Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade Nano S2
Old 04-10-2019, 02:50 PM   #1 (permalink)
Default BLADE NANO S2 on Spektrum ix12 Help, Please...
If any of you are using an ix12 to fly your NANO S2, please snap some photos of how you have your 'PANIC' function setup in the 'MIXING' menu. I've done everything the instructions says to do plus tried a few different configurations and I can't get the 'PANIC' function to work.
I have 'PANIC' assigned to switch 'G' and on 'AUX 2' which is a 3 position switch. I have it setup on that switch because I like to keep switch assignments the same for all of my models and flight simulator.
The manual says to setup 'PANIC' on the 'I' button, but I couldn't get the NANO to respond to that switch assignment, either. These photos are screenshots of the way I have the 'MIXING' program in my radio, which I assume is for 'PANIC'. As you can see, it's setup to what the manual calls for, aside from the switch assignment. Am I missing something and just flat out doing it wrong?
SCHOOL ME!
Roban 800 size Super Scale AIRWOLF
BLADE 360 CFX 3S, BLADE mCP X BL2, BLADE NANO S2, SPEKTRUM iX20, SPEKTRUM iX12
carlos64030 is offline        Reply With Quote Quick reply to this message
Old 04-10-2019, 03:43 PM   #2 (permalink)
Start with the I button to rule out any weird 3-pos switch issues.
After you change your mixing switch to button I (momentary button), and if you depress and hold it, what is your GER channel doing? You don’t need your S2 on to check, just look at your channels on the left side of your screen. Is GER changing at all?
From memory it should go from 100 to 150 if you’re in the most basic flight mode. Or from 0 to 20, or from -100 to -150. Someone correct me if I’m wrong there. I never understood Spektrum’s mixing equation.
Brian Oxy 2 & 4 Max XK K110 S2 & CP X 150X iK2N/Brain2/Spirit Horus X10S OpenTX AccuRC
xoexoe is online now        Reply With Quote Quick reply to this message
Old 04-10-2019, 04:11 PM   #3 (permalink)
Ok... I assigned that 'MIXING' function to the 'I' button and nothing happens on the 'GER' graph. The 'AX6' is the only graph that shows any signs of life when the 'I' button is pressed: Normal position reads 100 and -100 when it's pressed.
Old 04-10-2019, 04:14 PM   #4 (permalink)
I just tried all 3 different flight modes and nothing changes at all on the 'GER' graph when I press the 'I' button.
Old 04-10-2019, 04:24 PM   #5 (permalink)
Can you take a screenshot of your Channel Assign input page? The one where you can assign switch B to GER?
If your GER > GER mixing on switch I isn’t doing anything to GER, I’m at a loss. Only other possible think I could think of is that the value of switch I was changed? Maybe in digital switch setup?
Hopefully someone else can chime in.
Old 04-10-2019, 04:30 PM   #6 (permalink)
Old 04-10-2019, 05:11 PM   #7 (permalink)
Inhibit I on Aux 6. See if that helps.
Old 04-10-2019, 07:11 PM   #8 (permalink)
'I' is already on 'AUX6'...
Old 04-10-2019, 08:54 PM   #9 (permalink)
Aye. Inhibit it. Make it say “N/A” or “INH”. Get rid of it. You don’t need anything on any AUX2-6 (channels 7–12) since the Nano receiver only has 6 channels. Those first 6 on the left hand side of your screenshot.
I don’t know if this will help, but it’s worth a shot maybe. Perhaps having a button do both channel stuff and mixing is causing a weird issue? I doubt it.
Old 04-11-2019, 04:43 PM   #10 (permalink)
Thanks to a Horizon Hobby tech, just now FINALLY got this 'PANIC' issue figured out. It was something SOOOOOO freakin' simple and I would have NEVER figured it out on my own. All I had to do was physically touch a stupid little box in the 'MIXING' programming menu to activate it. If I were to use the 'I' button, I just simply touch the #1 box to highlight it. Since I'm using the 'G' switch for 'PANIC', I highlighted the #2 box.
UNBEFREAKINLIEVABLE... something so simple got turned into the mystery of the year.
Old 04-11-2019, 07:08 PM   #11 (permalink)
Glad to hear it’s solved. I hope HH is taking note of unintuitive GUIs.
Old 04-12-2019, 09:46 AM   #12 (permalink)
Well to be honest, 'PANIC' still doesn't appear to work, even though there's at least movement now on the 'GER' graph in the 'MIXING' menu. I don't know to what extreme the NANO has to be in for 'PANIC' to intervene, but when I activate it while hovering around, nothing different happens to the flight characteristics.
Old 04-12-2019, 09:49 AM   #13 (permalink)
What if the heli is on the ground at rest, not spooled up, and you hit Panic? Does the swash move a little? Try again with the heli tilted slightly. If I remember correctly, the swash should be trying to return to level quite noticeably.
Old 04-12-2019, 09:58 AM   #14 (permalink)
Nope... nothing happens at all. I've even tried holding the heli in my hand at an angle to see if anything would happen.
