Go Back   HeliFreak > R/C Helicopter Support > Gas Powered Thoughts
Gas Powered Thoughts Advice for Gas Helicopter Success from Carey Shurley
Like Tree4Likes
  • 3 Post By carey shurley
  • 1 Post By Azalin
Old 05-22-2019, 08:55 AM   #1 (permalink)
Default Build Thread - JCD Goblin 570 Nitro 55
Goblin 570 55 Nitro Conversion
Overview
This is a conversion kit to convert a Goblin 570/Sport for a 50/55 class nitro helicopter. This thread will not be step by step but an overview of the process. A detailed conversion guide is linked to this thread and can be downloaded and/or printed
Donor Kit
Goblin 570 Standard/Sport donor model
You will need a Goblin 570/Sport helicopter. The conversion contains everything needed for the conversion but you will need some parts from the donor model
Parts Used
These are the parts needed from the donor kit. All of these parts need to be in good condition and working order
Entire upper chassis required
Frame parts needed
Canopy required
Parts Not Needed
These parts will not be used. If they are damaged or missing you can still complete the conversion successfully
Lower frame parts not used
Parts not needed
There is an exception, you will need to disassemble the battery tray and reclaim the frame spacers it contains
Remove these spacers
Conversion Kit
And this is what you will find in the conversion kit
JCD Conversion kit
Required Parts
There are also some required parts needed to complete the model
You will need an engine, it must be 50/55 class engine, both the OS and YS engines will fit
OS 50/55
YS 60
You'll need a muffler designed for the engine
OS Powerboost/MStudio 55
You'll need the usual electronics including a battery to run the Rx/FBL/Servos and an additional servo for the throttle
Electronics Ė note mini servo
And of course you'll need rotor blades. I'd suggest the main blades be no longer than 560mm
Rotor blades
Conversion Guide
The kit includes a printed conversion guide which you can to download from this link:
Next Step
Pre-Conversion Components
carey shurley is offline        Reply With Quote Quick reply to this message
Old 05-22-2019, 08:55 AM   #2 (permalink)
Default Build Thread - JCD Goblin 570 Nitro 55 - Components
As you’ve no doubt noticed in virtually all of my model builds, I like to do a lot of preassembly, things that can be put together as small units of work and then when you’re ready to complete the build you aren’t waiting for adhesives to dry, or looking for the right drill bits or some other annoyance. The Goblin 570 build is no different, there are a number of components that can be pre-built before completing the conversion
Assemble Fan/Clutch
This is the hardware needed to
assemble the fan and clutch
Parts for fan/hub/clutch
If you are going to use a governor sensor, install the magnets required in the fan as shown
Fan magnets for governor
Fan hub installs as shown
Fan hub positioned
Install the four M4 x 6mm BH bolts to secure the hub as shown
Fan hub mounted
Install the engines bearing spacer over the end of the crankshaft. The fan hub will push over the crank and seat against the spacer.
Parts to mount fan on engine
Push the fan hub over the crankshaft until it seats against the engine thrust washer. Drop the 1/4" washer over the crankshaft and tighten the engine provided crankshaft nut. You'll need a crank lock of some sort to hold the crankshaft in place while you tighten it. You can use a piston stop or one of the custom made crank locks. I've even used a plastic toothbrush to hold the crankshaft in place.
Tighten the two M3 clamp bolts using a ball end driver to clamp the hub on the crankshaft
Fan orientation
Install the clutch into the fan hub as shown
Clutch position
Install the clutch with the M4 bolts
Clutch installed
These are the parts needed to install the clutch bell
Parts to assemble clutch bell
Press the upper and lower clutch bearings into the clutch bearing block
Install bearings in block
The bearing block will install onto the top of the original motor mount using M4 flat head bolts
Block mounted to motor plate
Press the upper and lower start shaft bearings into the clutch bell
Install bell bearings
Select the clutch drive pulley and locate the orientation of the set screws and note the position of the flat milled on the clutch bell
Install drive pulley
Drop the clutch spacer over the clutch shaft as shown
Install clutch spacer
Install a 5mm Teflon washer over the start shaft and then install the 5mm shaft spacer as shown. The spacer is a loose fit on the shaft. Select the starter adapter and place it over the end of the start shaft.
