Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade 230S
Blade 230S Blade 230S Helicopters Information and Help
Like Tree1Likes
  • 1 Post By UH34D
Old 05-17-2019, 07:34 AM   #1 (permalink)
Default Stability mode
Iíve been flying my Blade 230s for awhile now and really like it. Itís set up per the instructions with my dx9: The problem is that it is stuck in stability mode in all flight modes on switch B. I thought 0 would be stability and fm1 would be aggressive and fm2 would be 3D out of the box? Iíve e gone thru the manual several times but canít figure out how to make it fly in the three modes. I want to start looping and rolling this thing!
Jim
tberget likes this.
UH34D is online now        Reply With Quote Quick reply to this message
Old 05-17-2019, 08:49 AM   #2 (permalink)
Only thing I cAn think of is that channel 5 is not controlled by switch B.
Go into System > Channel Assign > Next (channel input config)
Make sure Ch 5 gear is on B.
xoexoe is online now        Reply With Quote Quick reply to this message
Old 05-17-2019, 04:50 PM   #3 (permalink)
Thanks XO. I checked my DX9 and at Channel Assign I show Receiver Port assignments
#5 Gear Gear
On Channel Input Config I show 5 Gear B .I think I've followed the manual but there
is definitely something wrong. For example, if i try a loop in any flt mode the nose just goes up about 60 degrees. I can tell on my roll as well. Something is definitely set up wrong.
Old 05-17-2019, 05:15 PM   #4 (permalink)
Check your channel value for AUX2. It should stay at 100 all the time while in flight modes. If it goes to (or is set at) -100 it can trigger SAFE mode to stay engaged. I believe they were eventually going to take AUX2 out of the mix.
Team USED
Shape S8,G700/G500,Shuttle 550,Trex 500 E/EFL Pro,Oxy 3(2),B400(5),450X,360CFX,Fusion 270(2),230S (V1/V2),200S,120S,Nano (CPS/S2),K110/120/130
BrokeDad is online now        Reply With Quote Quick reply to this message
Old 05-17-2019, 05:18 PM   #5 (permalink)
Thanks Broke Dad, Iíll give that a try
Old 05-17-2019, 05:27 PM   #6 (permalink)
Aux 2 values of 100 donít move at all in the monitor. Values do move in the gear channel from 100 in 0/normal to 0 in idle up 1 and -100 in idle up 2
Old 05-17-2019, 05:44 PM   #7 (permalink)
Just for the helluvit download the 230S V1 file from the Spektrum site and install it and bind with that. I know that will work with both versions. If it still won't come out of stability mode then it's not your settings or radio and is a problem in the AR636 FBL.
Link: https://www.spektrumrc.com/ProdInfo/...ith%20SAFE.SPM
Team USED
Old 05-17-2019, 05:56 PM   #8 (permalink)
Originally Posted by UH34D View Post
[...] Values do move in the gear channel from 100 in 0/normal to 0 in idle up 1 and -100 in idle up 2
This sounds like what you want. Gear channel is -100 in IU2, 0 in IU1, +100 in Normal.
If it were me I'd start fresh with a new model in the DX9. Or try BD's suggestion.
We'll get it working!
By the way, any chance that your Dual Rate/Expo values aren't at stock settings? Maybe they're so low/high that it just feels crazy stable? I know you said everything is stock, so I doubt it, but it's worth a look.
Sep 2019: Oxy 3 & 2 ó Nano S2 & CP X ó T-Rex 150X ó Spirit FBL ó FrSky Horus X10S ó OpenTX
Next heli I want: Oxy 5 light build on 6S
Old 05-17-2019, 06:13 PM   #9 (permalink)
Thanks guys for the suggestions. Iím going to download from the Spektrum site tomorrow morning. Then Iíll ck it and head to the local flying field. Iíll report back to you tomorrow!
Old 05-18-2019, 10:56 PM   #10 (permalink)
Did you get it figured out ? I know I have a switch on my DX9 that I have setup to turn stability on/off. I am 800 miles from my radio right now. so I can't confirm a switch. it's pretty simple to configure
Harder, Faster, Louder.....works for Me !
Brick is offline        Reply With Quote Quick reply to this message
Old 05-19-2019, 11:52 AM   #11 (permalink)
Thumbs up
I finally got it working. I found a video on utube that got things straightened out. The video is ďHow To Fly Blade 230s in 3D Mode with Spektrum DX6Ē. The video is by David B, who had the same problem as mine. He found that by toggling the D switch he could release stability mode. Watch the video and it will solve the problem. I flew yesterday and was looping very easily. I had followed the instruction manual for my settings and simply could not get the thing out of stability mode. Problem solved. I moved gear to the C switch rather than the D switch on my DX9 because the C switch is easier to reach. Thank all of you who chimed in to help.
Old 05-19-2019, 01:00 PM   #12 (permalink)
Sounds like Gear was on D rather than B as per instructions maybe? Either way, glad you got it.
Old 05-19-2019, 01:37 PM   #13 (permalink)
Very interesting as I have the stability modes separated out to the D switch myself but it's something I did not HH.
Team USED
Old 05-19-2019, 04:25 PM   #14 (permalink)
Some manuals from HH left out the fact that gear needs to be on B. By default it goes to D.
The old Nano CP S was like that IIRC. They may have fixed it since then.
