Go Back   HeliFreak > R/C Electronics Support > OpenTX Radios
OpenTX Radios OpenTX Radios Discussion and Support Forum
Like Tree19Likes
Old 10-03-2019, 11:13 PM   #41 (permalink)
Found this on Thingiverse:
https://www.thingiverse.com/thing:3857670
I think it could stand a few improvements though.
The position of the antenna holes could be adjusted to better match the antennas and changed from slots to actual round holes.
The supports for the PCB inside the case could be improved. There is one under the PCB between the antennas but others could be added to the corners and supports could also be added to the lid to sandwich the PCB (these must match spots on the edge of the PCB where there are no components)
The size of the bind button hole could be optimized, I think it's a little large.
When I have some time I'll see about adding those.
Old 10-22-2019, 11:59 AM   #42 (permalink)
Originally Posted by K-rash View Post
using frsky on large models should be avoided
lol, like a goblin 770?
been using mine for a while now
Goblin 770S - eXo 500 - HD 502 - Oxy FE, Max, MEG - Few 4 Stroke Saito powered Fixed wings
Spartan VX1e, Frsky RX, RT & Zeal Blades MKS/BK, Hobbywing
Danker16 is offline        Reply With Quote Quick reply to this message
Old 10-28-2019, 10:10 AM   #43 (permalink)
Antenna routing suggestions. I'm new to Frsky and converting my Oxy3 from spectrum now. I used a XM+ to a uSpirit controller.
The Spektrum sats had their short antennas basically perpendicular to the cases, how should the two longer antennas be positioned?
Is sending one basically straight from the RX fixed to one side of the frame and the other looped backwards on the other frame side okay or bad?
Align 150X | Gaui - X3L | Gaui Flybar 500 | Oxy3 Qube | Align 600 CF Flybar | Spirit | FunCub
blade_crasher is online now        Reply With Quote Quick reply to this message
Old 10-29-2019, 07:00 AM   #44 (permalink)
Place the 2 antennas perpendicular to each other.
Sent from my Pixel 2 using Tapatalk
xoexoe likes this.
kuroguy is offline        Reply With Quote Quick reply to this message
Old 10-31-2019, 11:32 AM   #45 (permalink)
+1 Danker16 . Or a Trex 550X like mine. I have been using Frsky on it for more than a year now without any failures.
Align Trex 550X (Spirit 2 FBL/Geolink), Trex 470LP (mini Brain 2 FBL), Trex 450 Pro (mini Vbar FBL), HCP100S, V977, V911, Taranis Q X7S OpenTX.
denis747 is online now        Reply With Quote Quick reply to this message
Old 10-31-2019, 12:12 PM   #46 (permalink)
Still waiting on k-rash to respond to my statistical analysis of what he posted. But, I don't think that is going to happen.
I have put on over 250 flights on my E7 with an X4R-SB and had zero radio issues.
Same with my 516 and X4R-SB.
Had a 450X with an RXSR and no issues, but it finally succumbed to the thumb glitch...
Ivan is offline        Reply With Quote Quick reply to this message
Old 11-03-2019, 08:30 PM   #47 (permalink)
specter 700, Flown with qx7 and x4r sb lol
Kevin Dover flying XL Power at Helis Gone Wild 2019 (4 min 26 sec)
Sent from my LM-G820 using Tapatalk
IndividualWon and denis747 like this.
kevindnyc is offline        Reply With Quote Quick reply to this message
Old 01-02-2020, 03:54 AM   #48 (permalink)
Your statistical analysis is flawed ... My original post in this thread says "large models"... The post you quoted says 600 size models... so the relevant statistic would be to large models...yet you selected to use data from all models flown... so the actual relevant failure ratio would be more like 4 out of 30....
BTW, I now have many hundreds of flights with large models on Jeti and have had zero failsafes... Try analyzing that.
James Recard is online now        Reply With Quote Quick reply to this message
Old 01-05-2020, 12:28 PM   #49 (permalink)
I have had zero (nothing/nada) fail-safes with FrSky on a large model, flying many hundreds of flights on it too. Absolutely no failures. Go figure that.