Parts for start shaft
Align the adapter holes with the two small indentations in the shaft, install the two set screws and then tighten them. Install the clutch pulley spacer over the clutch shaft as shown.
Clutch bell assembled
Insert the clutch bell assembly into the previously assembled clutch block as shown. Push it all the way in
Insert clutch bell
Select the 12mm nut and thread it over the clutch shaft and fully tighten it. There will be a very small amount of vertical play in the assembly.
Clutch bell installed
Assemble Battery plate
Select the battery plate, the isolator tubing and the tie wraps. It mounts on isolators using the included tie wraps.
Parts for battery plate
Select the isolator tubing and cut it into 6 pieces each ĺ” long as shown. Push the isolator pieces over the three frame spacers as shown and set these parts aside for now
Prepare plate mounts
Partially install the tie wraps into the battery plate as shown. DO NOT tighten them down yet
Prepare tie wraps
Assemble Rear Canopy Mounts
If you want to use quick mounts I suggest the SAB mounts that use this post
Parts for rear canopy mount
Using the M3 x 5mm flat head bolts install the posts onto the mount tabs as shown.
Rear canopy mounts
If you are using the standard canopy mounts, you will use these parts.
Knobs prepared
Select the 2.5mm locknuts as shown and drop them into the canopy mounts.
Standard mounts - nuts
The canopy mount will be attached as shown with the bolt connecting with the locknut previously dropped into the mount. Select the canopy mount tabs and insert an M2.5 flat head bolt through the side with the recessed bevel opening as shown.
Attach mounts
Use a small screwdriver to wedge the locknut into place as you tighten the mount into place.
Tighten mounts
Completed standard canopy mounts
Completed Mounts
Assemble Fuel tank
Select the fuel tank parts as shown
Fuel tank parts
Assemble the cap top using the M3 bolt and the stopper. The wide part of the stopper goes into the cap. Align the stopper so that the stopper holes are not visible
Cap top
Add the cap bottom and thread the M3 bolt into it. Again, align the bottom cap to make sure the stopper holes are not visible. Tighten the bolt just enough that the assembly is snug and can be tightened with the cap’s parts twisting out of position
Cap bottom
Select the two tank fittings and very carefully stretch the O-rings over them as shown. Push the O-rings all the way against their base
Tank fittings
Select the fuel tank and mark it as to the location of the fuel fittings. The exact position is not critical however they both need to be on the wider side of the tank as shown
Mark tank fitting holes
Drill both holes with a #10 (.1935”) drill. If you don’t have one of these use a 3/16” drill. DO NOT use a larger drill or it will leak fuel. Carefully clean away flashing from the holes and make sure no particles are inside the tank
Fitting holes drilled
Select these parts for the fuel pickup. Cut the pickup line length to 5.5”. Thread the filter material over the brass clunk fitting
Fuel pickup line
Assemble the fuel pickup as shown. The clunk weight will thread over the tubing connection on the clunk until it is flush with the filter as shown
Fuel pickup assembled
Insert the fuel pickup line into the tank opening, clunk end first. Using some bent pliers, carefully position the fuel pickup through one of the tank holes. Push it through and install one of the M5 nuts and washers. Tighten this but it doesn’t have to be critically tight. You may have to hold the fitting with pliers but be careful the fittings are plated brass and can be crushed.
Fuel pickup installed
Now install the fuel vent in exactly the same way in the remaining tank hole
Fuel vent fitting
Push the previously assembled tank cap into the top of the tank and tighten the bolt until it is fairly snug. Make sure that no holes are visible in the rubber stopper. If they are, remove the cap assembly and reposition the stopper
Tank assembled
Locate the 1” wide Velcro and cut both pieces in half as shown. Note one side is a “hook” and one side is a “loop”.
