Old 04-13-2019, 02:31 AM   #1 (permalink)
Default HW V4 rpm reading Vcontrol
Hi there, I am trying to figure out why I can t get the rpm readings on my Vcontrol using a miniV 6.0Pro and HW 100V3 (running internal HW governor store).
Where the rpm wire should be plugged in on the miniV? I plugged the yellow, red and black to RX C.....
Appreciated any help
Chris
XLPower 700 - XLPower 550 - OXY4 - OXY 4 Max
scoio is offline        Reply With Quote Quick reply to this message
Old 04-13-2019, 07:01 AM   #2 (permalink)
Canít remember the port number but I do know you canít have the power wires used only signal or you will burn up the mini vbar.
tshelby73 is offline        Reply With Quote Quick reply to this message
Old 04-13-2019, 11:39 AM   #3 (permalink)
https://www.vstabi.info/en/node/442
Top pin of RX A is for rpm input, DO NOT PLUG ANYTHING INTO MIDDLE AND BOTTOM PIN, only the signal from rpm out from the HW ESC.
Gaui R5, Henseleit TDR, TDR2, TDF, TDS
VControl
Old hand at Planks
Old 04-14-2019, 04:48 AM   #4 (permalink)
Thank you Vinger! all sorted!
Chris
Old 04-14-2019, 08:17 AM   #5 (permalink)
For others not stated on vstabi…
RX-A connects directly to the controller chip and so must not exceed 5volts.
Using a H/W ESC is good as the rpm out is set to 3.3volts.
A separate phase sensor would typically get powered from the ESC bec and that might be 8 volts. Doing this the signal would also be 8 volts. Something is then required to drop the voltage of the signal to the 5 volt maximum. A voltage divider consisting of 2 resistors is an easy thing to construct for this.
Andy from Sandy is offline        Reply With Quote Quick reply to this message
