second nature!
acidla is offline        Reply With Quote Quick reply to this message
Old 09-15-2018, 08:08 AM   #38 (permalink)
You're going to have to do better than that.
Old 09-15-2018, 09:09 AM   #39 (permalink)
Later
Old 10-09-2018, 03:01 PM   #40 (permalink)
4 Max in the sun
jrman83, slogoat and xmlnoob like this.