Tank velcro
Select one piece of Velcro and attach it to the tank as shown. Note the orientation of the fittings. Now attach another piece of Velcro to the opposite side of the tank as shown, again note the orientation of the fittings. When the tank is later installed,
the tank should be installed with the fittings on the side close to the battery plate to ensure proper canopy clearance of the fuel tubing
Tank Velcro installed
Governor Sensor
I highly recommend that you use a backplate sensor on your engine. Its simpler to install and requires little to no adjustment.
Backplate sensor
However, if you want to use a std magnetic sensor some options are supported with this kit. As noted earlier, if you are going to use a magnetic sensor you should have installed magnets in the fan as shown. Next you will need to determine what if any changes may be needed to use your particular sensor. As delivered the kit will support the Spartan sensor will little to no modifications. Others may require some modifications to the fan shroud. The Spartan sensor will directly mount using the M2 x 10 bolts/nuts
Sensor position
Locate and temporarily mount the left side fan shroud to ensure that the sensor fits. It will roughly align with the existing fan shroud opening
Sensor installed
There is an optional sensor mount included that allows for a sensor to be positioned in a different location on the fan shroud
Optional sensor mount
Next Step
Assemble Upper Frames
Old 05-22-2019, 08:56 AM   #3 (permalink)
Default Build Thread - JCD Goblin 570 Nitro 55 - Upper Frames
Upper Frame Assembly
The frame will be built in two sections, the upper and then the lower part. For this section you will need the previously assembled clutch stack and battery plate as well as the main plate and t/r servo mount from the donor model along with a T/R and throttle servo. Most of the upper frame assembly will be done using bolts and washers from the donor model
Start by preparing the frame sides. The right-side frame has PEM nuts installed for the throttle servo
Select frame parts
Because the Goblin canopy is quite narrow, you have the option of installing standoffs to prevent it from rubbing. Install one in this position on the left frame
Throttle servo standoff
And a second standoff in this position on the right frame using the M3 x 6mm bolts
Rear canopy standoff
Select these parts for the next assembly sequence
Main plate assembly
Re-install the motor plate onto the main plate as shown and engage the drive belt with the original secondary pulley. Initially the belt will be tight.
Clutch assembly installed
Itís easier to install the T/R servo now so select the T/R mount from the original donor model. It is HIGHLY recommended that you use the rubber isolators included with the servos
These parts needed for t/r servo
The servo will be installed in the mount in this orientation and alignment using the original mount parts
T/R servo assembled
Install the previously built T/R servo mount onto the inside of the left frame. NOTE the orientation and position of the mount posts
T/R servo installed
Mount these frame spacers to the front of the left frame as shown using existing M2.5mm bolts and cup washers
Install front frame spacers
With the t/r servo installed this is how the left frame should look at this point
Left frame prepared
Select the previously prepared battery plate and slip the tie wraps over the frame spacers as shown
Position battery plate
Now with the front plate tabs pushed into the left frame slots, pull the tie wraps snug on the isolators and clip off the excess
Secure battery plate
Now combine the main drive plate and the left frame as shown
Install main plate
Select the small rear frame brace. Its tabs will fit into the slots on the inside of the rear of the left frame. Test fit this to make sure it fits, if it is too tight you may need to adjust the slots on the frame plate Note Ė this is an optional plate to mount equipment like a SwitchGlo and is NOT required
Optional equipment plate
Next move on to complete the right-hand frame and install the throttle servo on the right frame using these parts. Again, it is highly recommended that you use the rubber servo isolators provided by the servo manufacturer
Throttle servo parts
The desired result is to have the top of the servo be flush with the outside of the frame plate for proper control rod alignment. Depending on what type of servo you are using you will need to use some of the included spacers to achieve this. For these BK servos we needed 3 on each side. You may need less
Spacers for throttle servo
Mount the throttle servo as shown on what will be the inside of the right frame plate using the M2.5 x 14mm bolts. Thread lock these carefully
Throttle servo installed
Now you are ready to combine the two upper frames, they will be oriented as shown here
Combine frame plates
Again, the frames attach using M2.5mm bolts and cup washers. Hereís how it should look from the left
Frames assembled left
Hereís how it should look from the right
Frames assembled right
Select the previously assembled rear canopy mounts, they will install as shown. Install them both using an M2.5mm bolt and cup washer. This completes the upper frame assembly
Canopy mounts installed
Next Step
Lower Frame Assembly
Old 05-22-2019, 08:57 AM   #4 (permalink)
Default Build Thread - JCD Goblin 570 Nitro 55 - Lower Frames
Now that the upper frame is complete, the lower frame will be built. For this assembly you will need the previously prepared engine plus the original Sport landing gear set.
