Go Back   HeliFreak > R/C Helicopter Support > KDS Helicopters General Discussion
KDS Helicopters General Discussion KDS Helicopters General Discussion
Like Tree2Likes
Old 03-30-2019, 02:33 PM   #1 (permalink)
Default Kds a7
Anybody have pics of the new kds a7, found some last night but can't find them again.
Oxy2 215 sport / Oxy4 325 pro stretched to 360
Goblin fireball / 380 / 500 sport / kraken 580
Kds Chase 360 / 470l / 550x / 650x Dominator / xlpower 550 / 700
beastx / Helithunder( https://www.youtube.com/channel/UC1X...s3ZRqyqpkMA11Q )
Helithunder is offline        Reply With Quote Quick reply to this message
Old 03-31-2019, 06:23 PM   #2 (permalink)
Here is a few
https://www.helifreak.com/showthread...32#post7735585
Rasmus Fauske
MD700 v2 for F3C, MD 700 v2 for 3D, M5-Sport, MD600 and a few Oxys and a MSH P380 Evo
rfauske is offline        Reply With Quote Quick reply to this message
Old 04-02-2019, 11:28 AM   #3 (permalink)
It looks like they also changed the one way.
goof2 is offline        Reply With Quote Quick reply to this message
Old 04-03-2019, 12:59 AM   #4 (permalink)
Also the motor pinion seems extremely close to the crown gear. Is this the same as on the Agile 7.2?
If so, does it cause any problems with wear on the crown gear?
dan-uk is offline        Reply With Quote Quick reply to this message
Old 04-08-2019, 05:15 PM   #5 (permalink)
Almost done building mine 🙂
Rasmus Fauske
Old 04-08-2019, 11:09 PM   #6 (permalink)
Default A7
Please share more pics of your a7 and what did you use for electronics? What's you're overal opinion of build quality?
Old 04-08-2019, 11:31 PM   #7 (permalink)
Default Agile a7
Will a printed manual be included in the kit or a online manual like the chase 360? Thanks for any help.
Old 04-10-2019, 06:12 AM   #8 (permalink)
I'm pretty interested in the A7 - please tell us where we can find the manual, and also what components you are using.
#749: The end won't be for everyone. The choice, to know, will be yours
-Let's Go Brandon!!!
Skeezix is offline        Reply With Quote Quick reply to this message
Old 04-10-2019, 06:27 AM   #9 (permalink)
Hoping to pick up mine soon. They were supposedly out of stock at THB.
Tengu motor or xnova?
Old 04-10-2019, 11:30 AM   #10 (permalink)
Manual: http://static.rc-batteri.no/manual/K...7%20manual.pdf
It is not included in the kit in printed form.
The quality feel was like the 7.2 so that was good, and the build was easy and quick. Most larger things are premounted so you just loosen and add locktite. THe CF sides do need 5 minutes with wet sanding before building, after that they are great
I am using a Tengu 4525, there is not room for a 4530 without modifying the canopy ..
My setup is rather cheap only expensive thing is the motor.
Servos: KDS DS725+DS525
FBL: Ebar v2 (or Spirit if I can not get it like I want)
Motor: Tengu 4525
ESC: ZTW Gecko 150A Opto (12S), Hae not used it before so its to test it.
And KDlipo 5000mah/6S/70C packs.
Rasmus Fauske
Old 04-10-2019, 09:37 PM   #11 (permalink)
Motor: Tengu 4525
Thanks for the link for manual and your electronics setup. Please post more pics showing a full side on view.
Old 04-11-2019, 12:33 AM   #12 (permalink)
I'm surprised you can't get a 4530 under the canopy. I would have thought that motor size should be standard for the A7.
Is the limitation relating to the Tengu 4530 spec or will no 4530 motor fit under the canopy?
Old 04-11-2019, 01:54 AM   #13 (permalink)
I was a bit suprised myselfe aswell. But I guess you could move the mounts a bit or just make a cutout in the canopy. It is hitting in the front top part of the motor. Nothing else. But the motor I tried was the KDS 4730, but the size there seems to match a normal 4530.
Attached is two bad pics of the side, those were the only one got now but I can take some new ones later.
ID:	787277   Click image for larger version
Rasmus Fauske
Old 04-11-2019, 08:57 PM   #14 (permalink)
Thanks for the info.
I heard that Egodrift are bringing out a new high performance spec of the 4525/4530 motors, but I can't find any update on their facebook page. Any idea when they will be available?
EDIT: Turns out that the new spec is on their website. 4530 HT.
Last edited by dan-uk; 04-11-2019 at 09:00 PM.. Reason: Clarified info from Egodrift website
Old 04-13-2019, 10:58 AM   #15 (permalink)
Some pics thats a bit better 🙂
ID:	787581   Click image for larger version
ID:	787583   Click image for larger version
ID:	787585   Click image for larger version
ID:	787587   Click image for larger version
Rasmus Fauske
Old 04-14-2019, 08:37 AM   #16 (permalink)
First one ? 🙂
Rasmus Fauske
Old 04-14-2019, 09:12 AM   #17 (permalink)
Killer looking heli, let us know how the maiden went. What is the significance of the symbols after the question mark.
Old 04-14-2019, 10:24 AM   #18 (permalink)
Do you have an all up weight, excluding batteries?
Gob Kraken |Gob 700 BT 'T' | Gob 770 Comp | SoXos Strike 7 | Henseleit TDR, TDSF & TDR2 | Kasama Dune | OMP M1&M2 | UK stockist for OMPHobby M1/M2 ScotiaRC.co.uk
Old 04-14-2019, 01:00 PM   #19 (permalink)
Maiden went fine, but gov in the esc was so-so. Other then that all good. Will also replace the kbdd tail blades as they were humming a bit.
Weight is 3.8kg without batteries but with battery tray and canopy. so AUW around 5.2-5.4 depending on the batteries use I whould think.
Smoggie likes this.
Rasmus Fauske
Old 05-02-2019, 07:40 PM   #20 (permalink)
Any feedback on the A7? Still choosing electronics for mine...
