Go Back   HeliFreak > R/C Helicopter Support > Other Makes and Models Helicopters > V977/K110/K120
Old 12-22-2018, 11:09 AM   #1 (permalink)
Default Need To Start Over
Heli was pulling hard to left. I balanced the swash with the zip tie trick. Then heli wouldn't get off the ground. I adjusted the rods again now the heli just asks stupid. To start fresh can I just twist all of the rods in and go from there?
nacraracer is offline        Reply With Quote Quick reply to this message
Old 12-23-2018, 01:31 PM   #2 (permalink)
I guess you are flying in 6g mode, if so, I would suggest you to replace the controller foam, look it up in this k110 section, read the whole section and you will find it.
Yes, it will make a big difference, don’t know why but it works, even if you are not in 3g mode, nothing to loose.
It will stop the drifting.
Use regular white 3m white foam that you find in Lowe’s or HD
Don’t add any trim or subtrim in radio.
After doing this go mid stick in your radio and check for blade tracking.
Report back
As for the rods measurements, what pitch curve do you have in 6g mode?
salrica is offline        Reply With Quote Quick reply to this message
Old 12-23-2018, 01:42 PM   #3 (permalink)
Are you referring to white double sided tape?
Old 12-23-2018, 06:13 PM   #4 (permalink)
Yes, replace with that one and report back when you have the blade tracking perfect at mid-stick and post your pitch curves on 3 and 6g mode.
This is how I did it, you need to cut it in parts for the electronics placement
If you are certain that main shaft and head spindle are good, that main grips bearings are good, then replace foam
Old 12-23-2018, 07:38 PM   #5 (permalink)
Can you post a video of it acting stupid?
Brian Oxy 2, EOX 1911-3600kV, YGE 35LVT Oxy 4 Max, EGODRIFT 3220-900kV, YGE 65LVT XK K110 Spirit FBL Horus X10S, OpenTX 2.3.9
xoexoe is online now        Reply With Quote Quick reply to this message
Old 12-29-2018, 04:32 PM   #6 (permalink)
Here is the video I took this evening. This is my other heli. This is basically what it does, however it sometimes rolls to the right and does the same thing. I have replaced everything on this heli, everything.
It will not let me upload the file. Something about I did not have a security token.
