Old 04-12-2019, 10:40 AM   #1 (permalink)
Default Neo Vgov rpm not stable
Running Neo vgov with vcontrol on scorp esc. From low to high throttle Rpm varies than slowly settles to requested headspeed. What did i miss here?
logo 600sx, 480, mcps bl.
Dsss is offline        Reply With Quote Quick reply to this message
Old 04-12-2019, 09:42 PM   #2 (permalink)
Are you on default settings? Does this happen in the air or on the bench? Latest Scorpion firmware and VBC updates?
Gaui R5, Henseleit TDR, TDR2, TDF, TDS, TDSF
VControl
Old hand at Planks
Old 04-12-2019, 11:09 PM   #3 (permalink)
On bench and in air. Everything is on newest version. 58 scorpion. I may make a video if I can figure how to post it.
Strange rpm goes up with stick than a few seconds later is slowly goes to requested headspeed.
80a Scorp.
Old 04-13-2019, 07:00 AM   #4 (permalink)
80a Scorp.
I had my 200a do some pulsating issues. I think it was because it didnít load the default settings for tribunus when I switched from hobbywing. I ended up disabling tribunus app then reloading it to get it to load the default values for tribunus. Canít remember exactly how I did it but it was in the instructions somewhere on scorpion site.
tshelby73 is offline        Reply With Quote Quick reply to this message
Old 04-13-2019, 11:45 AM   #5 (permalink)
VBar governor does use a function calling collective addition as you increase collective, you WILL see an increase in rpm on the bench without blades/load. In the air it should not be noticeable unless your collective addition is set to high.
VControl
Old hand at Planks
Old 04-13-2019, 11:46 AM   #6 (permalink)
So you disable the app in your vcontrol and enable it to start from scratch?
Old 04-13-2019, 08:08 PM   #7 (permalink)
Interesting , i will check it in the air once again ,and report my findings here. thank you
Old 04-13-2019, 08:45 PM   #8 (permalink)
I followed the instructions to use tribunus governor then switched back to vbar governor to load default values.
Old 04-14-2019, 07:10 PM   #9 (permalink)
You may want to look at this thread.
https://www.vstabi.info/forum/read.php?44,138193
(2) Protos Max Leggero/VBarNeo/Tribunus200/VTX717, Blade 550X/VBarNeo/Hobbywing120/Rail556, VBar Control Touch
Caeguy is offline        Reply With Quote Quick reply to this message
Old 04-14-2019, 09:28 PM   #10 (permalink)
Odd on that link ,even logged in says i do not have permission to view this form.
Old 04-14-2019, 11:39 PM   #11 (permalink)
You need to send an email to vstabi forum so that they open the VBar Control forums for you. Only registered users of a VBC can get access.
This is what is posted there
Best preconditions are:
- blades (fold method) are at 0deg in setup (locked) position
- Cyclic Ring set up as best in hover collective point
- tail throws set in useful ranges
- paddle sim and pitch pump are zeroed
- style is at 70...100
- useful gear/kv/cell count setup for the target RPM
Step 1 - Basic Gov settings:
- Gov Gain to 0
- Gov I to 0
- Spoolup at zero collective
- dial in basic throttle unless HS matches
- go to a hover, dial in collective add unless HS will be kept under hover too
- do a medium climb, check hs, possibly add some collective add again
- set cyclic add to 1/3 of collective add
- turn back gov gain and Integral
Step 2 - Basic Tail together with Gov:
- lower tail gain (e.g. to 40)
- hover and do medium climbs
- on a CW heli - if nose turns to left in the climbs - increase collective torque precomp in tail
- if it stays approx. - the optimum has been found.
- if it still turns although the precomp is e.g. at 60 - decrease (!) the collective add of the governor (tail is overloaded by too hard gov'ing)
- set cyclic precomp to 1/3 of collective precomp
Step 3 - Tail gain:
- just increase ad needed to hold the tail. The VBars have a internal gain calculation depending on the flight situation to avoid oscillations - e.g. in fast flight.
- If the tail holds well - not more gain needed
Step 4 - Elevator Precomp:
- lower main rotor gain to 30-40 (approx 1/2 of the usual recommended gain)
- from a hover - start a climbout
- watch the tail boom. If it hangs down first - increase the precomp
All steps below can be done in different order:
Step 5a - Trim flight
- as the tail torque precomp changes the tail "center" - the TF will be done after the steps above to be perfect
- perform the trim flight on a calm day
- lift off, hover hands off for some seconds, repeat a few times
- if a hands off pirouette stays in place - end trim flight
Step 5b - Swash Optimizer:
- dial in the target agility, this resets the cyclic optimizers!
- do some constant rolls and flips in all 4 directions with approx. 50-70% of the stick throw.
- lets say 5-10 each direction will be ok, turn the optimizer off
Step 5c - Tail Optimizers:
- do some pirouettes in each direction
- also some stops (5 each side will be ok)
- turn the optimizer off
- if the stop is a bit softer on one side (due some physics) - increase the stop gain, see if it helps
- if it won't help - lower the tail acceleration which gives a bit softer response but more equal behaviour (optional, lower down to 45 ans less, often used on weak scale tails with 30)
Step 5d - Main Gain:
- increase unless you won't notice changes anymore.
- not critical - so it is possible to keep it at 80 on a usual helicopter
Step 5e - the rest:
- dial in Style as preferred (low = more smack, high = more precise)
- same with paddle sim
- and pitch pump (but - if using this - the tail will show up the limit again ...)
And of course - to be perfect - most of this can be done for each bank.
VControl
Old hand at Planks
