JR and Spektrum Radios and Electronics JR and Spektrum Radios, Gyros, Servos, Etc. |
04-20-2019, 07:07 AM | #1 (permalink) |
Is there "throttle cut" in JR DSX12?
Hi All,
I have been using my JR DSX12 for electric Heli couple of years without the need of Throttle Cut. But I just bought a Nitro Heli and the setup will be better with Throttle Cut and Throttle Hold. Try to look up on the manual and search on the web but found nothing. Has anyone tried to find a way to make it work in a similar to Throttle Cut? Thanks, Hoa. |
04-20-2019, 03:55 PM | #2 (permalink) |
Hi,
Please refer to following manual and pages http://www.macgregor.co.uk/support/r...X12-manual.pdf Page A-23 and A-33 so on. |
04-20-2019, 07:27 PM | #3 (permalink) |
Thank you for your respond.
That is what I've been using on my Electric Heli. But I like to setup as below Throttle Hold : engine idling Throttle Cut : Kill the motor / Close the carb I know people use Throttle Cut and Throttle Hold separately in other radio like Spektrum DX9, etc... In the worse case, I will set Throttle Hold : Kill the motor / Close the carb Normal Mode : engine idling - with flat TC ST1 : Fix TC - No Governor only for take off and landing ST2 : Idle up with Governor Do you think there will be problem with this set up? |
Tags |
jr dsx12, throttle cut |