Parts to assemble lower frame
The rear strut fits into the plate rear hole and the push it forward. The front strut has to be worked into place as itís a tight fit. When the struts are in place, install the skids and tighten the set screws that hold them in place
Push struts into lower plate
Select the rear frame mount and M3 x 8mm bolts for installation as shown
Rear support parts
The rear frame mount installs as shown. Push it forward so that it holds the rear landing gear strut in place
Rear support installed
Now the engine mounts can be installed using these parts
Engine mount parts
There is a right and left mount, they are not interchangeable. Note the orientation of the right-side mount
Engine mounts installed
The mounts install with M4 x 12mm bolts/washers and a frame doubler. Push the frame doubler against the front landing gear strut but donít fully tighten these yet
Engine mount bolts
Now the engine can be mounted into the lower frame plate
Parts to install engine
Install the engine as show using the M3 x 16mm bolts and cup washers. Donít fully tighten these yet
Engine installed
Finally, the fan shroud can be installed using these parts
Fan shroud parts
Insert the shroud spacers into one side of the shroud. Set one side of the shroud over the fan. Install the second shroud half by pushing it over the fan shroud spacers. This completes the lower frame assembly
Fan shroud installed
Next Step
Combine Frames
Old 05-22-2019, 08:58 AM   #5 (permalink)
Default Build Thread - JCD Goblin 570 Nitro 55 - Combine Frames
Combine Frames
It is easier to connect the t/r belt if you do so before adding the lower frame so if itís not already attached to the main plate do so now. Position the tail boom on the main drive plate as it normally attaches and slip the drive belt over the t/r pulley
Reassemble the tail boom
Now the upper and lower frames can be combined. If you have not done so add some light grease into the one way bearing on the clutch
Combine upper/lower frames
This will require a little patience however the parts will fit together. Start the assembly in the orientation shown and work the parts together until all the parts are in place and the start shaft is engaged into the clutch
Positioning frame parts
The upper and lower frames connect with six M3 x 8mm bolts and the fan shroud attaches with four M3 x 8mm bolts and cup washers as shown. However, before you tighten the bolts that secure these bolts, spin the engine over with your spin starter. This will ensure that the clutch is properly aligned. Now you can tighten the frame bolts, the engine bolts and the engine mount bolts underneath the engine
You may need to slightly re-orient the fan shroud before tightening it to make sure the fan isnít rubbing on it. The frame is slotted to allow this adjustment.
Bolts for assembly
Use one of the remaining Velcro pieces as shown on the battery plate. Make sure itís the correct Velcro type to mate with that you installed earlier on the back of the fuel tank
Tank velcro
If your tank is resting on the front frame spacer, you may want to cut a 1Ē piece from the supplied fuel tubing and slip it over the spacer as shown. This will keep the tank from rubbing on it.
Tank isolator
Attach the fuel tank to the battery plate as shown, it will be temporarily held in place with the Velcro. For canopy clearance the fittings need to be against the battery plate as shown
Install tank
Now take the remaining Velcro piece and attach it to the battery
Battery velcro
Attach the battery to the fuel tank as shown
Install Battery
Select the roll of 3/4Ē Velcro and cut it in half. You can use these to secure the battery/fuel tank.
Secure tank/battery
Next Step
Install Electronics
Old 05-22-2019, 08:58 AM   #6 (permalink)
Default Build Thread - JCD Goblin 570 Nitro 55 - Install Electronics
Install Electronics
Most of the electronics will install in the same as done on the donor model with a couple of exceptions. A flight system battery is needed, and the throttle servo must be connected
Install/connect servos
Select the parts to build the throttle rod. Make the rod the approximate length shown.
