Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade 230S
Blade 230S Blade 230S Helicopters Information and Help
Old 05-04-2019, 11:10 PM   #1 (permalink)
Default Alternative motor option topic refresh
I'm bringing this up again because the older threads discuss upgrade motors that often can no longer be sourced. Looking for a bit more power to be able to run with a bit of headroom and use the BL governor. I presume the 300X Blade motor is still what has been termed a "POS"?
Thanks,
Ben Minor
Team Futaba USA, Team Minicopter/Peak Aircraft, Team Kontronik USA
Dr.Ben is offline        Reply With Quote Quick reply to this message
Old 05-11-2019, 10:58 PM   #2 (permalink)
Does this Heli have a governor ? I've read a few people have used the 300x motor and dialed down the throttle
Harder, Faster, Louder.....works for Me !
Brick is offline        Reply With Quote Quick reply to this message
Old 05-12-2019, 10:12 PM   #3 (permalink)
The ESC doesn’t have the governor enabled, but it is running BLheli firmware so if you hook it up to a PC you can enable the gov.
I have gone with a slightly bigger motor from Horizon which also requires a new pinion, same tooth size but there is a step on the motor shaft so you can’t use the original. I will have to check which number motor it is but it’s from one of the fixed pitch helis. It KV is slightly higher and the can is a mm or 2 longer.
//Dennis
soXos Strike 7 : soXos 600 : soXos 550 : soXos F3C
Protos 380 : soXos DB7 nightflyer : Jeti DS-16 : Mini Protos FBL Stretch : Logo 600
www.soxosaustralia.com.au | VTX blades | SLS Batteries
Thunder Fighter is offline        Reply With Quote Quick reply to this message
Old 05-13-2019, 01:40 PM   #4 (permalink)
That would be nice to know. I'm currently flying the referenced "POS" motor, and I agree it is one vibrating little bitch even with bearings fixtured to the motor shaft, but the added power makes the model much more useful for learning a bit more power hungry 3D stuff, especially as the pack depletes.
Ben Minor
Old 05-13-2019, 01:53 PM   #5 (permalink)
Originally Posted by Thunder Fighter View Post
The ESC doesnít have the governor enabled, but it is running BLheli firmware so if you hook it up to a PC you can enable the gov.
I have gone with a slightly bigger motor from Horizon which also requires a new pinion, same tooth size but there is a step on the motor shaft so you canít use the original. I will have to check which number motor it is but itís from one of the fixed pitch helis. It KV is slightly higher and the can is a mm or 2 longer.
//Dennis
The 200S motor is 80Kv higher if that is the one you are talking about:
Main Motor 3980Kv: 200 S BLH2650
Team USED
Shape S8, G700, G500, Shuttle Plus 550, Trex 500 EFL Pro, Oxy 3 (2), B400 (7), 450X, 360CFX, 230S (V1/V2), 200S, 120S, Nano (CPS/S2), K110/120/130
BrokeDad is online now        Reply With Quote Quick reply to this message
Old 05-13-2019, 08:28 PM   #6 (permalink)
I see that motor, but is it more powerful than the stock one?
Ben Minor
Old 05-13-2019, 10:35 PM   #7 (permalink)
Yep, that is the one.
Ben Minor
Thatís a good question, the can is slightly longer and KV slightly higher. My friend did the change first and he gained significant extra power, but then I did it and donít think I gained much. Could be some variation between the motors.
//Dennis
Old 05-14-2019, 02:58 PM   #8 (permalink)
insteresting... direct fit?
230s, Fusion 270, 360 cfx 3s & DX9
2005h4 is online now        Reply With Quote Quick reply to this message
Old 05-15-2019, 06:19 AM   #9 (permalink)
You need another pinion because of the stepped shaft and you just need to re-route the ESC wires as the can is longer so you need to go out the side rather than under the motor, otherwise it is a direct fit.
//Dennis.
Old 05-15-2019, 08:40 PM   #10 (permalink)
I moved the esc to the side of the model with the larger motor. Not quite as pretty, but all the wiring to both motors becomes a straight-shot plug in with no concern for the front bullets off the esc getting close to the can or being forced into acute angles.
Ben Minor
Old 05-16-2019, 08:11 AM   #11 (permalink)
I have one 230s with a Turnigy 4200KV motor which is more powerful than stock. It fly's great but if I really bang on the pitch the tail will turn about 90 degrees before it catches up. Also on spooling up when on a smooth floor the heli with tend to turn about 90 degrees before tail authority is gained.. Also I get about a minute less duration. I bought the heli with this motor but for my flying capability and liking for smooth more big sky aerobatics I don't see this motor as necessary. Then again if you are into hard pitch pumping 3D stuff I don't see the 230 as the ideal helicopter for this type of flying.
Allan114 is offline        Reply With Quote Quick reply to this message
Old 05-17-2019, 11:44 PM   #12 (permalink)
I wish I could get that motor, but it's on perpetual backorder. The 300x motor makes good power but is a noisy, hideously balanced POS just as described by others.
Ben Minor
Old 05-18-2019, 08:26 PM   #13 (permalink)
I use one of my 230s just as a Sport flyer to fly fast. I would love a little more SPEED !!
Old 05-19-2019, 03:47 PM   #14 (permalink)
Interesting as I have tried speed flying. I like to climb to a good height then roll over the top inverted and pull up to dive down pulling out level and fast but I find that the heli seems to become a little unstable in pitch with a sort of bucking motion.
