Go Back   HeliFreak > R/C Helicopters > Rotor Blades
Rotor Blades R/C Helicopter Rotor Blade Discussions
Old 02-25-2019, 06:03 PM   #1 (permalink)
Default Will this work? Paint to balance blades
I have an Edge 713 and a Switch 713. Both were the surviving blade of a corresponding light crash.
Edge: 202g
Switch: 210g
I was thinking of painting both blades to match them up. Painting would also, in theory, add weight. Maybe add an extra couple coats to the Edge to shore up the difference in weight.
Would this work?
Gaui X7 Tribunus 200A, Xnova XTS 4530-525, Xpert, iKon2
Epic MD-7 Mezon 130A, HKII-4525-520KV, Savox, SK-540
TSA 700E Mezon 130A,HK-4530-540KV LE, Torq, iKon
Gaui X5 HW 100A V3,Gaui 4020-910,KST, iKon
lucidchaos is offline        Reply With Quote Quick reply to this message
Old 02-25-2019, 06:09 PM   #2 (permalink)
Yes. I have a set of mismatched 550mm Cyclones Ive flown like 20 times from two different sets.. One is clearcoated with a few grams to balance evenly.
I did it with two Cyclones though.. I would hope the Edge and the Switch are the same. Well, you will find out real fast when you try them out.
....... Arf! ARf! ARFFFArFARFF! Arf. ......
Align 550e & (Got me some more canopy nutz, Jack.) Gaui X7 filled to the brim with expensively reliable goodies ... (Somehow I have the parts for like fo ...wait... nevermind. )
Dogdipstick is offline        Reply With Quote Quick reply to this message
Old 02-25-2019, 07:50 PM   #3 (permalink)
Check the CGs of the blades. If they're not exactly in the same spot, a lead weight may be favorable.
Also keep in mind that painting them alters the airfoil thickness.
Johnny31297 is online now        Reply With Quote Quick reply to this message
Old 02-25-2019, 08:06 PM   #4 (permalink)
Yeah, I would plan to measure CG before painting and balance them out with more clear coat on one side. Was also thinking of doing fluorescent orange on the bottom and chartreuse on the top before clear coating.
I thought about adding weight without paint, but haven't the slightest clue how I would go about adding lead.
If this flies, painted blades should fly
T-Rex 550 ONEBLADE first test (3 min 7 sec)
Old 02-26-2019, 12:49 PM   #5 (permalink)
Simple. Cast a cylindrical lead plug of the desired weight, drill a hole into the blade skin at the right spanwise radius right behind the spar, insert lead plug with resin, let it cure, done.
Old 02-26-2019, 08:49 PM   #6 (permalink)
OK that makes sense, thanks. I've always flown matched pairs, with exception of 450 size where I just used tape.
