Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade Nano S2
Like Tree81Likes
Old 07-10-2019, 09:28 PM   #161 (permalink)
Did you just hold a lighter on the pinion to get it off? I tried once and gave up.
xoexoe is online now        Reply With Quote Quick reply to this message
Old 07-10-2019, 10:00 PM   #162 (permalink)
Just pulled it off with a pair of pliers. It was pretty easy.
Ah Clem likes this.
Keith - MSH Brain2 Beta Team
Raptor E700 RMJ Nitro | Synergy N556 | Synergy 516 | T-REX 470LP
For FrSky help visit my thread: https://tinyurl.com/y3b3vu3k
https://kc3dprint.com - 3D Printing on Demand and 3D Printed RC Helicopter Upgrades
Number is offline        Reply With Quote Quick reply to this message
Old 07-11-2019, 08:32 AM   #163 (permalink)
The trick is to use a pair of needle nose and pull the pinion off with the pliers as wedge... don't actually grab the pinion with them. Stick the pliers under the pinion and leverage does the rest.
Ah Clem likes this.
Old 07-13-2019, 08:13 PM   #164 (permalink)
Took mine to the gym again and had some fun. Teased my 480 a little bit
Nano S2 | Flying in the Gym with Upgraded Motors (2 min 19 sec)
Me_How and xoexoe like this.
Old 07-13-2019, 08:41 PM   #165 (permalink)
Awesome man !
Number likes this.
Harder, Faster, Louder.....works for Me !
Brick is offline        Reply With Quote Quick reply to this message
Old 07-14-2019, 12:08 AM   #166 (permalink)
Inspiring!!!!
navigator2011
Oxy3 255 / Oxy2 190 FE + 190 Sport / Fusion 180 / Trex 150X / Blade mCPX BL2 / Brushless Nano S2 / Spektrum DX9.
navigator2011 is offline        Reply With Quote Quick reply to this message
Old 07-15-2019, 11:22 PM   #167 (permalink)
Default What did you do with your Nano S2 today?
That 480 was so jealous. Great flying.
Today I finally fixed up my S2, which only involved a new feathering shaft and new blades.. my KBDD blades broke last week after a major crash.
I did have replacement KBDDs, but instead I installed a pair of MicroHeli reflective blades I found in a hidden box. They look great. I mean, the overall color scheme of the heli is ugly as poop, but the blades themselves are nice.
They flew great. Love ‘em.
Put 3 packs through the S2. Only flip practice.
Yesterday I flew the CP X. 5 packs. I really enjoy having both.
Number and Chris1683 like this.
Old 07-20-2019, 03:00 PM   #168 (permalink)
Anyone looking for pinions for use with the Micro Motor Warehouse or BetaFPV motor upgrade I got mine from here. Took 18 days from order to in my mailbox.
https://www.ebay.com/itm/5PCS-7-Teet...drwndLTeFuruv8
Old 08-03-2019, 04:36 AM   #169 (permalink)
Anyone having issues with their s2?
Mine just randomly starts to spin
Bought 2,
First one would go nuts when 100% throttle given.
Second one it’s random, cant figure out any patterned
alibaloch94 is offline        Reply With Quote Quick reply to this message
Old 08-03-2019, 06:21 AM   #170 (permalink)
Bought 2,
Try a different battery? I had an blade msr s that would randomly spool up and quit and so forth on one battery pack. Other packs flew fine...
Spektrum DX8G2, AccuRC Simulator
Blade Scout CX, MSR S, Nano S2, 230s V2, 360CFX, NanoQX
Oxy 4 MAX
Old 08-03-2019, 10:39 AM   #171 (permalink)
Are you in 3D mode with throttle hold on? If it starts to spin when you’re in the mode above, that’s a known issue with the S2. You need to adjust the throttle output for throttle hold in some way so that it sends it out -130% if I remember correctly. .
Old 08-03-2019, 10:53 AM   #172 (permalink)
Installed Rakon swash, DFC blade grips. Stability improved and no more of the bearing popping out of the swash after a crash. This tiny beast is almost a sim replacement, plus it is way more fun.
Tried 300mah 1S with the high power UMX adapter, longer run times but felt really bogged and less responsive to pitch commands, I would not recommend the battery. Love the 220 mag though!
MiguelBain is offline        Reply With Quote Quick reply to this message
Old 08-05-2019, 01:59 PM   #173 (permalink)
Yes i have tried the throttle cut to 130% nothing helps.
Man these lower canopy mounts are soooo fragile.
I Broke them on 1st crash.
2 of my friends broke them on 1-2 crashes.
And you have to replace the whole body
Wow not liking this S2, at all
Old 08-05-2019, 07:16 PM   #174 (permalink)
Did you tie the throttle cut option to switch H?
Old 08-06-2019, 06:36 AM   #175 (permalink)
Throttle hold needs to be on switch 'H' (dx8g2) ... Throttle cut needs to be mixed in (not said in the manual) as Throttle hold does absolutely nothing without throttle cut as well....
Oxy 4 MAX
Old 08-11-2019, 09:58 PM   #176 (permalink)
Well I got my S2 a couple days ago spent 2 days trying to get it to work with mt DX6i. But to no avail . So I ordered a DX6 3G that should come in tomorrow. The little bit I have flown it and got it to be somewhat stable was enjoyable. But evetime I got it trimmed out the battery would die. When I put a new battery in I would have to re trim it all over again. Hopping with the DX6 and the better compatibility to the S2. That things will go much better
Krugerw357 is offline        Reply With Quote Quick reply to this message
Old 08-11-2019, 11:45 PM   #177 (permalink)
The DX6 through DX9 latest gen is great. Let us know if you need help getting that set up.
— Brian —
— Oxy 2 / 3 / 4 Max — S2 & CP X — 150X — iKON/Spirit — Horus X10S — OpenTX —
Old 08-12-2019, 01:11 AM   #178 (permalink)
Are the setup instructions in the S2 manual accurate for the DX6?
Old 08-12-2019, 01:46 AM   #179 (permalink)
From my memory there is one modification you need to do regarding throttle hold/throttle cut. But it’s not a DX6 issue, it’s an S2 issue. When in 3D mode, going into throttle hold does not kill the motor. So you need to modify what the transmitter sends during throttle hold from the default -100 to -130.
It’s easy to describe how to do once you get he new transmitter.
— Brian —
Old 08-12-2019, 01:49 AM   #180 (permalink)
..this is a good thread if you haven’t read it. https://www.helifreak.com/showthread.php?t=826717
— Brian —
