Like Tree2Likes
Old 04-10-2019, 07:59 AM   #21 (permalink)
Originally Posted by anthony1 View Post
mine ends in "config_53 -u -n" should i change it to match yours?
You are using version 5.3 of the software. Is this for a Neo or older Vbar?
This does not work with 5.3 software for the older Vbars.
Gaui R5, Henseleit TDR, TDR2, TDF, TDS
VControl
Old hand at Planks
Old 04-10-2019, 08:09 AM   #22 (permalink)
https://www.helifreak.com/showthread.php?t=786568
Your question in 2017 where you did fix it.
VControl
Old hand at Planks
Old 04-10-2019, 08:48 AM   #23 (permalink)
its for the older vbar, actually the same one that i asked about in the older post, i remembered that i fixed it but couldn't find the old thread , i am going to try the same thing again hopefully it will work again , thanks for finding it , i tried searching but nothing came up, if it doesn't work i have some magnifying glasses i will use , i actually don't need it for very long once its setup there are minor changes to make and that's it
Anthony
oxy 3 ikon , synergy 516 cgy760-r x2 , futaba
anthony1 is offline        Reply With Quote Quick reply to this message
Old 04-10-2019, 10:20 AM   #24 (permalink)
Are we sure that you two are running the same version? That looks like there is the possibility that Anthony is running 5.3x version...
e/ beat me to it.
AMA 373608
Citizen #97
K2Freak is offline        Reply With Quote Quick reply to this message
Old 04-10-2019, 10:21 AM   #25 (permalink)
/e TWICE!
AMA 373608
Citizen #97
Old 04-10-2019, 07:40 PM   #26 (permalink)
ok i tried my old way and it worked , thank you ,
Anthony
Old 04-13-2019, 02:10 PM   #27 (permalink)
Default Yeah! Success
Thanks guys, following Anthony's instructions I have usable program now.
Many thanks for your assistance.
anthony1 likes this.
TBeghtol is offline        Reply With Quote Quick reply to this message
Old 04-21-2019, 08:37 PM   #28 (permalink)
So I just had to reinstall my Vstabi Neo software due to my Surface Pro 3 dying on me. When I open it, it was small, and I used the -e2 to make it bigger, but the font size was super small. I found the following fixed it for me so I could see the font in the software much much better:
On the Vstabi Neo icon on your desktop:
Right click -> Properties
Chose Open File Location
On the javaw -> Right Click -> Properties
Under the Compatibility tab, select Change high DPI settings
I checked the top box, the first drop down box is set at "I open this program"
I check the bottom box, and the bottom drop down menu is set to "System"
That made my font like 3 times larger than it was before.....so I can read it now!! I had to edit the first part and use -e1.2 as it fill me screen and actually went off my screen.
I've attached some pics to help show what I found. I put one on top of the other, of the Neo software, so show the difference it made for me. This is what works for my new Surface Pro 6. Your mileage may vary, depending on your machine.
ID:	788915   Click image for larger version
My custom charging case build
RCHN #633
Grimmy is offline        Reply With Quote Quick reply to this message
