Old 04-23-2019, 04:31 PM   #1 (permalink)
Default vbar initial programming questions
Following vstabi initial programing instructions and have some questions.
"It says after successful initialization the connection status will switch to green bar and the V will begin to blinking slowly"
Mine stays solid green no blink. And on the transmitter page of the setup wizard, the wizard does not recognise any inputs from aileron--elevator--rudder but the collective work just fine. Sorry first time setup and new to all this, can some one help?
Using dx7 radio and a standard receiver
peterel is offline        Reply With Quote Quick reply to this message
Old 04-23-2019, 04:57 PM   #2 (permalink)
For starters, ensure that you have single servo swash selected and that you chose the correct type of receiver. When you get to the transmitter page you should see all of the controls doing something.
You may need to break it down for us a little so that we can be of more help. Examples: provide further info on your motor, ESC, wiring connections, specific software of your vbar, which governor you will use, etc.
AMA 373608
K2Freak is offline        Reply With Quote Quick reply to this message
Old 04-23-2019, 05:55 PM   #3 (permalink)
Sorry stock 450 trex pro , DX7 radio with AR610 receiver don't know what software and no governor ( that I know of). DX7 set to [ swash type ] --1 servo--norm
Receiver wiring
THRO---comes from esc
AILE--goes to RXA on vbar
ELEV-- '' ''
RUDDER " "
GEAR goes to RXC on vbar
AUX1 goes to RXB on vbar
When I get to transmitter page it only sees the collective. Maybe radio not set right?
Old 04-23-2019, 10:13 PM   #4 (permalink)
https://www.vstabi.info/en/node/436
Work your way through the setup procedure in the link above. when finished with the page, click on the right bottom link to go to next step. TX setup and wiring is all there.
Gaui R5, Henseleit TDR, TDR2, TDF, TDS, TDSF
VControl
Old hand at Planks
Old 04-23-2019, 10:20 PM   #5 (permalink)
Been there, done that, 3 times. Still the same thing. I'm thinking that I may have shorted the vbar out some how.
Old 04-24-2019, 09:08 AM   #6 (permalink)
RX A is a triple INPUT plug and should have the single signal wires from AILERON. ELEV and RUDDER into it. Make sure you have the correct wire from the RX channels, normally white or yellow in color.
RD = Tail rotor servo
Ch1 ... 3 = Swashplate servos
RX A = Aileron, elevator and rudder signal from RX
RX B = Collective RX signal and power supply
RX C = Gyro gain RX signal and power supply
RX 1 = not used
RX 2 = not used
If you had power into RX A even for a brief period then the VBar is toast.
https://www.vstabi.info/en/node/442
VControl
Old hand at Planks
