Like Tree2Likes
Old 04-03-2019, 08:16 AM   #1 (permalink)
Default making vstabi larger
i'm sure this has been asked before but nothing comes up when i search for it.
i'm using a 13 inch laptop and the vstabi software uses about a 1/3rd of the screen ,my 55 year old eyes struggle to see it even with glasses ,plus the buttons on the bottom are just visible, is there a way to make it bigger without changing screen resolution as that doesn't get me the buttons, thanks
Anthony
Anthony
oxy 3 ikon , synergy 516 cgy760-r x2 , xl power specter cgy 760 , futaba
anthony1 is offline        Reply With Quote Quick reply to this message
Old 04-03-2019, 03:58 PM   #2 (permalink)
https://www.vstabi.info/en/node/1961#12
Code:
How can i display the PC software in a HD screen?
To get a bigger view of the PC soft - just right-click on the desktop icon, then propertiers - and under "Target" add " -e2" (w/o " but with blank) for double size. You can also enter a scale of 1.2 or 3 or 4 or 4.7 if you like. the fonts are sized through your OS.
My custom charging case build
RCHN #633
Grimmy is offline        Reply With Quote Quick reply to this message
Old 04-03-2019, 07:49 PM   #3 (permalink)
i tried adding -e2 at the end of the line but the program wont start , when i removed it it started , where should i add the -e2
Anthony
Anthony
Old 04-03-2019, 10:18 PM   #4 (permalink)
Making it bigger by adding the -e2 at the end of the target under properties will only work if your Java is updated to the latest version.
Add the -e2 at the end and remember to add a space before the -e2. Have found that 2 is much too big so use 1.2 to start with.
Name:	Annotation 2019-04-04 051433.jpg
Gaui R5, Henseleit TDR, TDR2, TDF, TDS
VControl
Old hand at Planks
Old 04-04-2019, 01:06 AM   #5 (permalink)
Run the Windows Magnifier
MKMHC, LARCS ~ T-Rex 700e ~ VBar Control ~ my flight log
richardv is online now        Reply With Quote Quick reply to this message
Old 04-04-2019, 05:23 AM   #6 (permalink)
yes but that doesn't get me the buttons which are off screen mostly
Anthony
Anthony
Old 04-05-2019, 06:59 AM   #7 (permalink)
Is it just Mikado program or all programs?
For all programs there is a display setting to change font size. Well written programs will scale up so the text fits.
Andy from Sandy is offline        Reply With Quote Quick reply to this message
Old 04-05-2019, 09:35 AM   #8 (permalink)
The Mikado settings program uses Java, this does not scale perfectly with Windows fonts etc. If radio buttons are off the box for the program it means you are using a font scale that is too large to fit, so resetting Windows fonts normally restores this.
Some graphic drivers are also to blame, so make sure ALL your updates are done including latest Java and graphics drivers.
The -ex.x only works for Java based programs.
VControl
Old hand at Planks
Old 04-06-2019, 06:16 AM   #9 (permalink)
i updated java , ran windows update e, and when i add -e2 to the end of the line the program wont start . i'm adding it after the -u -n , i tried it on both my computers and it stops the program from starting on both, actually i cant use the second computer because when i do i get a constant timeout message and it says its not connected. i'm sure its a setting that needs changing but again i have no idea what
Anthony
Anthony
Old 04-06-2019, 08:14 AM   #10 (permalink)
Default Good product, difficult to use interface...
Well, I am in the same boat as previous poster. I am am older guy, (56) and I am pretty tech savvy. I Fly Jeti radios, use computers and smart phones daily, etc.
BUT I have also tried all the suggested ways to get the program visible/usable on my high end laptop to no avail.
VBAR may be the greatest thing since sliced bread, but if I can't see the program to set it up, not going to use it.
(Anyone want to buy a couple classic VBAR Blueline units with external gyro?)
TBeghtol is offline        Reply With Quote Quick reply to this message
Old 04-06-2019, 08:20 AM   #11 (permalink)
not trying to derail the thread, but using vcontrol and neo's, you don't need a pc. its pretty easy on the eyes too.. im 53
K2Freak likes this.
tonys-heli is online now        Reply With Quote Quick reply to this message
Old 04-06-2019, 08:06 PM   #12 (permalink)
i'm sure it is but deep down i'm a futaba flyer, have been my whole time in this hobby, plus it would be too expensive for me to change all of my stuff over to vbar , so what am i doing wrong why doesn't the -e2 work for me
Anthony
Anthony
Old 04-06-2019, 10:27 PM   #13 (permalink)
I had your same issues for a while when I got a new HD computer. Actually tried two different brands thinking the first was somehow causing the issues. I did find a workaround that worked. What I had to do was go into the video settings and reduce the screen resolution down to something like 1920 x 1080. It did affect everything else, but it got the Vbar screen to where I could use it. After I got finished, I just changed the resolution back to its native values.
Specter 700, Logo 700, Logo 690SX, Goblin 700, Trex 700DFC, Gaui X7, Trex600EFL Pro, Trex 600 ESP, Trex 500 ESP, DJI 550
Amain Hobbies Team Rep
rcflyerheli is offline        Reply With Quote Quick reply to this message
Old 04-06-2019, 11:59 PM   #14 (permalink)
Anthony
Try a number smaller than 2, say 1.2 as doubling the size it might not fit on your screen anymore and Java won’t start it.
VControl
Old hand at Planks
Old 04-08-2019, 08:19 PM   #15 (permalink)
i tried adding " -e1.2" to the end of the line but the program wont start if i remove it , it does start , ?
Anthony
Anthony
Old 04-09-2019, 12:15 AM   #16 (permalink)
Anthony
You did add it without the " and " as that is not required. only -e1.2 and remember to add a space before the -
VControl
Old hand at Planks
Old 04-09-2019, 05:39 AM   #17 (permalink)
yes just what is in the quotation marks
Anthony
Anthony
Old 04-09-2019, 10:36 PM   #18 (permalink)
Anthony
Mine works perfectly. Please check your Java version and run the remove older version from the Java website.
https://www.java.com/en/download/help/java_update.xml
ID:	787057   Click image for larger version
Name:	Neo Large.jpg
VControl
Old hand at Planks
Old 04-10-2019, 05:12 AM   #19 (permalink)
mine ends in "config_53 -u -n" should i change it to match yours?
Anthony
Old 04-10-2019, 05:19 AM   #20 (permalink)
well i tried changing it to match yours and the program doesn't start ,???
Anthony
Anthony