Sent from my SM-G950F using Tapatalk
Old 01-13-2020, 09:13 AM   #50 (permalink)
Default ACCESS
Anybody happen to know if I use my ACCESS X9 Lite, an RX4R flashed with ACCESS firmware, if SBUS out will work the same?
I also acquired two Microbeast Plus for working on a buddies two heli's that I'm setting up on his two new Ikon2's; I'm interested in using the SBUS to one of the Microbeast Plus controllers.
IndividualWon
IndividualWon is offline        Reply With Quote Quick reply to this message
Old 01-13-2020, 09:53 AM   #51 (permalink)
Yeah if you use S.Bus out it should work. S.Bus is standardized.
IndividualWon likes this.
Keith - MSH Brain2 Beta Tester | KST Heli Division Team Pilot | BuddyRC/OMP Sponsored Pilot
Specter 700 | T-REX 600N DFC | GAUI NX5 | Protos 380 | OMPHobby M2 V2
https://kc3dprint.com - 3D Printing on Demand and 3D Printed RC Heli Upgrades
Number is offline        Reply With Quote Quick reply to this message
Old 01-17-2020, 04:54 PM   #52 (permalink)
Are you guys running a single receiver or two?
Race City flyer is offline        Reply With Quote Quick reply to this message
Old 01-17-2020, 05:25 PM   #53 (permalink)
Single - but biggest heli is a 380
xoexoe likes this.
Old 01-17-2020, 06:03 PM   #54 (permalink)
Single on all including a 700 gasser.
XK K110(s), Align 150X, Align 500XT, Align 550E/DFC, Blade fusion 180, Goblin 280, Goblin 380, Goblin 420, Goblin 500 Sport, Leviathan Goblin 700 TRM gasser --- FrSky/OpenTX controlled.
Oh, and GO HOGS!
tvoth3 is online now        Reply With Quote Quick reply to this message
Old 01-17-2020, 06:35 PM   #55 (permalink)
Currently:
X4R-SB in F.Port mode on my 516 and (new) Gaui NX5
X8R on my Synergy N556
R-X8R Pro on my E700N (used to have a XM+ as a redundant but removed it)
Old 01-18-2020, 01:54 AM   #56 (permalink)
I have just set up a RSSI- field in my Telemetry display, it shows the lowest that the RSSI (Received Signal Strength Indicator) goes during flight. I did this as I am just moving a number of my helis over to FRSky and I can see immediately if I have a signal problem - the Tx will obviously tell me if it gets critical, but I wanted to know how low it was getting even when it's OK.
If you are worried about reception you could do something similar
Old 01-18-2020, 09:56 AM   #57 (permalink)
Yep, I do that too. I don't think I've seen any lower than 65 even doing good size autos, so I'd say the radio link is darn good. Considering the low RSSI is at 45, and decibels are a logarithmic scale, I think I'd have to go way high up to even reach a moderately low signal.
Old 01-18-2020, 10:03 AM   #58 (permalink)
Originally Posted by Number View Post
Yep, I do that too.
Great idea guys. Do you bother with a reset button for that telemetry value so you can check the minimum value on a flight-by-fligut basis. Id probably end up doing that.
Brian — Oxy 2, YGE 35LVT, µSpirit — Oxy 4 Max, YGE 65LVT, Brain2 — XK K110 — Coming soon: XLP 520, YGE 95LVT, IKON2 — Horus X10S & OpenTX —
xoexoe is online now        Reply With Quote Quick reply to this message
Old 01-18-2020, 10:16 AM   #59 (permalink)
Yeah I have a switch setup to reset the flight (which in turn resets the timer(s) and telemetry all at once). I also use telemetry to tell me maximum current and ESC temperature so I have to reset it before a flight otherwise the data is from a previous flight.
xoexoe likes this.
Old 01-18-2020, 11:21 AM   #60 (permalink)
...and it doesn't lose control link until below something like 35 which is like three times as far as when you get the warning.
