Old 04-03-2019, 09:33 PM   #1 (permalink)
Default mini v bar gov and hobbywing v4
i'm trying to setup my hobbywing 40a v4 in my oxy 3 with a mini vbar(old one not neo) and its not behaving the way it does in mr mels video's, when i try to adjust the slider for the startup of the motor , it doesn't but feels like the slider is controlling the throttle not the place that it starts. i can get the motor to start but throttle hold doesn't turn the motor off and the motor gets faster as i move the slider. is there something i'm missing
Anthony
Anthony
oxy 3 ikon ,2 x synergy 516 streched cgy760-r , xl power specter cgy 760-r , futaba
anthony1 is online now        Reply With Quote Quick reply to this message
Old 04-03-2019, 10:20 PM   #2 (permalink)
Which TX ? Where is the slider located?
Gaui R5, Henseleit TDR, TDR2, TDF, TDS, TDSF
VControl
Old hand at Planks
Old 04-04-2019, 05:20 AM   #3 (permalink)
futaba t18sz . page 2 of the gov menu in vstabi . i have the endpoints calibrated for the esc but when i move the motor off slider the motor starts at 88% ,at 90% when i turn throttle hold off nothing happens, at 88% the motor comes on regardless of throttle hold being on or off.
Anthony
Anthony
Old 04-04-2019, 03:00 PM   #4 (permalink)
What exactly would you like to happen?
A slider feels like a variable output not a single value that is used for electric governors.
If you were using the throttle channel tied to the collective stick as is normal you would create a flat throttle curve so the output is fixed for desired head speed.
Futaba programming by default "knows" what throttle hold is to take throttle channel out put to 0.
If I remember correctly though you set the required head speed in one of the governor screens in the vstabi software. After that you define a switch to enable hold, and run.
Andy from Sandy is offline        Reply With Quote Quick reply to this message
Old 04-04-2019, 09:28 PM   #5 (permalink)
i would like to set the startup so there is no delay as in the mr mel video, but mine doesn't start at all , and when i do get it to start with the slider, throttle hold doesn't turn it off , right now my throttle curve is 0 -100% are you saying that i need to have a flat line curve of say 85%? before i set the startup and full speed part of the gov setup?
Anthony
Anthony
Old 04-04-2019, 09:48 PM   #6 (permalink)
I am still confused on what you have set on the TX. Futaba have HOLD as 17% by default for idle and they use CUT to stop the motor.
Please follow the settings explained here https://www.vstabi.info/en/node/438
And continue with the wizard to do setup, this will ensure that the correct channels and endpoints are set in TX for what the Vbar expects.
VControl
Old hand at Planks
Old 04-05-2019, 05:10 AM   #7 (permalink)
i don't use cut as its electric and not necessary , hold is still set at 17% . which is exactly the same setup as in my logo 480 , so i don't understand why its not working everything else is as it should be, i see -100 to +100 for throttle in the software and hold works in the software too ,just not on the gov screen
Anthony
Anthony
Old 04-05-2019, 06:52 AM   #8 (permalink)
I changed that as I remember a change to the way the governor is setup in the mini v-bar with the 5.34 software. You need to look at the 2 governor setup screens and in one of them you set the throttle percentage to use.
I cannot remember how you assign the switch you want to use but that might be on the tx screen where you set and calibrate the channels.
I am also pretty sure you will find setup information on the vstabi website. I would be inclined to follow Mikado to get it working initially and modify from there.
Old 04-05-2019, 01:28 PM   #9 (permalink)
i'm not trying to modify anything , this is for the initial setup . here's my roblem , in mr mels video he has his initial setting for power on set to around118% he flips out of throttle hold and after a brief pause the motor starts , he lowers the % to around 106% and there is no hesitation starting,
my scenario is the motor turns on at 89% at 90 % if i flick out of throttle hold the motor doesn't start (at all) at 89% the motor runs slowly but throttle hold wont turn it off only moving the slider back to 92% turns the motor off, this is totally different to the mr mel video, something is wrong or different but i cant figure out what
Anthony
Anthony
Old 04-05-2019, 07:03 PM   #10 (permalink)
ok . i have made some progress, throttle hold doesn't work on the gov screen but it does on the transmitter screen, if i have my throttle stick above 50% then the motor spools up but throttle hold doesn't stop it, so its in my transmitter somewhere, any ideas as to where to look
Anthony
Anthony
Old 04-05-2019, 07:50 PM   #11 (permalink)
done it , my mistake , i had at some point set throttle control to channel 6(collective) instead of channel 3(esc) i remember changing it but not sure why ,any way its sorted and it seems to work
Anthony
Anthony
