Like Tree1Likes
  • 1 Post By nivaldin
Old 05-01-2019, 07:49 PM   #1 (permalink)
Default Stationary Pirouetting
When I'm hovering, if I start a stationary pirouetting the helicopter starts to lean in some direction rapidly. What can cause that?
It's a mini vbar on a trex 470LT!
Swashplate is flat and CG is perfect, what else could be?
nivaldin is offline        Reply With Quote Quick reply to this message
Old 05-01-2019, 10:03 PM   #2 (permalink)
The Vbar normally has no problems with pirouetting in any direction, stationary or in flight. Which direction are you doing the pirouette and which direction is the helicopter moving?
Gaui R5, Henseleit TDR, TDR2, TDF, TDS
VControl
Old hand at Planks
Old 05-02-2019, 02:26 AM   #3 (permalink)
I had this same problem first before. Turns out I missed that with the Vbar connected to the PC, that when I move the rudder stick left the live display in the software showed right. And when I move the stick right it showed left. To fix this I had reverse both the tail servo tail tab in the software and the rudder channel in my radio. I also had to select a different sensor mounting then re-select the correct mounting for the sensor. Once this was done all pirouetting drift went away!!!!
GOBLIN 630 COMP VBar NEO VLink 6.1Pro
GOBLIN 570 VBAR NEO VLink 6.1Pro
GOBLIN 380 VBAR NEO VLink 6.1Pro
V-BAR Control ICharger 4010Duo
PREACHERB68 is offline        Reply With Quote Quick reply to this message
Old 05-02-2019, 05:48 AM   #4 (permalink)
I'm pirouetting anti-clockwise, and the helicopter always lean to the left most of times, sometimes to the backward and sometimes to the front.
Old 05-02-2019, 09:14 AM   #5 (permalink)
Check and fix geometry and COG, and then do an autotrim flight.
AMA 373608
Citizen #97
K2Freak is online now        Reply With Quote Quick reply to this message
Old 05-02-2019, 09:19 AM   #6 (permalink)
As said before, CG is perfect.
Could you specify this geometry?
Old 05-02-2019, 09:24 AM   #7 (permalink)
That your swash is centered in the throw range at 0 degrees, that your control links are all the same length, equal throw in both directions, ranges set correctly in FBL. Vstabi is usually very good at telling you something is wrong, and works very well when nothing is.
After checking all of that, the trim flight will help too.
AMA 373608
Citizen #97
Old 05-02-2019, 09:27 AM   #8 (permalink)
Nice, I'll check all of that and do the trim flight too.
Thank you
Old 05-02-2019, 02:00 PM   #9 (permalink)
My inputs in vbar are correct... right is right, left is left.
Old 05-02-2019, 03:17 PM   #10 (permalink)
I think under most circumstances this issue (had it existed) would have been manifest quite dramatically...
AMA 373608
Citizen #97
Old 05-03-2019, 05:45 AM   #11 (permalink)
The auto trim does the magic.
Thank you all!
Name:	Sem título.jpg
Hemidoo likes this.
