Like Tree1Likes
  • 1 Post By 1BOHO
Closed Thread
Old 04-12-2019, 04:35 PM   #1 (permalink)
Default "Kyocera" printer diy brushless
Hi
This is my work thus far converting the motor for model use.
ID:	787443   Click image for larger version
ID:	787445   Click image for larger version
ID:	787447   Click image for larger version
ID:	787449   Click image for larger version
ID:	787453   Click image for larger version
ID:	787455   Click image for larger version
Vinger likes this.
1BOHO is online now        Quick reply to this message
Old 04-14-2019, 07:49 AM   #2 (permalink)
Thanks Vinger.
@ Hunter
Why re task old theories with new technology? Use new theories no longer theory but proven in the IEEE labs with new tech. I really hope that's good enough for us. And that nothing done in our hobby world challenges these real experts information. If you track here with that eventually you will see the YY SL series connected to the DD SL so its both parallel and serial topology. Similar is zig zag transformer tech.
Another explanation of the shifted wind topologies resides in the NEU thread. I think I will wind it a half turn motor but Im still deciding if that's what I want to do.
A connection diagram for a hetro polar array is here
https://www.helifreak.com/showthread.php?t=817007
Old 04-16-2019, 08:08 PM   #3 (permalink)
My hope is that the wye + delta will attenuate the triplen that sits on top of a 12N8P ABC wind. You see there is very little harmonic content in the higher orders.
I was going to use all of the original bell then decided I could gain efficiency by making it lighter. So I parted off the face leaving only the flux ring. Ill make the endbell from aluminum. Im considering on piece as I don't know if a steel shaft is essential on an airplane. An 8mm in aluminum may hold and be lighter. I'm not sure I guess I have to look at shear, tensile, and yield values.
Name:	wye motor 2.jpg
ID:	788205   Click image for larger version
Name:	simplified gerling.jpg
ID:	788207   Click image for larger version
ID:	788209   Click image for larger version
Old 09-25-2019, 08:48 PM   #4 (permalink)
Changing things up a bit based on a paper CL sent about Y-D versus D-Y.
For a 12N8P the working is the forth so we try a shift of two slots and
connect D - Y.
Here is the YY SL machine bundled so far. In a Y-D u would never bundle the wye ends but instead hook up to what would have been the motor leads for the delta motor. The theory with the shift and series connection is we boost the working harmonic (4th), eliminate the fundamental, and lower the other subs. As its already a lesser motor than a 12N10 for torque production It wont work as good as it would on a 12N10P but it should improve the efficiency of the 8 pole machine
Thanks for your time and patience..
ID:	817729   Click image for larger version
ID:	817731   Click image for larger version
File Type: pdf A_New_Space_Harmonics_Minimization_Strat.pdf (519.5 KB, 33 views)
"Diese Flugzeuge werden von Clowns entworfen, die von Affen beaufsichtigt warden....."
Old 09-26-2019, 12:06 AM   #5 (permalink)
Closed Thread
