100 Class Electric Helicopters 100 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
#1 (permalink) |
![]() Does anyone know if the k110 tx will bind to the k130?
I have been looking on Banggood and some say yes others say no. Just wondering if anyone has bought a k130 and successfuly got it to bind to there k110 tx. |
#2 (permalink) |
![]() In the QnA on BangGood someone asked. The reply is that the 110 generation X6 would need a factory firmware update to be compatible with the 130. You could search the K130 thread on RCG for an answer.
CrashyCrashy |
#3 (permalink) |
![]() I had no issues binding the X6 with the 130. No update was needed.
#4 (permalink) |
![]() It should bind OK, but there was some discussion as to whether there might be a range issue. I've only tried my 130 with the X6 on the ground and it worked fine. If you are going to try it however, I would give it a good range test first before flying.
#6 (permalink) |
![]() How about getting a multi-protocol transmitter?
![]() For the XK helis you need the Futaba S-FHSS protocol which is supported by the CC2500 HF-modul. The newer HF-modules are 4-in-1. Another thing: The XK X6 radio doesn't have a timer function, correct? How can you even fly helis with it when you need to know how you should run the throttle? Comparision: The OpenSource DeviationTX firmware (with the Walkera Devo10 transmitter) supports 4 timer: - 1 CountDown (e.g. starting at 6,5 minutes) - 2 CountUp - 3 Permanent (how many minutes/hours you have on a model slot) - 4 Unused Do you always fly the 1s or 2s lipos to the very end until the ESC kicks in?
Walkera Devo 10/DeviationTX (12CH DSMx & telemetry)...Ex-DX8...Blade 4503D...Walkera V120D02s...XK K110...Blade 200QX quad...Ex-NanoCPX...Ex-120SR...StrykerQ (LEDs, M2 tuning)...Ex-MPX EGP...PPZ P51-D...PZ Wildcat (searching fuselage-firewall) |
#7 (permalink) |
![]() No, I fly upto the heli seems weak then right way land it. I fly with 1S lipo.
XK110 is run with 1s obcouse. I have Spectrum dsm transmitter too. |
#8 (permalink) |
![]() I have ordered the xk130 heli to be binded with XK110's TX expecting it works.
I will update this if works. |
#9 (permalink) | |
![]() Quote:
__________________ Team USED ![]() Shape S8,G700,G500,Shuttle 550,Trex 500 E/EFL Pro,Oxy 3(2),B400(5),450X,360CFX,Fusion 270(2),230S (V1/V2),200S,120S,Nano (CPS/S2),K110/120/130 |
