Old 04-22-2019, 11:33 PM   #1 (permalink)
Default Neo governor headaches
So I have 2 logo's one is a 550sx with neo and tribunus 120 opto. the other is a 480 with neo and tribunus 120 opto, tx is a vbar touch. The 550 governor worked right out of the box no problems. The 480 has a new neo and esc. It is wired exactly the same as the 550. On the 480 the governor never becomes active on the touch's status page. the rpm box flickers green as it does on the 550, and on the 550 the gov active box turns and stays green saying gov active. Initially I would get a - number for rpm (example -430) I have uninstalled and reinstalled the scorpion app several times and after uninstalling and reinstalling sometimes I get a normal number but the gov never becomes active and never reaches the target rpm of 1900 rpm in bank 1. All governor settings are default. I have tried the procedure outlined here https://www.helifreak.com/showthread.php?t=828113 Post #11 but the gov never becomes active.
I have checked the wiring several times and also checked the integrity of the rpm lead and the telemetry lead from the esc. The scorpion status page says everything is normal and the scorpion setup page says the scorpion vbar gov is selected. I have checked the amplitude and quality of the rpm signal on both the 550 and 480's esc's with my oscilloscope and they both are clean 3 volt square wave signals. I'm using a western robotics bec and have tried 5 and 6 and 7.4 volts. I have searched this forum for Ideas/suggestions and others with similar issues. I have thought about trying to reload the pro firmware and rescue but thought I would wait to see if anyone has some suggestions, because I'm running out of things to try.
luckyflyer is offline        Reply With Quote Quick reply to this message
Old 04-23-2019, 10:22 PM   #2 (permalink)
Make sure you have the latest firmware on the Tribunus ESC. As VBCt updates itself via WiFi connections, the Scorpion app and communication protocol is now V3, only V58 and higher firmware on the ESC will work with it.
Also have to make sure the ESC is set to VBar PID and VBar protocol via the Sproto program from Scorpion using the VLink2 cable and diode.
Gaui R5, Henseleit TDR, TDR2, TDF, TDS
VControl
Old hand at Planks
Old 04-24-2019, 07:15 PM   #3 (permalink)
I had forgot that this 480 was stretched with a 106 tooth main gear. When I entered the correct main gear on the gov page the governor started working like it should.
