Like Tree6Likes
  • 1 Post By gmann
  • 1 Post By racer-g
  • 1 Post By gmann
  • 1 Post By gmann
  • 1 Post By senzafine
  • 1 Post By Mr.Andersen
Old 04-05-2019, 04:40 PM   #1 (permalink)
Default 550sx head thrust bearings shot
Well, something funny was going in my my 550SX head, so took apart to discover both thrust beatings totally eaten up and disintegrating
Yes they were lubed. This happen to anyone else?
Hundreds of flights over a couple years.
I'm going to order part #2349
https://shop.mikadousa.com/02349-Thr...4x5_p_139.html
What about these instead?? (same size)
https://www.bocabearings.com/products/f6-14g-302
I'd rather not have this issue happen again...
Thanks.
gmann is offline        Reply With Quote Quick reply to this message
Old 04-05-2019, 06:21 PM   #2 (permalink)
Hundreds of flights? . Not seeing the issue. Normal wear.
Thickfog is online now        Reply With Quote Quick reply to this message
Old 04-05-2019, 06:29 PM   #3 (permalink)
They don't last that long and lube never stays in there. I rebuild the head more than anything else on my machines. When there even a little notchy I can see boom supports shaking more on hard cyclic than with good bearings.
Wayne
Logo 480 / Logo 600sx / Logo 690 / Logo 700 / Vbar Control
Mentalic is offline        Reply With Quote Quick reply to this message
Old 04-05-2019, 07:45 PM   #4 (permalink)
yup, no grease.
it takes time to do that.. it didn't happen all of the sudden..
tonys-heli is online now        Reply With Quote Quick reply to this message
Old 04-05-2019, 08:06 PM   #5 (permalink)
Thanks guys. Will keep an eye on this and inspect more often...
senzafine likes this.
Old 04-07-2019, 09:52 PM   #6 (permalink)
I assume you have installed thrusts with separator facing outside.
the better way to install it opposite way so the balls dont run over the separator and wear it.
It was a topic about it but i cant find the link.
Quick search.
In picture is wrong installation.
racer-g is online now        Reply With Quote Quick reply to this message
Old 04-07-2019, 10:22 PM   #7 (permalink)
This is correct installation.
And dont worry about catching the grease.It will throw away once you spool up anyway
Old 04-07-2019, 11:27 PM   #8 (permalink)
Every Align and Tarot manual shows bearing retainer with flat side outboard, to retain grease.
Please enlighten on reversal. Less wear on cups? Not sure I can see that. Appears to me that retainer floats between the cups.
Dave
dwoof is offline        Reply With Quote Quick reply to this message
Old 04-07-2019, 11:43 PM   #9 (permalink)
I got the same thing. It's the Logo 600SX with about 200 flights and have not opened the head since the 1st day.
I will open and re-apply the grease to thrust bearings every 50 flights
ddhuans is online now        Reply With Quote Quick reply to this message
Old 04-07-2019, 11:54 PM   #10 (permalink)
But this is Mikado Logo
PS
Also,wearenes depends on headspeed.
Old 04-08-2019, 12:19 AM   #11 (permalink)
PS
No,you're wrong.
Old 04-08-2019, 01:26 AM   #12 (permalink)
It says that mounting direction is not critical(so neither you are right ) but we all know that mikado manuals are not perfect.
Besides, they are not updating manuals and some of them contain minor mistakes like shimming main gear or pinion but thats another topic.
You can assemble thrusts the way you want but my, and others experience show that it needs to be assembled the way i showed on picture.
Here is old thread on vstabi forum.
They discussing logo xtreme but the idea is the same for all thrusts we use in our models.
https://www.vstabi.info/forum/read.php?39,95609
So...do a quick search before blaming someone he is wrong...
PS
Read also MrMel's opinion
https://www.helifreak.com/showthread...st#post3874765
STAZZ likes this.
Old 04-08-2019, 09:27 AM   #13 (permalink)
I have always put my Thrust Bearings in with the exposed balls facing in (Towards the Shaft)
Me too on all models. Correct the manual says "mounting direction not critical" - well, their manual leaves a lot to be desired...
And thanks for the pic of Logo 600 bearings. Mine are totally eaten away...
taoY likes this.
Old 04-08-2019, 12:00 PM   #14 (permalink)
if your bearings are bad in the head, I wonder what your tail thrust bearings look like.
Old 04-08-2019, 12:18 PM   #15 (permalink)
this post made me want to check my tail thrust bearings and they were both quite rusty & not good looking. I was having weird tail behavior and im almost sure it was that.
OXY 5 | OXY 2
LYNX | AccuRC | Scorpion | Xpert | HRB USA | V-Bar | VTX
xcellfury is offline        Reply With Quote Quick reply to this message
Old 04-08-2019, 02:41 PM   #16 (permalink)
You're right Tony - I pulled the tail apart the same day and they were fine, just a little rusty - cleaned up and relubed.
tonys-heli likes this.
Old 04-08-2019, 02:52 PM   #17 (permalink)
I also prefer to put my thrust washers with the bracket in vs out. I use Botolube and I am amazed that most of the time when I tear it down every 6 months or so there is still some on the balls. Anytime any head bearings get notchy or im in doubt I replace them. I've had some weird shakes and shimmies over the years and it's just not worth it to me to save a few bucks.
Mile high fun - https://rcheli.club/
senzafine is offline        Reply With Quote Quick reply to this message
Old 04-08-2019, 03:57 PM   #18 (permalink)
I did the exact same thing but found my grips with a bit of play so I replaced them & its good & smooth now
OXY 5 | OXY 2
Old 04-14-2019, 02:56 PM   #19 (permalink)
Quick search.
Im in the process of changing out the thrust bearings of my 600SX and mounted them separator facing inwards when mounting them last time and now the only wear is on the balls and races and there where remarkable amounts of grease there to considering the race not holding onto the grease mounted these way.
Just saying.
racer-g likes this.
Logo 600SX
Warp 360
Chase 360
Exo 500
Mr.Andersen is offline        Reply With Quote Quick reply to this message
