Go Back   HeliFreak > R/C Helicopter Support > Mikado Logo Helicopters > Mikado Logo 700
Old 01-07-2019, 12:47 PM   #1 (permalink)
Default logo 700 tail wag
on Friday I probed my 700 logo with a vbar silver line tail servo mks the flight was very bad since I had a tail wag very bad
Decide to change a ikon in the field and the flight was very good
the state trying to understand the solution to the problem if in fact the change of the washer that is mentioned in some post is the solution
victor gomez07 is offline        Reply With Quote Quick reply to this message
Old 01-07-2019, 05:54 PM   #2 (permalink)
I did the washer change when building my Logo and it has zero wag. I would swap out the washers.
7s TDR’s / TDSF / Diabolo UL
Neo, Touch, MKS, Kontronik, R2 buffer
Lighter just flies easier.
Spencerkey is online now        Reply With Quote Quick reply to this message
Old 01-07-2019, 06:48 PM   #3 (permalink)
thanks for answering just change for the 12mm or some othe
Old 01-07-2019, 07:23 PM   #4 (permalink)
Get the 8 x 12 x .5 shim
Old 01-08-2019, 11:13 AM   #5 (permalink)
You already made the change of the 12 mm washers and nothing the tail.
the record of the vbar does not show any extreme vibration any idea
please help
Old 01-09-2019, 05:27 AM   #6 (permalink)
Thrust bearings? Have you checked if they are installed correctly (larger inner ID in, smaller inner ID out)?
Logo690SX-Logo600SX-Logo550SX-VBarControl-Neo
STAZZ is offline        Reply With Quote Quick reply to this message
Old 01-09-2019, 08:23 AM   #7 (permalink)
hello friend thanks for replying
We have already revised the thrust bearings several times.
The tail slider is soft
I put the 12mm washers
change servo from one mks bl 980 to bk 7005 and there was no change
any other idea or solution that has had please help me
I already despair too and try an Ikon with this much improvement but it is not perfect
I need to find the solution to this problem please anything that has been done so that your 700 logo with a perfect tail let you know and appreciate all the help
Sorry for my English and Mexico and unfortunately nobody can help me here and I do not know anyone who has this helicopter
Old 01-09-2019, 09:51 AM   #8 (permalink)
I had this problem too, all was smooth and built correctly, but i had a nasty tail wag as well the first flights.
I completely rebuilt the tail section, and although i did that in the exact same way as before the tail wag was now gone. I never found out what the problem was.
I hope you find out what the problem is
mr. mark is offline        Reply With Quote Quick reply to this message
Old 01-09-2019, 10:06 AM   #9 (permalink)
Thank you
which section did you rebuild
Old 01-09-2019, 11:51 AM   #10 (permalink)
The whole tail
Old 01-10-2019, 10:40 AM   #11 (permalink)
Default thrust bearing
The whole tail
someone could tell me the correct installation of thrust bearing
the exposed balls go out or go towards the arrow
Old 01-10-2019, 10:58 AM   #12 (permalink)
should not matter too much for tail wag. I prefer the exposed side inwards though, the grease might stay in longer that way (although you have to check that regularly)
Old 01-11-2019, 02:39 PM   #13 (permalink)
ok from the top, here is how i build mine......
Before I even build the tail box I dismantle the brass bush out of the tail slider, apply brasso ( a brass polish) and work this up and down the tail shaft until its perfectly free ..... I clean both the bush and the shaft with brake cleaner and oil both with a light oil, triflow is good,.....
then I am super careful with the build of the tail , especially the thrust bearings,... I usually build them cup side inward and make sure the thrust bearing is assembled the right way round , with the larger id to the inside.... and greased with a good quality grease.....
I use a rubber safe (silicone ) grease on the damper o rings.....
I also change the shims out to a 12mm o/d but I have just built the latest kit 2019 spec and am going to try the OeM shims first....
I also squeeze the pitch links gently with a pair of pliers when they are attached to the tail grip... I also do the same on the tail pushrod ball links
this should be good to go.....
oh just a question..... the front torque tube bevel gear is all the way home ????? its quite a push to fit it !
I hope this helps you and this only applies if you have a slow tail wag thats very noticeable in the hover !
rachel is offline        Reply With Quote Quick reply to this message
