Go Back   HeliFreak > R/C Helicopter Support > Antique Out of Production and Vintage Helicopters > Outrage RC > Outrage 550
Outrage 550 Outrage 550 Helicopter Factory Support Forum
Old 10-13-2008, 04:31 PM   #21 (permalink)
Originally Posted by airsoft1779 View Post
could useing 2 3s 2200 packs from their 450 w/ a z20 motor work. only for sport flyin. ive seen a bunch of ppl do this w/ their g550, but then again, that bird is LIGHT. just an idea for those budget flyers.
Not worth it due to short flight time, and very short pack life. Your packs will be toast in just a few flights.
Just a guy and his heli....
LITHIUMSTATIC is offline        Reply With Quote Quick reply to this message
Old 10-15-2008, 05:46 AM   #22 (permalink)
Registered User
This is a lot larger machine than the g550 and I am not sure you could get it to CG without adding weight with 2 x 2200mah packs.
William James
Old 10-17-2008, 08:57 AM   #23 (permalink)
anybody have the rtf weight w/ batterys and everything in it?
airsoft1779 is offline        Reply With Quote Quick reply to this message
Old 10-17-2008, 11:02 AM   #24 (permalink)
the 550 is around the 3kg mark depending on what gear you put in it. Mines a smidge over. HCs is a smidge under i think.
Ade
adrian@accurc.com direct email
support@accurc.com AccuRC support
plus.google.com/u/0/+AdrianChapmanlaw/ Me on google+
www.spartan-rc.com probably the best flybarless unit
Ade_Law is online now        Reply With Quote Quick reply to this message
Old 10-17-2008, 11:24 AM   #25 (permalink)
Don't think the 2200 would work well in it, I was told that My 3300 mah batteries were way to light for CoG and I'd need something closer to a 5000 MAh in weight . That and like others have said the batteries would be toast after a few flights.
Oxy3 Tareq edition
Oxy 3
Trex 470LM
jujiro is offline        Reply With Quote Quick reply to this message
Old 10-17-2008, 06:38 PM   #26 (permalink)
Ade
3kg RTF? or the airframe alone?
Old 10-18-2008, 02:47 AM   #27 (permalink)
rtf
Old 10-23-2008, 12:05 PM   #28 (permalink)
I am currently flying the A-40 10-L turbine motor, and thus far, is the most effecient, and powerful motor for this heli, on 6s. It is more consistant throughout the pack, and has some serious torque. I love this motor.
I have a Scorpion motor which is a 1380 KV motor, that I will be testing next week. Will let you know what the outcome is.
As far as the hacker. Super hard 3-d, and big flying using all the pitch, The Hacker runs about 100 degrees, and the batteries get no hotter than 115. Usually around 100. This is a serious set up thus far.
Craig
Craig Martin
Ernie is offline        Reply With Quote Quick reply to this message
Old 10-23-2008, 12:26 PM   #29 (permalink)
You will kill a 2200 pack in short order on a z20a powered G550 which is a bit lighter than the Outrage 550 numbers I've seen. Even keeping the flights around 3 minutes will draw too much from such small capacity packs. You could hover, but thats about it.
My G550 is 4.7lbs auw with 6s 3700.
-TREX600NSP - TREX500ESP -TREX450FBL - TREX250 - CHP GAUI 550 - OXY3 - 30% EG Aircraft MX2 DLE55 -
JaggedEdge is offline        Reply With Quote Quick reply to this message
Old 10-23-2008, 08:10 PM   #30 (permalink)
I've got the Neu 1907h 1y motor to try in mine. It's 1400 kv using a 12 tooth pinion..
Bill Erickson, Did you crash again?? PENDEJO
H to the C is offline        Reply With Quote Quick reply to this message
Old 10-24-2008, 01:37 PM   #31 (permalink)
Let us know how it compares to the Zpower.
Old 10-30-2008, 02:45 PM   #32 (permalink)
What's the tooth count on the O550?
Also weight on it looks similar to the Logo500 and I can tell you that 6S 5000 packs on this size machine absolutely rips. I think Outrage is making the right move by going into this size electric.
Mikado Model Helicopters
Edge Blades
Big Fil is offline        Reply With Quote Quick reply to this message
Old 10-30-2008, 02:47 PM   #33 (permalink)
140
Old 10-30-2008, 05:57 PM   #34 (permalink)
The Capi
Here is what my first iteration of my O550 setup is. Opinions and suggestions welcomed
Power by a 2A 5V BEC
- Spartan gyro and 8900G tail servo
- R790 Rx
Powered by a 5A 8V BEC
- Ko Propo KO PDS 2123 Digital FET
HV85 esc
Scorpion something motor
Old 10-30-2008, 07:02 PM   #35 (permalink)
Guys I must say the Neu 1407 1y motor is freakn insane on this heli. i'm using a 10 and 11 tooth pinion.
Old 10-30-2008, 07:02 PM   #36 (permalink)
The Capi
HC have you tried the Scorpion motor ?
Old 10-30-2008, 10:11 PM   #37 (permalink)
no, I'm to happy with the NEU.
Old 10-30-2008, 10:13 PM   #38 (permalink)
How were your fight times with the NEU 1907 compared to the Zpower?
Old 10-30-2008, 10:53 PM   #39 (permalink)
The Capi
Which ESC you using HC ?
Old 10-31-2008, 04:58 AM   #40 (permalink)
using hv 85, and phoenix 125. I'm also using the new outrage 6s 6000mah packs too. I'm getting 6 1/2 to 7 minutes with this setup turning around 2150 headspeed. The motor temps are way cool around 110 degrees and pack is close to the same.
I want to get alot more flights on this setup to get a real "set in stone " opinion. As of now I'm very happy with this setup...
Human Verification