Throttle rod setup
Youíll need a spare servo arm as well as the throttle arm from the engine. If you are sure that the throttle servo is centered you can install the rod now
Throttle rod installed
If you have not installed the cyclic servos, do so now. I would highly recommend you use the servo isolators provided by the servo manufacturer
Swashplate servos
If you are sure that the T/R servo is centered, connect the T/R rod as shown
T/R Servo connecte
Gyro Mount
I would highly recommend that instead of using the stock platform that you instead use this platform from Darby Fabrications. It is machined from a Delrin type material and is drilled to bolt mount either a Neo or GY760 gyro
Optional Gyro mount
The Goblin 570 uses a suspended platform to mount the gyro, if you have not installed it do so during this assembly
Std gyro mount
It will drop over the two aluminum standoffs so it can be removed with the gyro attached and it will lock your tail boom nuts into place
Optional mount installed
Optional mount plate
If you have other equipment to mount and canít find a place to put it, there is an option to install this plate on either the left or right frame as shown
Optional plate installed
These are the parts needed to install the plate
Optional plate
Wiring
Since the battery is in the front and the gyro/rx is typically in the rear of the model, you will need to make a jumper wire to get the power to those components. You can make up a h/d wire as shown or simply use a servo extension
Jumper wire
Connect and route all wiring to the Rx, FBL system, battery, EI, etc. as your normally would.
Gyro installed
Make sure that no wire is rubbing against a sharp edge and that they are all secured using Velcro, tie wraps or another way. There is no one way to wire the model, this is just an example
Wiring complete
Since the control system is not high amperage you can use an on/off switch in the circuit if you like
Optional switch
If you want to use a Switch-Glo/Push-Glo you may want to install the equipment plate between the rear lower frame, it is an ideal place to mount these devices. I would recommend the version that uses an alligator clip to simplify glow-plug attachment
Switch-Glo location
Next Step
Complete Model
Old 05-22-2019, 08:59 AM   #7 (permalink)
Default Build Thread - JCD Goblin 570 Nitro 55 - Complete Model
Complete Model
There are a few items left to complete the model especially plumbing of the fuel system
The OS muffler is made for a left hand installation so the pressure tap is on the bottom.
Install Muffler
MStudio makes a right side version with the tap on the top which will let less burned oil into the fuel tank
Install Muffler - RH Version
Use the supplied fuel tubing to plumb the system. Make sure you connect the correct tubes to the correct fittings
Tank plumbing
Here is a more detailed look at how to plumb the fuel tank. Your system may be different depending on what engine you use
Detailed Tank plumbing
Keep the tubing inside the frame to prevent the canopy from pinching any of the lines
Engine connections
The kit includes a T fitting and fuel plug so that you can plumb in a fill line if you desire
Fill tube
Connect the vent line to either the muffler or to the pressure fittings depending on what your engine requires
Pressure fitting
Select the two vinyl decals provided in the kit
Decals
Find a location on the canopy for the decals. Remove the paper backing and press them into place then peel off the protective film on top of the decals to expose them
Decals installed
You will need to make a hole in the top of the canopy for your spin starter. It needs to be large enough for the wand to fit through it. The exact location is shown
Starter opening
Fit the canopy and make sure that none of the fuel lines or wiring is pinched. Depending on your exact setup you may or may not have to make small reliefs on the sides of the canopy for the throttle arm or the needle valves on the engine. Just make sure the throttle rod or ends are not rubbing on the canopy
Install Canopy
Next
Summary
Old 05-22-2019, 09:00 AM   #8 (permalink)
Default Build Thread - JCD Goblin 570 Nitro 55 - Summary
Summary
Doug Darby, Cryhavoc1 and Kgnx like this.
Old 05-22-2019, 04:11 PM   #9 (permalink)
Awesome build log and photography.
Sent from my MI 5s Plus using Tapatalk
Doug Darby likes this.
Azalin is offline        Reply With Quote Quick reply to this message
