Old 04-14-2019, 09:38 PM   #1 (permalink)
Default Neo vlink Calibration of the horizontal
To prepare the rescue, a Calibration of the horizontal position is recommended. My neo v link Will not calibrate. message says check level and orientation.
put bubble level on neo both axes level and try, same message. Fly's normal. Had no trouble with neo non v link. (calibrated). Back loaded express and then re loaded pro-Rescue on neo v link, no help. in the Display screen. dot in the middle when level, collect box always stays black right side up or up side down. even when activated. On the fence normal, fly it or does it have a problem
oblj is offline        Reply With Quote Quick reply to this message
Old 04-14-2019, 11:36 PM   #2 (permalink)
https://www.vstabi.info/en/node/1930
Confirm motor switch is off? Post the log so that we can see if there are any abnormal entries.
Gaui R5, Henseleit TDR, TDR2, TDF, TDS
VControl
Old hand at Planks
Old 04-15-2019, 09:24 PM   #3 (permalink)
Un able to retrieve logs. have early v control. can see logs on transmitter says Calibration horizontal failed. Can't connect with Vstabi neo. says serial number not in my list. can connect with vbar control manager but has no log files there only software
Old 04-15-2019, 11:21 PM   #4 (permalink)
To connect to PC software you will need the keyfile for your devices that you have registered. https://www.vstabi.info/en/node/1856
The logs on the Neo contains more info than what is on the VBC, so see if you can connect to PC software and retrieve the logs.
VControl
Old hand at Planks
Old 04-16-2019, 09:19 PM   #5 (permalink)
logs
Old 04-17-2019, 02:55 PM   #6 (permalink)
Those errors during flight is normally associated with precision calibration, you can set it to normal then fly again and see if the error still appears. Calibration setting is under RESCUE app.
As long as the Neo boots it is safe to fly.
VControl
Old hand at Planks
